Ok, it's 2019, what springs are my best bet (2011 M-Sport 328xi)
10-08-2019, 06:43 PM | #1 |
111
Rep 81
I just bought a 2011 M-Sport 328xi. It's a nice car, but coming from E36 and E46 sport package and M cars, this thing handles like a Caddy. BMW calls this M-sport suspension? It's a DD, so I'm not looking to slam it. I just want it to handle like a BMW with sport suspension should. Not to mention the 4 finger gap between the tire and fender.
Anyways, I've had great luck with Koni yellows on my cars, so I was planning on that. I've read H&R sports (50494) are overly stiff. It seems the Eibach Pro springs aren't right for Xi cars, so I'm not sure where else to turn. What do people run in M-sport Xi cars to get the car to handle like it should have out of the factory? Photobucket's foolery makes it tough to dig up pics from old threads, and info on XI cars is hard to find. |
10-11-2019, 09:22 PM | #2 |
78
Rep 239
Even though you have the M sport package, BMW only offered one suspension setup from the factory on xdrive cars. So you really have stock non-sport suspension. Wheel gap is increased on the xdrive cars to try to make up for some of the last travel due to the space taken by the front axles. There's a suspension compatibility sticky at the top of the subforum. I don't think H&R or Eibach officially support xdrive, but lots of people have used those setups.
Antetokounmpo1551.50 |
10-15-2019, 10:43 PM | #3 | |
111
Rep 81
10-22-2019, 09:04 AM | #4 | ||
Rep 1,482
Drives: 2008 BMW 335xi (E90)
Instagram: @4doors
Current: 2011 E91 328i M-Sport Touring Past: 2008 E90 335xi 1996 E36 328i Sport |
10-22-2019, 01:36 PM | #5 |
119
Rep 106
Drives: '19 M2C,'07 335xi, '11 335ix
First Picture: 2011 335i xDrive with Eibach 2092.140 springs and Koni Yellow Shocks. The fronts settled fine but rears settled a bit too much for rear passenger transport.
Second Picture: Same car with 2092.140 front springs only and OEM ZSP D5 rear springs and Koni Yellow. Current setup. Third Picture (not the best quality picture): 2007 355xi with OEM ZSP D7 front and D6 rear and Koni Yellow. I hope this helps! |
10-22-2019, 03:15 PM | #6 |
Rep 1,482
Another big factor and piece of suspension to change out are the bump stops. By putting on lowering springs and different shocks/struts you need to change out the bump stops because of travel. Usually the E36 M3 bump stops in the front and Z4M bump stops in the rear work great! That is what I run.
Instagram: @4doors
10-23-2019, 09:47 AM | #7 |
103
Rep 139
How did you go about getting the Euro spec springs? I'd like to do this combo with the Koni yellows in the future but don't want to use the RWD springs as I think they will lower the rear too much for my liking.
10-23-2019, 11:00 PM | #8 |
93
Rep 117
10-24-2019, 10:26 AM | #9 | |
Rep 1,482
I do not have the Euro-version of the Eibach springs. I have the RWD version and they work great. Many others on here use them as well with no issues. Again, the big piece to remember is travel and switching bump stops helps greatly.
Instagram: @4doors
nicked8102.50 |
10-25-2019, 11:26 AM | #10 |
Rep 620
Drives: E90 335XI MSport, S2000
Dinan springs w/ Bilstein B8's. I switched from the eibach pros to the dinans when I got the car because it was crashing over bumps.
11-15-2019, 09:46 AM | #11 | |||
eBay Special
3108
Rep 3,038
Drives: E90 330xi
Common sense is a flower that does not bloom in everyone's garden
11-15-2019, 09:48 AM | #12 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
How's the ride quality compared to the pros? And do you have pics as well?
11-16-2019, 12:03 AM | #13 |
Rep 598
Do what I did, get bigger 18" wheel and fatter tire 235/45/18.
You can even do 235/40/18 and look flushed. Your car will FEEL sporty just by using Bilsterin HD/6 dampers. Xi springs are stronger than other, made to handle the boat weight of 3770 on wagon xi I wouldn't down grade to other weaker springs. But I hear E93 has same weight and it sits low, so perhaps you can use those springs. If you want to FEEL sportier, what you need are solid (not hollow, not liquid) suspension arm bushings for front and sub frame bushing inserts for the back. |
