Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > HELP FITMENT 19x9.5+40 and 19x8.5 +35 5x120?
      06-03-2013, 02:10 AM   #1
E90PETEPNW
E90PETEPNW's Avatar
Drives: E90 LCI 6MT
I found some wheels but the offset looks a little strange? Will these fit without any modification? I have a E92 2007 335i w/ sport package suspension. Please help thanks!
      06-03-2013, 02:13 AM   #2
project335i
144
Drives: Wide Load
Yes but they will be sunk in and you will need some spacers.
If you get the wheels pm me I can help you out
      06-03-2013, 10:09 AM   #3
E90PETEPNW
E90PETEPNW's Avatar
Drives: E90 LCI 6MT
Will I need spacers for the front and rear? Also, what size spacers? Will this offset effect handling at all?
      06-03-2013, 10:11 AM   #4
Projekt_BooGie
Average Car Exceeding Expectations (ACEE)
Projekt_BooGie's Avatar
Drives: 2007 335i e92
2007 e92  [7.00]
those are basically close to factory offsets. Depending on the look you want will depend on what size spacers to get.
too much to list...just know its wide and bagged
      06-03-2013, 12:12 PM   #5
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Those specs will definitely work. 7mm spacers in the rear and you'd have the specs that we normally would recommend for an E92.
      06-04-2013, 01:30 AM   #6
waterbottle1
waterbottle1's Avatar
153
Drives: F80 M3
same setup
hey man,
i got the same setup, but lowered on coils
and yes you do need spacer.
      06-04-2013, 04:11 AM   #7
OB
Sweden
37
Drives: 335i wagon, Pure Stage 2+PI...
You'll prob only need spacers for the rear IMO. I'm running Et 35 on 8,5 in the front and 9,5 et 25 in the rear on my E91 with stock sport susp. Original et for the 9,5 was 40 as well, but got 15mm spacers after I rolled the fenders. Et35 would prob be enough I guess.
Of course, the tire size matters as well.
If you go with 235/35/19 and 265 or 275/30/19 it would be sufficient with a 5mm (or more if you like the look) spacer for the rear and non in the front IMO.
figment, offset
