06-27-2014, 11:37 AM | #23 | |
Now in the dark side !
65
Rep 1,136
So if you like this setup, and still want to use your 17" winters, do like I'll do: Paint the front the color you like, and only get the back ones. Upgrades for the 328i and 335i are (either M Sport blue or M Performance red-yellow-orange): 370mm disks with matching calipers front 345mm disks with matching calipers rear.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
06-27-2014, 01:30 PM | #24 | |
Law Enforcer
25084
Rep 22,282
Drives: '22 Chalk Gray Porsche C2S
06-29-2015, 10:03 AM | #25 |
Rep 2
Hi,
just found this post and have one additional question. The difference between calipers is clear, BUT which brake pads should I use for calipers 34116799465/6 with 340mm rotor and which ones for calipers 34116799469/70 with 370mm rotor? Thanks to anyone who can advise on this!! m. |
06-29-2015, 10:36 AM | #26 | ||
Rep 1,637
Are they the same brake as 335i? Can directly replace stock calipers with blue one? |
06-30-2015, 12:41 AM | #27 | |
Rep 3,468
428 gets 11.8" rear rotors and 12.3" front 428 GC gets 11.8 rear rotors and 13" front 335 brakes are 13" rear and 13.4" front, this uses the m-sport front caliper and a traditional 1-piston sliding rear caliper. Upgrading to "M sport" brakes on the 428s gets m-sport front AND rear 2-piston calipers, which are fixed calipers and the bigger rotors from the 335. This is a no brainer upgrade if you like brakes (I do). For $600, you get a slightly better braking system than the stock on 335s. Upgrading to the "M sport" brakes on the 335 for $600 paints the front caliper blue and gives you the blue rear 2-piston fixed calipers. This is not a great deal and doesn't do much for the braking, since most of your braking is done with the front anyways. Upgrading to the "M performance" brakes on the 335 gets you 14.6" front rotors and 13.6" rear rotors, plus cross-drilled/grooved. Same basic calipers as above on the "M sport", but I don't know what the mounting looks like, since obviously it fits the bigger rotor. Most likely the caliper-half is a different part number from whomever really makes the brakes (brembo does lots of OEM stuff, even the relatively low-end). This could be worth it, but mainly you are getting the bigger rotors. IMO it's $$$ (several thousand) better invested in a real "big brake kit", with 4 or 6 piston stoppers up front and 4 piston in the rear. |
06-30-2015, 12:54 AM | #28 | ||
Rep 1,637
I might go for m sport brake and 335 rotor but I just want the look of caliper. Not sure I need the rotor though. |
06-30-2015, 08:36 PM | #29 | |
Rep 10,351
M-Sport brakes and M-Performance Brakes use same rear calipers.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
07-07-2015, 12:21 AM | #30 |
Rep 2
ok, but on guy here has M-Performance with 370mm rotors, I have M-Sport with 340mm rotors, it means these are two different calipers
his: 34116799469/34116799470 mine: 34116799465/34116799466 so how can we have the same brake pads ??? |
07-08-2015, 11:55 PM | #31 |
41
Rep 141
That's because the Calipers are exactly identical. The part numbers on the calipers are identical, the end numbers are different because of color code. Your rotors are different size, but the calipers aren't, and the brake pads are cross-compatible also.
07-11-2015, 03:36 AM | #32 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
so in order for me to get the M performance brakes.....I can just buy the Msport rear calipers and then all 4 drilled/slotted rotors and then paint my front calipers and im good to go?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
02-06-2016, 06:45 PM | #33 |
32
Rep 181
Guys i have a question. So if i get the blue m sport brake calipers. Tht can fir the 335 rotors? 340 in the front and 330 in the rear? The rear wont be too small?
02-07-2016, 03:38 AM | #34 | |
Rep 603
http://f30.bimmerpost.com/forums/sho...d.php?t=858607 S2NHA M Sport Brakes (blue colored): S2NHA Variant 1: Front rotor: 340x30mm (Millimeter) / Brake Caliper with 4 piston Rear rotor: 345x24mm / Brake Caliper with 2 piston S2NHA Variant 2: (all 335i/d Version, Europe Version of 325d, 328i, 330d) Front rotor: 370x30mm (Millimeter) / Brake Caliper with 4 piston Rear rotor: 345x24mm / Brake Caliper with 2 piston Be aware that rear rotors 345mm are available in tow different version. You need to verify the fit the hand-brake/emergency brake installed. You possibly also need to change the dust cover plates to fit larger discs.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
M4_GTS1152.50 |
02-07-2016, 07:02 AM | #35 | |
32
Rep 181
brakes
Part #34206797607 and 34116792223 are good? I can buy these instead of the slotted/dimpled ones? Thanks |
04-25-2016, 06:50 PM | #37 |
Rep 1,805
I have a complete set front and back for sale.
PM if you want details.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
08-13-2016, 06:19 PM | #39 | |
54
Rep 258
Drives: F30 320i (328i ECU) M-Sport
The pads are interchangable as the rotor working surface has equal width (say pad path)- the diameter is bigger so is the brake force arm, the contact area is the same.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
M4_GTS1152.50 |
08-13-2016, 06:20 PM | #40 |
54
Rep 258
Both of them.
08-13-2016, 06:24 PM | #41 | |
54
Rep 258
These are miles ahead the M-Performance (same are in 335i stock fronts) pads, which have low initial bite and dull pedal feedback.
08-15-2016, 06:23 PM | #42 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
I picked up a full set on ebay for £500
08-16-2016, 07:23 AM | #43 | |
Rep 682
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages |
08-16-2016, 08:57 AM | #44 | |
Rep 940
blue, brakes, caliper, f30, msport |
