BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > High pressure fuel pump confusion
Extreme Powerhouse
      11-14-2021, 04:22 PM   #1
Jkflo30
Drives: 335i
2013 BMW 335i  [0.00]
Hi all, really need some help rebuilding my car. I blew up my original engine 2013 f30 335i n55 and am in the process of swapping in a used motor. The engine I found (also n55) is dropped in but I just noticed the hpfp isn't the same as what I had. I don't really know how to proceed. The confusion is because on the original engine the hpfp bolt holes do not align with the engine I put in. There also looks to be some sort of mounting plate that you would think you could remove but it feels locked onto the motor (blown one). Not sure if it matters but the engine came from a 335xi. Yes I know I have to swap the pans.
I'll attach some pictures to make this more clear.
My question is if I should be looking to swap fuel pumps and adapter plates over
OR
Looking for a pump that fits my car
I'm also unsure what is considered "better" or "newer" because I'm already balls deep in this project and just want to do it right the first time (and not keep redoing everything)
Thanks to anyone that can give some guidance on this.
      11-14-2021, 04:31 PM   #2
thejeremyman9
thejeremyman9's Avatar
4392
Drives: 2015 BMW 335i
What year was the donor engine from? Did it not come with a HPFP? Is the picture the HPFP from your original engine?
      11-14-2021, 04:38 PM   #3
Jkflo30
Drives: 335i
I don't know I believe 2012. The guy I bought it from keeps blowing me off
      11-14-2021, 04:53 PM   #4
thejeremyman9
4392
Dorch website suggests there are some differences over the years, but maybe just harness? https://dorchengineering.com/product...-hpfp-upgrade/
      11-14-2021, 05:00 PM   #5
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
if you bought an n55 out of an E series it's different.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      11-14-2021, 06:40 PM   #6
5w20
@_sunbish
5w20's Avatar
294
Drives: Bmw 435i & 340i
OR
That's the vacuum pump. I don't have any experience changing it, but it looks like you will need to access it from the front to unbolt the drive sprocket that is driven by the chain that rotates the vacuum pump, oil pump, and crankshaft. I'm not sure if the front half is different, but I would see if you can swap the rear portion of the vacuum pump that houses the HPFP.
      11-15-2021, 12:08 PM   #7
Jkflo30
Drives: 335i
Thanks all for the quick replies. I know the harness has changed some but the major issue is the bolt up pattern. I didn't want to have to take that cover off and play with the chains because I don't want to throw it out of timing. If I got it off an E can I just buy an e series fuel pump? I'm having a hard time finding much info on this caveat
      11-15-2021, 12:10 PM   #8
Jkflo30
Drives: 335i
And no the guy I bought the engine from removed the pump before selling it. Left the turbo, took the fuel pump. Makes no sense
      11-15-2021, 12:11 PM   #9
Jkflo30
Drives: 335i
I have tried rotating the blown engine and then to try backing off the plate and it won't release. All bolts removed it will come off like an inch from the vacuum pump before it gets stuck
      11-15-2021, 12:27 PM   #10
Jkflo30
Drives: 335i
The seller just got back to me it's from a 2012 E90
      11-15-2021, 12:37 PM   #11
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
you cannot use the e series fuel pump etc on the f series. it's just different. it uses the old style n54 setup. it's like a weird hybrid of the n54 and later n55.
      11-15-2021, 01:02 PM   #12
thejeremyman9
4392
Yeah you may want to pause and evaluate if you can even use the E series N55 in your F series without other changes (harness? DME/coding? etc). It might be more work/time/money than just sourcing a F series N55... not entirely sure.
n55david1306.00
      11-15-2021, 01:18 PM   #13
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
this.. I was under the impression that they are just different.
      11-15-2021, 05:43 PM   #14
Jkflo30
Drives: 335i
So far the only really obvious differences are that I need to swap the oil pans (the xi being much different due to the front axle drive) and the fuel pump. I am swapping over my DME, am considering replacing injectors. Both the "old" and "new" engines say n55b30a so I know they are the same in that regard. I have a manual trans too so I'm swapping flywheels and what not but that's just nuts and bolts I already had to do it once when I replaced the trans.
So far this is really the only feedback and help I've gotten for this issue. Is there anything you guys can think of that may not be compatible?
      11-15-2021, 06:04 PM   #15
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
havw the rod bearings replaced two since the oil pan is coming off. e series motors tend to have more of a problem with this.
      04-04-2023, 12:37 AM   #16
Gerardo
Drives: 2007 550i
Ever get this figure out, dealing with the same thing.. haha
      05-21-2023, 07:35 PM   #17
Tolo35
Drives: 2014 bmw 335 xdrive
Any update on this..? Running into the same issue
      05-21-2023, 07:37 PM   #18
Tolo35
I have an f10 n55 engine that blew(looks like your third picture) and bought an n55 from a 2013 335xi (looks like your second picture)
Everything has been going smooth so far but swapping these over was not as easy as I thought it’d be.. any insight at all would be greatly appreciated
      05-21-2023, 08:54 PM   #19
madrrio
Capable
madrrio's Avatar
Drives: 335i m sport
I really wish people would check in w solution. My n55 is out of a 640i (going into f30) and so far I have swapped the oil pickup so I can use my old pan, I am in the same situation and think the best way to approach this is swapping the brake booster and fuel pump (though this requires holding the motor chain in place.
I'll try and message the autonwreckers as they took off the hpfp as well.
      05-21-2023, 10:25 PM   #20
Tolo35
Agreed. Keep us posted! I might just have to swap everything else over and take it to a shop to finish the job.
      05-22-2023, 01:26 AM   #21
madrrio
Capable
madrrio's Avatar
So the solution is to remove the brake booster cover. Use a tool to hold the gear in place, remove center bolt and 3 surrounding. Bolts while keeping gear in place and replace the booster/ fuel pump assembly with the one from original motor. If more pictures are wanted I can accomedate.
      05-23-2023, 09:16 PM   #22
Tolo35
Sweet! For those who may be worried like I was, it’s connected to the oil pump chain so you don’t have to be worried about timing.
How hard was it to remove the cover & how did you go about it? Did you have to replace it after?
Did you use a special tool to hold it in place?
hpfp, hpfp upgrade, options
