Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Rear right arch gap less than rear left?
      09-23-2014, 02:58 AM   #1
Calum95
Calum95's Avatar
Drives: E92 325i N53
Unhappy Rear right arch gap less than rear left?
Hi guys,
I've recently noticed that my car is lower on the drivers side rear than the left. Has anyone seen this before and know what is causing it? All I can think of is my exhaust isn't stock and looks lighter than the stock one, would this cause the left to sit higher?
Cheers, Cal
      09-23-2014, 03:02 AM   #2
col2611
Drives: E93 335i M-Sport
This pops up quite often. I think it's something to do with the way the car is balanced for where the driver is sat. Don't quote me on that, a quick search should find one of the old threads about it
      09-23-2014, 05:17 AM   #3
Calum95
Calum95's Avatar
I thought about that too but surely it would be higher on the drivers side to accommodate the weight of the driver? I tried doing a search but its hard to find what you're looking for on the search tool on this forum! Thanks
      09-23-2014, 05:28 AM   #4
old grey steve
old grey steve's Avatar
283
Drives: MK 7.5 Golf R
Common as I'm afraid the tolerance is between 6mm and 13mm from memory
      09-23-2014, 05:47 AM   #5
hey joe
Drives: e92 330d
Calum - the consensus of opinion on this forum is that the cars are built with a bias assuming a German businessman is driving Left Hand Drive. And also with this in mind, BMW have put several of the more weighty bits (incl. the battery) on the right.
That bias (and the heavy kit on the right) is not "dialled out" on cars for the Right Hand Drive markets and thus our cars sit right hand side low. Several members on here have levelled their cars using adjustable suspensions etc.
Hope that helps ...
      09-23-2014, 05:47 AM   #6
col2611
I find it's easier to use google to search for results on this website only
      09-23-2014, 06:26 AM   #7
Calum95
Calum95's Avatar
Thanks for all your responses, makes more sense now! I guess i'll just have to live with it!
      09-23-2014, 09:26 AM   #8
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Just in case anyone doesn't know how to do that:
"stuff you're searching for site:e90post.com" (without the quotes)
(Without the (without the quotes) in brackets)
      09-23-2014, 11:06 AM   #9
marknjayne
Drives: 335d
mine did till i fitted coilovers
arch gap, e92, springs, susspension
