10-24-2015, 10:41 AM | #243 |
15
Rep 57
What kind of led's do you have for your daytime running lights?
10-28-2015, 01:11 PM | #244 |
Rep 1,835
Drives: 2020 X4M CS
I had LUX, V3's I believe 6k? It's been a while...But i actually just had to replace them bc a wire came lose...Now I have some $50 Amazon 6.5k LED,s to be honest while they are def not as bright as the LUX, I like the blue/white much more...
I also coded them to be much brighter during the day.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
10-29-2015, 10:43 AM | #245 | |
Rep 7,120
Cheers |
11-21-2015, 10:16 AM | #246 | |
Rep 1,835
Drives: 2020 X4M CS
Generally speaking, Diodes ca vary in brightness based on the level of impedence placed before the "bulb" or LED. I need to test w a multi-meter.
11-22-2015, 07:47 AM | #247 |
Rep 1,835
Drives: 2020 X4M CS
Updates!
ATTN: ALL BMW TECHS, HOW THE F**K DID THIS HAPPEN?
I stopped at a light after about 30 mins of moderate driving, when I heard what sounded like a gun shot under the hood then the gar had a major misfire on 1 or more cylinder. Popped the hood liquid everywhere. It was dark assumed a piston punctured the block once I got a light I found what actually happened and it makes o sense. The coolant over flow tank EXPLODED.... the hot coolant cover the engine bay and soaked a few injectors/ sensors which caused the engine o have major misses...Heres some pics. Anyone ever see this before?
11-22-2015, 08:12 AM | #248 |
Rep 1,835
Drives: 2020 X4M CS
Update: New Subwoofer Installed
COMPONENTS:
-OEM CD/DVD Player (Upgrading to Android multimedia) -Audio Control Line Output Converter/ Line Driver with ACCU-BASS technology to prevent factory bass roll off -Hifonics BX10 Digital Bass Restoration Signal Processor. -Pioneer Championship Series Amplifier Class D 2400 watt. 800RMS @ 2ohms(2 CH / Bridgable) -Alpine Type Type R Subwoofer 12" (Wired in Parallel, 2 ohms) Recommended power handling 800-1500 RMS. -Vented Enclosure, 1.4 cu/ft, stuffed with poly-fill and sealed around the speaker, and wire terminals with silicone. -Planet Audio 2.0 Farad Capacitor w/ Voltage display. Sounds incredible for just 1 sub... At full volume the factory Mids/Highs hold there own against the Bass. Want to add one more Type R but that would most definitely involve amping the stock components in the car or swapping and amping them... Notice in the pics, I also added some M3 and BMW Patches LMAO. Corny I know but wanted to do something with them for a long time. Does anyone know if the OEM speakers in the M3 (I believe I have the Hi-Fi) (2) tweeters, (2) Front door speakers (1) center channel sub and (2) 8" underseat subs...Can these speakers handle more power than the stock amp? Or can I reuse existing speaker wires and a 6 Channel LOC to push a 4 channel amp and replace the door speakers and underseat woofers???
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 11-24-2015 at 09:50 AM.. |
11-23-2015, 12:14 AM | #249 | |
Rep 950
11-23-2015, 07:03 AM | #250 |
Rep 1,835
Drives: 2020 X4M CS
I considered those possibilities but they said this is a common problem ROFL
If so, I never heard of it. a week later they still have the car. Keeps throwing codes and/or warnings "engine malfunction, reduced power", erratic idle. major misfires, etc. Biggest fear is a bad head gasket (pressure entering coolant system...\ Anyone have any similar experiece'''
11-23-2015, 01:26 PM | #251 |
3387
Rep 7,542
I've never seen the tank explode like that... The cap has a pressure release so it shouldn't get to that point.. pretty crazy.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
11-23-2015, 05:14 PM | #252 | |
Rep 1,835
Drives: 2020 X4M CS
Made no sense to me either, but maybe you could shed some light on this...(One service manager said hes see the coolant issue a lot?!? lol) I dont buy it. Anyway, a Few hrs before the incident, with the Engine just warmed up, "Engine Malfunction",: "reduced Power",: "goto nearest BMW blah blah" message on CIC, along with bogging under throttle, erratic idle... I shut off/on ignition. Misfire went away, along message and he CELy. Few hours later, Boom. Explosion, and all the earlier messages pop back up. I shut off the car immediately. Only drove 1 moment to get iff the main rd. Car was bogging. DEALER DIAGNOSIS: Replaced actual tank. Cleared codes. "Faulty throttle actuator came up. They replaced that and car still missing??? They were stuck scratching there heads fri. Today I got a message my SM think ill b done tomm...Very curious to see wtf happened. Any Ideas Mike? Or not enough info?
11-23-2015, 06:39 PM | #253 |
Rep 4,172
Only possibility is that the pressure cap got stuck shut somehow and the system over pressurized and blew.
But in my many years of car ownership I've never ever heard of this happening. The pressure cap always fails by not being to hold pressure and the car overheats, but not the way around. On a side note, we now know the coolant hoses are tough. |
01-08-2016, 09:05 PM | #254 |
Rep 1,835
Drives: 2020 X4M CS
Update: January 6th 2016
Subs broken in and hitting HARD...
Need some repairs which il post about later which requires a new rear section... but in the last 2 weeks Ive gotten... 1.CF Splitters (OEM Reps)...Same ones I had last year 2.CF Perf Spoiler BMWhat Gen II OBD adapter (RE-coded DVD in motion that I lost when my FRM was replaced. 3.CF Roof Spoiler (On its way) 4.CF Mirror Covers OEM Reps 5. Monochrome (Black/Silver/White Stripes with Matte BLack ///M Performance windshield Stick...Over a dark tinted "sun strip" so is going to be low key (On its way) 6. LED white interior light kit 7. 7k HID Low Beams (not installed yet) 8. Aftermarket HUD...
01-08-2016, 09:07 PM | #255 |
Rep 1,835
Drives: 2020 X4M CS
Ooops I almost forgot...
PS: Also got a Challenge Rep Rear Diffuser...Will post pics as I do the installs...
01-17-2016, 10:15 AM | #256 |
Rep 1,835
Drives: 2020 X4M CS
Got a few new mods:
Carbon Fiber: Mirror Caps (Above), Challenge Rep Rear Diffuser, Roof Spoiler. Shift knob, and monochrome ///M Performance Windshield Sticker which I may or may not put on...I got the writing in matte black and was going to pu it over the tinted strip on the windshield to make it very subtle. If it sticks out too much Im not putting it on.
01-19-2016, 08:25 PM | #258 |
Rep 1,835
Drives: 2020 X4M CS
Agreed. Not to mention it's heavy, doesnt match the roof 100% and I'd be scared having that piece help with 3M tape....The Sticker too. might have ti go on the wall...lol
01-19-2016, 09:46 PM | #259 |
Rep 1,326
Any pics of the challenge rep diffuser? Didn't know there was one!
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
01-21-2016, 08:14 PM | #260 |
Rep 1,835
Drives: 2020 X4M CS
I shouldn't say replica. It's much different in detail but I should've said challenger style diffuser that is relatively common. I'm on an android phone number can't figure out home to post pics but tomm athe work I'll throw up pics of everything
01-22-2016, 12:58 PM | #261 |
Rep 1,835
Drives: 2020 X4M CS
Pics
Heres a pic...should have been more specific
02-04-2016, 07:29 AM | #262 |
Rep 1,835
Drives: 2020 X4M CS
Been a While...
Few New Pics...
More shortly...
02-04-2016, 11:32 AM | #264 |
Rep 1,835
Drives: 2020 X4M CS
Not Gonna Lie, while the paint was probably the shiniest cleanest jobs i'd ever seen...The last 2 years have "Lackened the luster, lol"...
A little increase in "Contrast" goes a long way along with Jet Black Paste Wax and spray detailer lol... But Thanks Bro
6mt, diffuser, e92, jet black, mode |
