BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      03-13-2024, 02:58 PM   #3015
Assimilator1
Assimilator1's Avatar
594
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Technical discussions in this thread are nothing new, and are relevant.
Originally Posted by PaulGros View Post
I have the complete data analysis from the OEM bearings that was rerun 02.02.2024 when I asked if the OE drawing could be checked. The following was rechecked:
Contact pressure
Bearing Hoop stress
Housing Hoop stress
Clearances
No anomalies were seen when compared to the original data. Unfortunately I can't share this data.
It's interesting that your list also contains OEM WPC treated bearings. My understanding of the process is it has a negligible impact on material dimensions, yet they are showing no wear even though clearance in theory is unchanged?
So just to confirm, the simulation was re-run with the original OEM bearings and the program confirmed the spec'd 0.046mm clearance is ok?
Re WPC bearings, I was wondering about that too.
Correct me if I'm wrong (memory's rusty here), but aren't WPC treated bearings ones which have had some sort of physical surface treatment (which minisculey increases the clearance, to no significant affect AFAIK) and also has some sort of coating over the bearing?
      03-16-2024, 05:59 AM   #3016
PaulGros
71
Drives: BMW E46
Sorry I missed this post.
Yes, the data from the OEM parts was rerun with the latest software version with no issues found.
As far as I know, WPC is a form of micro bead blasting with no coating applied
      03-16-2024, 03:54 PM   #3017
Assimilator1
594
2008 BMW M3  [0.00]
Re WPC, yes that's it, I remember now you mention it!
Re OEM parts, are you allowed to tell us what clearance the simulation said it should be?
      03-19-2024, 06:07 PM   #3018
Assimilator1
594
2008 BMW M3  [0.00]
And this is what rod bearings should look like even after 130k miles! Jump to 2:50s to go directly to the bearing shots (bloody link goes to the beginning, even though 170s is in the link!!).
Thanks to Matt@Evolve for publishing this btw.
PS The fact that it's not a high revving engine is irrelevant (IIRC it's redline is ~7k).
      03-20-2024, 03:48 AM   #3019
Helmsman
Helmsman's Avatar
Sweden
4470
Drives: 2011 AW E90 M3 ZCP
I didn't look all though, maybe they said, but anyone who knows what clearance the S55 go with?
      03-20-2024, 04:41 AM   #3020
CSBM5
CSBM5's Avatar
2723
Drives: 2019 M2 Comp, 2011 M3, etc
S55 stock redline is 7600 rpms...at least one day in time would have been considered pretty high revving!
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      03-20-2024, 04:57 PM   #3021
Assimilator1
594
2008 BMW M3  [0.00]
Ah ok, that is a bit higher than I thought, and yes that is still pretty high I'd say . As I recall, the later M3/4s have a lower redline, perhaps that's where I got 7k from.
      03-22-2024, 12:21 AM   #3022
rajchalus
Drives: 2024 992 GTS 2012 535xi 2008
2008 e93 m3 : 50,070 miles
Done at MRF🤩
      03-22-2024, 07:11 PM   #3023
Assimilator1
594
2008 BMW M3  [0.00]
Done at MRF🤩
Pics of the old bearings?
      04-11-2024, 09:44 AM   #3024
Sammy82
Sammy82's Avatar
Germany
92
Drives: BMW E92 M3
Here are my previously changed oem rod bearings:
44k km (~27k mls)
Summarized 3 days of trackuse
2 trackdays with BMW M, some laps on public driving (Hockenheim GP, Nürburgring GP, Nordschleife)
Oil was changed 5000-6000 km (3100-3800 mls)
The first rod bearings were replaced ~69k km (43k mls).
      04-11-2024, 09:59 PM   #3025
LMBE92
LMBE92's Avatar
64
Drives: 2010 BMW M3
2010 E92 M3
Original bearings afaik
Replaced with BE Bearings & ARP Bolts by EAS in Anaheim
140,750 miles at the time of replacement
      04-11-2024, 10:28 PM   #3026
M3SQRD
M3SQRD's Avatar
2167
Redline has not changed on the s55 with 425 hp, 444 hp, 454 hp or 493 hp variants.
      04-15-2024, 02:55 PM   #3027
Assimilator1
594
2008 BMW M3  [0.00]
44k km (~27k mls)
I don't understand you, don't you mean the 2nd rod bearings?
Originally Posted by LMBE92 View Post
2010 E92 M3
Considering the mileage, and being the earlier type, they're not too terrible!
LMBE9263.50
      04-22-2024, 09:06 PM   #3028
januza
60
Drives: X5 45e
So I just bought a 2009 E93 M3... Primairly city driven by an older lady.. 53.000km.. Should I start by changing the rod bearings now or should I wait.. Cost isnt a big issue.. thanks guys
      04-23-2024, 05:44 AM   #3029
Helmsman
Helmsman's Avatar
Sweden
4470
Always tricky to know. Could hold up for another 200k km or blow tomorrow. But at 53k km I personally would wait (although replaced at 60k km myself, which turned out to be early). Ps. 2009 I believe use the earlier 088/089 shells which proven to wear more.
januza59.50
      04-23-2024, 08:28 AM   #3030
M3SQRD
M3SQRD's Avatar
2167
I’ve changed mine at 25k miles for my ‘09 and 20k miles on my ‘12. With engines failing with < 10k miles, I wanted the oem bearings replaced asap. Went with BE V1 RB with BE ARP 2000 bolts.
januza59.50
      04-23-2024, 09:48 AM   #3031
Helmsman
Helmsman's Avatar
Sweden
4470
Ps. Sorry for being obvious but while planning possible RB replacement I'd change the oil, cut up the filter and carefully check its absolutely clean from any shavings. And of course...always carefull warm up of engine/oil before stomping....
Most S65s have proven to live along life treated correctly. Key reason to replace the shells really is when buying used and without real knowledge how its has been driven and maintained. Quite a few are stated to have been driven by old ladies...
      04-23-2024, 06:23 PM   #3032
januza
60
Drives: X5 45e
Hahaha old ladies. Well the history and service history shows it’s been pampered. Besides in Shanghai or China general you can’t push the car. We have street cams every two hundred meters. For peace of mind I’ll just replace the rod bearings.
      04-24-2024, 08:28 AM   #3033
Sammy82
Sammy82's Avatar
Germany
92
Drives: BMW E92 M3
Yes, these are the 2nd rod bearings
The 1st ones were replaced @69k km
Now the 2nd ones @114k km
      04-24-2024, 04:55 PM   #3034
Assimilator1
594
2008 BMW M3  [0.00]
2009 model? Yea I'd definitely replace the bearings, even though it's low mileage, most of those earlier bearings pulled come out heavily or severely worn!
m3post
