      02-17-2015, 07:02 PM   #67
Classic_Blunders
Classic_Blunders's Avatar
Drives: 135i N55 BSM
Originally Posted by RVAN View Post
The videos posted are extremely accurate. No drone at steady steady state I would guess due to the stock resonator. Under load though, it sound glorious. I still have the stock dp so no turbo whistle, but other than that the videos posted.
This video is an external mic, but it's what my car sounds like.
I paid just under $100, but if you have access to a welder you could do this for dirt cheap.
Thanks for info. I want to diy this but for $100 bucks and not havibg lots of free time lately almost no brainer to pay the cash. Did they repack all of the insulation? Just welded the holes in pipe? Sounds good. I'm going to do a res delete while I'm at it, thanks for sharing.
      02-17-2015, 07:10 PM   #68
RVAN
Drives: 2012 BMW E93 M3
To be honest I think this sounds best with the stock resonator, downpipe and this mod.
This muffler is actually louder than the pe muffler. The pe exhaust comes with the resonator with a straight pipe. This with resonator delete would drone a lot.
      02-18-2015, 07:45 AM   #69
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
I had the same mod done to mine. Ran it with the stock downpipe at first and it was nice. I installed a 4" catless down pipe and it was glorious! I just had my exhaust redone by the same guy. He built me a custom 3" stainless axleback with anti-drone chamber (like the afe) and dual 89mm tips. Deeper sound, less drone, and has a smoother, less raspy sound with the catless downpipe. (Plus it was free!)
2014 M5 6MT
Matticus913474.50
      04-20-2015, 12:06 PM   #70
CrimsonXV
27
Drives: 435i 6mt, 325Ci 5mt, 87' K100
What diameter pipe fit in the resonator?
Originally Posted by 805beemer View Post
So I had the muffler shop slide in a piece of ~3" long pipe to block off the holes inside the resonator and weld the muffler back together. It sounds a little bit louder, but not much. Only cost me $50 plus the header wrap so I'm not complaining. I'm surprised it's not louder since I have n55 mids although I do have stock dp's. Never heard the pe in person but from YouTube it sounds louder than my setup. I'll try and get some vids up soon. In hindsight I would have wrapped both pipes and I still might.
Also the pipe wasn't welded in place yet in the pic.
Same question, what diameter pipe did you use to fabricate onto the existing piping? Also do you have any videos of how it sounds?
      05-06-2015, 03:16 AM   #71
jose325i
Drives: 2008 135i
Just as an update, I did downpipes and resonator delete after this mod and they made a huge difference (especially the resonator delete!). I still have my secondary cats intact. I like the sound now. Pretty aggressive, with just a little drone. I'm probably going to end up redoing this (or upgrading to the real thing) at some point because I hear the bands inside vibrating once in a while. They must have worked themselves loose over time.
For anyone doing this mod, I recommend to have the holes welded shut instead to avoid the clamps from loosening and rattling down the line.
OEM ZCP wheels (4 fronts). BMW Performance Grills. Blackline Taillights. JB4. DCI. Downpipes. GP Thunder 5000K. LED turn signal and brake bulbs.
      07-30-2015, 09:52 AM   #72
VroomVroomRaceCar
Drives: 2011 135i Le Mans Blue
Hey Guys,
I just did this mod on my otherwise stock 2011 135 N55. This is the best Bang for your Buck mod you can do. Period. Pure genius. Heat wrap covered both sets of holes and kept all the fiberglass in.
Impressions:
At start up and idle the car is only barely louder, however in the “fun RPM” range I think it’s about 10-20% louder and sounds deeper and more aggressive. It also accents the pops and burbles at low speed that the muffler tends to…. Muffle. Very Very happy with the results, fantastic for the price.
On a stock car this is totally worth it. Next step is the downpipe and JB4.
Procedure and tips:
The hardest part of the whole deal was getting the Muffler off. Those rubber hangers are terrible. I soaked them in WD40 and used a flathead and needle nose to work them out. If I were doing this again I would buy the 3 Hangers new for 30 bucks and just cut them off.
Once the muffler is off I had to cut both the top and the bottom with an angle grinder to get to the big holes and small holes. I wanted to do it all from the top but it was impossible to get both. You only need to cut the thin strip down the middle to access the holes, only 2-3 inches wide.
Wrapping was easy enough, I used:
DEI 010121 Black 2" Exhaust Wrap - 15' and
Breeze Power-Seal Stainless Steel Hose Clamp, Worm-Drive, SAE Size 36, 1-13/16" to 2-3/4" Diameter Range, 1/2" Bandwidth (Pack of 10)
from amazon and secured each side with 3 ring clamps. I used these from amazon too and they fit great, covering everything well.
I had access to a welder so that part was free (minus the beer and pizza) but a nice grind afterwards made it super easy. Reattaching was a breeze, again thanks to WD40.
Thank you all so much for the Idea and pictures, making this a great DIY Mod.
      08-01-2015, 11:53 PM   #73
mike082802
Drives: 2010 135
so i finally started this project today after i picked up a used muffler from a local forum member. cut open around 4"x9" slit in the top of the muffler. how did you guys get the exhaust tape around? i dont know if i have fat hands but i had no screwdriver at the time and was running late for dinner with the wife so i just stopped. i only plan to wrap the pipe with the 2 big holes as i am n54 with atless dp's and n54 mids so i dont want it to drone or too loud.
      08-09-2015, 05:20 PM   #74
drewster99
43
Drives: 1 SERIES
I just used a long screw driver to push the wrap around the pipes. This was the most annoying part of the whole thing to me. Also getting the clamps on was a pain too.
Maybe I'm crazy or I screwed something up but I just did this and don't notice much of a difference at all. I have an n54 with no other exhaust mods besides the golf-tee mod.
      08-10-2015, 08:33 AM   #75
MDMA 135i
42
Drives: 135i N54
I wrap both pipes with thermal wrap and tiny inox and all that fixed with clamps and i don't notice much difference on my n54+golf tea mod also... but next week i remove sedondary cats and now sound is perversion especially above 3000rmp, while deacleration you can hear pops and gurgles from exhaust too ) sorry on my bad englih
      02-18-2016, 02:05 PM   #76
TwinTurboXI
Drives: 2011 135i
Just wanted to bump this thread as i'm considering purchasing an exhaust soon. Is everyone still happy with this mod?
      02-25-2016, 11:17 AM   #77
e92days
Drives: E92 335i
I would try it. I'm going to this week on my 335i. I see the price being completely worth it. I'll let you know how it goes!
      03-21-2016, 03:57 AM   #78
Tricki
Tricki's Avatar
Australia
215
Drives: BMW M2 Comp
Doing this mod... 3 large holes??? Thought there was only one...
      03-27-2016, 08:41 AM   #79
Converted1
Wolfsburg to Munich
Converted1's Avatar
75
Drives: 2009 135i Convertible M-Sport
Didn't do this mod but installed my PE yesterday.
Tip: If you want to get the hangers on and off as easily as possible and not have your exhaust smoke or smell, soak them with Windex. The come off easy and practically jump back on.
      04-06-2016, 10:54 PM   #80
RVAN
I'm still very happy. Added the ppk for the burbles and made this video of how it sits now.
DP, PE mod and ppk.
[u2b]https://www.youtube.com/watch?v=wnAQCyi_H9w[/u2b]
      04-06-2016, 10:56 PM   #81
RVAN
DP, PE mod and ppk.
6ixSpd6015.50
      09-23-2016, 08:06 PM   #82
muddtt
Drives: BMW 135i (E88)
Do you think the inside of the exhaust would be to hot to put some red loctite on the worm gear so they don't back out?
      09-30-2016, 06:15 PM   #83
muddtt
Tricki215.00
      10-17-2016, 05:28 PM   #84
muddtt
Added N55 midpipes.
      03-16-2017, 12:38 PM   #85
dandandan
102
Drives: 2012 135i N55 DCT
Currently working on the PE MOD. I was able to find a spare muffler to experiment with. Three large holes wrapped, and the internal perforated Y section welded as this is an N54 exhaust.
N55, PPK, with PE Y pipe. My car came with the genuine Y pipe and stock exhaust. The previous owner must have parted out the muffler section.
I added the ExhaustMeister wireless flap controller for a golf T on demand solution. Programmed into the garage door 2 + 3 buttons. This helps with the drone at specific highway speeds.
Should be done in early April (out of town).
      03-17-2017, 02:02 PM   #86
cam36
Drives: 2012 Wrangler
Wow! Definitely impressed with this mod– I'll be doing this once the weather warms up. I plan on doing a catless DP in the future– will it be obnoxiously loud with the DP + this mod?
      03-23-2017, 02:17 PM   #87
Dthltm
77
Drives: 135i / Deep Sea Blue on Taupe
I dont own any tools so does someone wanna knock this out for me in the Dallas/Fort Worth area for an agreed upon sum of money?!
      03-23-2017, 03:33 PM   #88
muddtt
If anyone wants one I have mine for sale in the Norcal area.
