08-25-2016, 07:32 PM | #67 |
Rep 4,499
Insane brother just insane!!!
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
08-26-2016, 10:14 AM | #70 |
Rep 850
Now stop making me wait to be a beta tester
Current
15 911 Turbo S Past 03 MB E55 AMG, 16 Grigio Medio F80 M3, 11 E92 M3, 13 BRZ, 06 Evo IX, 05 350Z |
08-28-2016, 04:09 PM | #72 |
4496
Rep 1,862
Drives: powered by bootmod3
08-28-2016, 04:42 PM | #73 |
30
Rep 162
08-29-2016, 01:02 PM | #74 |
4496
Rep 1,862
08-29-2016, 01:19 PM | #76 |
Rep 471
Sorry if this a dumb question but why to stack with JB4 like M4HCP did? What can JB4 do additionally that the tune cannot? I was thinking of switching JB4 with bm3 as soon as it's out. But depending on the answer I may keep it as well.
08-29-2016, 03:41 PM | #77 | |
4496
Rep 1,862
Flashing with bootmod3 calibrates the engine computer the way factory intended. Everything form fueling, ignition timing, boost/load targets, valvetronic, exhaust flap settings, overrun (burble/sound tuning), cold start, various limits for torque levels, etc you name it are adjustable in the flash. Piggybacks don't have the ability to program the DME but they can influence the systems in realtime externally and play a convenience role as a secondary system for boost mapping, meth control, secondary port fuel injection control, etc for many. In our neck of the woods we like to call flashes front-end flashes and piggybacks backend controllers given where/what control is possible with each, not the other way around, but that nomenclature is up for debate LOL |
08-30-2016, 10:18 AM | #79 | |
Rep 476
Importantly, this "dynamics" OTS map, would be ideal if it didn't increase peak boost pressure over OEM. Higher peak boost pressures take more time to reach and thus increase turbo lag. So, although many people would hate this, a map with lower peak boost that maintains near-stock HP (via ECU timings or whatever) would be worthwhile IMO. I'm not sure if that is technically feasible though. |
08-30-2016, 11:33 AM | #80 | |
Gone Fishin’
7318
Rep 12,125
08-30-2016, 01:31 PM | #81 | |
4496
Rep 1,862
FSociety3812.50 |
08-30-2016, 03:42 PM | #82 | |
Rep 476
Have you guys been able to achieve something similar to this (991.2, also a 3.0L twin-turbo): This appears to be the holy grail of FI-engine linearity. It's effin beautiful. |
08-30-2016, 03:51 PM | #83 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
proTUNING Freaks For those with JB4 currently is there an advantage or disadvantage of using it of a stack ?
Currently the advantage is the boost control of course and map switching on the fly via bluetooth. But there's also some disadvantage where was the JB4 needs more Boost when run as Backend than say a Full Flash tune car to put out the same power.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-30-2016, 05:23 PM | #84 |
Rep 1,184
My take on the JB is this. You get yourself the most power you can with a flash only and then see where you sit. At that point see what you get with a JB on top if you like maybe to run low boost but at the same time map switch is like a minute or so. Why switch maps though unless your mods or octane changes just makes no sense.
08-31-2016, 09:11 AM | #85 | |
4496
Rep 1,862
What boost you 'can' run is a function of octane and hardware on the car. Boost though is just one part of the equation. You have to ensure ignition timing and fuel are on appropriately set for a given boost profile that ensures the most power without significant knock (i.e. reliable power that keeps your car out of the shop and away from potentially very expensive repairs). One disadvantage might be, not sure you can call it that really, is you need to be in map 0 on the JB4 (or any piggyback using the diagnostic bus in the car) to use bootmod3's diagnostic and logging features. These features are something we're working on expanding constantly and there are plans there for quite a bit more than datalogging and the live dash that we already have in beta. |
FSociety3812.50 |
08-31-2016, 02:12 PM | #87 |
4496
Rep 1,862
Not sure where in Europe you are but we've received quite a bit of feedback from shops in Europe in regards to bootmod3. Halim who's part of PTF is in Denmark. You should be set.
FSociety3812.50 wakeofdeath70.50 |
08-31-2016, 03:40 PM | #88 | |
Rep 891
I am allways sceptical in sending my ecu if the transport company losses it or gets damaged in transport I would go crazy. |
bootmod3, dyno, stage 1 |
