      01-14-2014, 05:16 PM   #23
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Originally Posted by Ian///M View Post
BMW Dealer 'blacklisted' my warranty because I had a magnetic sump plug. Idiots!
That is so idiotic!
      01-14-2014, 06:09 PM   #24
___whoosh___
14
Drives: 2010 135i
Originally Posted by Dackelone View Post
Actually I have not installed it yet in my 135i. I will probably change the oil soon and install it. Waiting for a nice warm day to drive the car from its winter sleeping mode.
I just installed the Dimple magnet in my e39. So, since thats my DD and racking up the kms (now over 332K kms) I will be giving it a good test.
These Dimple magnets are MUCH stronger than the UUC one(s). Also on my UUC plug the paint is starting to flake off and it looks not so nice. But the main reason, is that these Dimple magnets are so much stronger. I'd say easily ten times stronger than the UUC plug. When you put the drain plug(Dimple) on a metal surface you really have to struggle to pull it off! With the UUC its not as strong. You just get a soft "click".
I saw a picture of a small sledge hammer being held by the Dimple magnet. It is THAT strong.
I will be sure to update this thread with some pics soon. Here are some from Dimple's website...
www.drainplugmagnets.com
Attachment 964271
Attachment 964272
Attachment 964273
I second the Dimple plugs
bought oil drain and rear drain magnetic plugs from Bavarian Autosport
      01-14-2014, 06:33 PM   #25
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Rear drain for the manual transmission(I think you mean right?) Because... our diff's don't have a drain plug, only a fill plug.
      01-15-2014, 12:08 AM   #26
litebulb
litebulb's Avatar
68
Drives: '09 E88 135i M-Sport/6MT/SGM
Sorry is M12X1.5x18 the correct size? Thanks
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
      01-15-2014, 03:11 AM   #27
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
I've had some bad experiences with the ECS sump plugs so I'll be sticking with OEM.
      01-15-2014, 09:04 AM   #28
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
Just ordered one of these. Gonna try it out.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
      01-15-2014, 11:41 AM   #29
New21er
Drives: 2011 135i
What is the correct size for our cars??
      01-15-2014, 04:14 PM   #30
Freon
Drives: 2009 135i
N54, N55 is M12x1.5x18
THE SS M12X1.5X18, BMW PLUG DESCRIBED ABOVE FITS=
Fits BMW : 128i Convertible / 128i Coupe / 135i Convertible / 135i Coupe / 318i / 318i Convertible / 318is / 318ti / 320/6 / 320i / 323Ci / 323Ci Convertible / 323i / 323i Convertible / 323i wagon / 323is / 325ci / 325ci Convertible / 325e / 325es / 325i / 325i Convertible / 325i wagon / 325is / 325ix / 325xi / 325xi wagon / 328Ci / 328i / 328i Convertible / 328i Coupe / 328i xDrive Coupe / 328is / 328Xi Coupe / 330Ci / 330Ci Convertible / 330i / 330xi / 335i Convertible / 335i Coupe / 335i xDrive Coupe / 335is Convertible / 335is Coupe / 335Xi Coupe / 524td / 525i / 525i Wagon / 525Xi / 528e / 528i / 528i Wagon / 528i xDrive / 528Xi / 530i / 530i Wagon / 530Xi / 530Xi Wagon / 533i / 535i / 535i xDrive / 535i xDrive Wagon / 535is / 535Xi / 535Xi Wagon / 540i / 540i Wagon / 630csi / 633csi / 635csi / 733i / 735i / 735iL / 740i / 740iL / 745i / 750iL / 840i/Ci / 850i/Ci/Csi / M3 / M3 Convertible / M3 Coupe / M5 / M6 / M6 Convertible / X5 3.0si / X5 4.8i / X5 M / X5 xDrive30i / X5 xDrive35d / X5 xDrive48i / X6 35i / X6 50i / X6 M / X6 xDrive35i / X6 xDrive50i /Z3 2.5/ Z4 sDrive30i / Z4 sDrive35i / Z4 sDrive35is
ALL 6 CYL. BMW'S INCLUDING THE DIESEL
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
      01-15-2014, 09:43 PM   #31
litebulb
litebulb's Avatar
68
Thanks
      01-22-2014, 12:04 PM   #32
Freon
Drives: 2009 135i
Just got my Dimple magnet in, was due for an oil change anyway, good timing. Price is a bit ridiculous (just shy of $40 USD shipped!), but it is a nice product. Magnet is very strong. They included a nice thread gauge and ruler tool and a total of three drain plug gaskets, which is nice.
      02-11-2014, 11:44 PM   #33
litebulb
litebulb's Avatar
68
Hi, is there any point for a magnetic plug for the trans or diff? Thanks
      02-12-2014, 04:00 AM   #34
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
Yes, it makes sense for those too. But... our diff does not have a drain plug. So getting a magnet for the fill hole would be pointless. For the tranny, it makes sense since we have a drain and fill hole. You only need the magnet on the bottom (drain)hole/plug.
      02-12-2014, 08:13 AM   #35
brusk
brusk's Avatar
33
Drives: 2008 135i Coupe
Some OEM diffs have a magnet glued to the bottom of the case or diff cover. Does BMW not do this?
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
      02-12-2014, 10:54 AM   #36
litebulb
litebulb's Avatar
68
Thank you so much for the detailed reply!
      02-12-2014, 03:45 PM   #37
Dackelone
European Editor
Dackelone's Avatar
Germany
10624
Drives: N54 e82
I doubt they do. When I was using a flexible hose to suck out all the old fluid in my diff(thru the fill hole/plug) I did not feel anything with said "hose".
I know BMW does use magnets in their automatic transmission pans/sumps. They put a magnet in each corning of the pan. And when I changed my tranny fluid on my e39... there was A LOT of metallic particles(fur) on those magnets! I cleaned them off and put them back in position.
I think for the engine oil sump... these magnetic drain plugs make so much sense! You won't believe on how much metallic crap is floating around in your oil!! Even with me changing my oil(and filter) like FIVE times by the time my engine had 15K miles on it(!), I still was shocked on how much metal the UUC magnet picked up.
The new magnets from dimple(drainplugmagnets.com) has an even stronger magnetic field and they look to be better made. I would really recommend them.
Dack
      02-17-2014, 10:29 PM   #38
romak47
romak47's Avatar
Drives: like a bat out of hell
looking to get a differential plug magnet .. but since its a fill only and on the top side for our bmw's.. is it worth it?
id assume oil would splash up onto that fill hole in the differential, and metal bits would get attracted by the magnet.
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
      02-17-2014, 10:58 PM   #39
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Don't know if it's worth it but I got one from Gold Plug while I was getting the one for the sump. Thought it can't hurt.
      03-01-2014, 02:18 AM   #40
SfValley335i
Afghanistan
165
Drives: Current:135i Sold:335i sedan
Arrow Dimple Magnetic drain plugs - Review Soon
After reading a post of @Dackelone 's, I decided to purchase some dimple plugs. Below are some pictures of what I received, thread/bolt measuring tool and personal thank you from Dimple. (Motor and Transmission plugs ordered)
Price was about $75 shipped for two plugs, it is pricey but I dont mind supporting Made in U.S.A. products.
The plugs look to be well made and a quality product. Wish I could say the same about the ECS tuning plug I bought and never opened...
I'll update this thread around July/Aug to see if its captured anything.
      03-01-2014, 02:44 PM   #41
johngrossi
johngrossi's Avatar
9
Drives: 2011 135i e82
I have heard great things about the dimple plugs. From what I read the magnet is far superior to other plugs on the market.
Looking forward to the review!
PE exhaust, tints...more to come
Dackelone10623.50
      03-01-2014, 03:29 PM   #42
litebulb
litebulb's Avatar
68
I picked one up as well after reading Dackelone thread. Great customer service, the shipment was delayed and they refunded me the shipping cost as an apology. Can you tell me what the measurement was for the transmission plug? Thanks
      03-01-2014, 03:53 PM   #43
vivanapoli806
Drives: 2012 535i Xdrive Msport
I picked up the uuc one after I read dackels thread awhile ago. Will be using that when I change my oil this year then will switch to these ones. Please post part numbers if u can for the 2 u got
      03-01-2014, 06:32 PM   #44
SfValley335i
Afghanistan
165
These are the two plug sizes I bought:
Motor: M12 x 1.5 x 18
Manual Transmission: M18 x 1.5 x 12
