BMW X3 Forum
BMW X3 Forum
      04-25-2024, 02:23 PM   #1
jaydv
Drives: BMW X3
Spark Plugs
I’m going crazy trying to pull my plugs! I’ve used 14mm, 15mm and 5/8” long reach sockets! None of which seems to work!
What size sockets are you all using?
      04-25-2024, 02:29 PM   #2
mwat
131
Drives: E46 M3 & LCI X3 35i M Sport
2016 BMW X3 35i  [0.00]
2001 BMW M3  [0.00]
You need a thin walled jointed 12 point 14mm socket.
I think I used this one when I did mine: https://www.amazon.com/Magnetic-12-P...s%2C320&sr=8-7
If you don't use a jointed one you risk breaking the plug off in the socket
Also curious why you're switching to NGK's
      04-25-2024, 04:00 PM   #3
jaydv
Drives: BMW X3
Mwat
Thank you, THANK YOU!
Why in god’s name would BMW make this so difficult? A “thin walled” socket? GTFOH! Now I’m gonna have to find one that’s a little less expensive that what you recommended.
Thanks again!
PS. Using NGK because I don’t know any better!
      04-26-2024, 06:38 AM   #4
HPR
HPR's Avatar
Drives: 2015 X3 35i M Sport
Amazon has a plethora of the 14mm BMW compatible thin wall sockets ranging in price from $10.00 to $17.00. If you purchase the socket only you'll need a u-joint or wobbler extension to access the number six plug if you have the N55 engine.
Pat
2015 F25 X3 35i M Sport - Carbon Black
mwat131.00
      04-26-2024, 07:55 AM   #5
mwat
131
2001 BMW M3  [0.00]
Originally Posted by jaydv View Post
Mwat
Thanks again!
No problem! It's never easy, but always satisfying figuring it out. I picked this one because the plug is about a foot into the engine so I remember it working great. If I'm remembering correctly it was too long to get to the one in cylinder 6 so I had to use an extension and another socket... I think. I really can't remember. 1-4 is easy, 5 is a challenge, 6 sucked. (EDIT, I see the guy above me said the same thing so I'd wager you may need to buy a socket with a joint on it (for cyl 6) and the extension one I linked.(for 1-5)
Also I'd just stick with OEM plugs, but that's just me.
      04-29-2024, 07:22 PM   #6
ClutchFC
Drives: X3 35i
Mwat
Thanks again!
You wanted a BMW . Do some research before you jump into a project, you can easily make costly mistakes.
      04-29-2024, 07:43 PM   #7
pungo
pungo's Avatar
Drives: Z4MC-X3-35i-525i, Corrado G60
IDK, if you can't afford a $10 tool to perform some maintenance, you're in for a world of hurt wrenching on your BMW
      04-30-2024, 07:08 AM   #8
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
73
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [9.50]
OEM plugs from BMW is NGK plugs but branded as "BMW" plugs...
just like buying RAM from Apple for a Macbook or iMac... versus ordering from INTEL or another RAM memory chip manufacturer
BLACK 2017 BMW x3 xDrive28i [N20] xLine Package, Comfort Access, Build Date: 03/03/2017. *[THE POWER OF 33]*
      04-30-2024, 07:26 AM   #9
Jolbex
51
Drives: X3
They used to be Champion...
      04-30-2024, 07:56 AM   #10
mwat
131
2001 BMW M3  [0.00]
Really? The factory plugs I pulled out of mine were Bosch branded as BMW. All the parts sites reference Bosch as the OE plug and NGK as the step colder plug. Interesting. Can you post your source?
pungo899.50
      04-30-2024, 10:03 AM   #11
slowblackx3f25
xdriv33
73
2017 BMW x3  [9.50]
I remember way back it used to be BOSCH plugs. I know Audi/VW all use NGK plugs as OEM plugs. I thought I mixed it up but a quick search I found this source:
Source:
https://shop.bmw.ca/p/Bmw__/Spark-pl...120039664.html
step colder plugs are for tuned BMW's/vehicles in general, right? please correct me if I am wrong...
"I know that I know nothing" - Socrates
      05-01-2024, 09:18 PM   #12
slowblackx3f25
xdriv33
73
2017 BMW x3  [9.50]
Source:
another source:
https://oembimmerparts.com/products/...kit-oem-6-pack
      05-02-2024, 06:57 AM   #13
mwat
131
2001 BMW M3  [0.00]
The first link you posted is for 4 cyl engines, the second link above is for an e46. Maybe there's a nuance between the N20 and the N55 when it comes to the OEM spark plug manufacturer but I can say with 99% confidence that the OEM plug for the N55 is bosch.
      05-02-2024, 08:40 AM   #14
slowblackx3f25
xdriv33
73
2017 BMW x3  [9.50]
looks like it varies between models/engines
Source:
https://bmwsparkplugs.com/products/b...em-spark-plugs
BOSCH it is! (N55)
Anyone know if BOSCH is better than NGK?
I've used NGK plugs on all my vehicles, non-bmw/bmw's... no issues at all
mwat131.00
      05-02-2024, 01:27 PM   #15
mwat
131
2001 BMW M3  [0.00]
Source:
BOSCH it is! (N55)
Ultimately I think people have success with both brands. In my research I think there's just more room for error with the NGK. Some people swear by them so who knows. I'm pretty sure when I did my plugs on my E46 M3 they were NGK.
      05-02-2024, 07:39 PM   #16
ClutchFC
Drives: X3 35i
As long as you’re putting the right plugs in and it’s not something for a different car, I’d argue you’re not really going to find a plug that’s significantly better than the other. They’re just spark plugs. When I was working on a top fuel funny car team, the plugs they used in an 11,000HP engine were Champions. You’re in an X3 bruh. You’ll feel the same performance whether you go Bosch or NGK.
Now if you were to grab a PR coil kit or B58 coil conversion kit you’ll see some performance improvement, but the plugs are going to spark only as much as the system is going to give it.
The gap difference is where you may experience rough performance. So before you screw those bad boys in double check the gaps and put them into spec.
      05-03-2024, 07:10 AM   #17
ClutchFC
Drives: X3 35i
No you’re right. A plug you probably shouldn’t worry about unless you’re at least Full-Bolt-On. Even then I’m sure some N54/N55 wizards will say they’re unnecessary. All I can say is, I’ve ran Step2 colder plugs in both a N54 and N55 FBO setup and can’t report any negatives to performance.
xbimmers
