BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      06-18-2019, 05:32 PM   #45
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
That is weird they used 2.5” resonators on 3” piping. You could change to 3” resonators but that would cost $150 if you can weld and $300 if you cannot and could make them harder to fit without risk of rubbing something.
      06-18-2019, 05:37 PM   #46
tdott
Drives: M3
Yea the 4 to 1 collector also chokes down to 2.5" before opening up to 3" for the mid section.
Compared to the stock system i don't see it being restrictive.
Dpc2u11503.00
      06-18-2019, 07:50 PM   #47
Richbot
Drives: Jerez Black E90
Using an “undersized” resonator is a common anti rasp strategy
      06-18-2019, 08:29 PM   #48
pbonsalb
Interesting. But isn’t flow limited to the that of the smallest point?
      06-18-2019, 09:37 PM   #49
Richbot
Further back you go, less pipe diameter you need for the same flow rate because the gas is cooler
But I wouldn’t suggest they did the testing like evolve did to actually find the best placement and size seems like “resonators go here on this car so that’s where they are on our pipe”
      06-19-2019, 08:51 AM   #50
tdott
Drives: M3
I remember someone saying the gaskets these type of headers come with are usually not good and to use oem gaskets.
The OEM gasket is slightly smaller than the ports on the headers, assuming the exhaust ports on the head are the same size as the gaskets i don't see this being a problem so I'll probably still use the oem gaskets if that is the case when i remove the headers:
This is what the Becker gasket looks like:
      06-19-2019, 11:25 AM   #51
pbonsalb
The OEM gasket is bigger than the head exhaust port. The port is the limiting factor. It should not matter whether the gasket is a little smaller than the header opening.
tdott3950.00
      06-19-2019, 06:24 PM   #52
darkbmw
Drives: slow m3
are they ceramic coated or just polished, i would spend the money on ceramic, cause u lose most of the heat shields
      06-20-2019, 01:42 AM   #53
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
the hardware that comes with these kind of exhausts are terrible.
judging by the photo that you have taken the OEM gasket is just fine. Even if its a mm undersized it shouldn't be a big problem. had the same kind of experience back when the e46 m3 headers on ebay were a hot item.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      06-20-2019, 08:02 AM   #54
tdott
Drives: M3
Stuck at 70%, almost there, thank you for all that have contributed so far.
The plan is to hopefully dyno this weekend and start the install right after that.
Pretty sure they are just polished
I plan to try to reuse most of the heat sheilds, even if it involves some cutting, but we'll see once I get to the install.
I agree, I plan to use the OEM gaskets. From pictures I have seen, the exhaust ports are smaller than the gaskets so no big deal.
      06-20-2019, 03:26 PM   #55
pbonsalb
Exchanges like that are one reason I have no interest in Facebook. Unfortunately, chat seems to be the way of the future and forums where people generally take the time to think about what they write before they write it are losing popularity.
      06-20-2019, 04:13 PM   #56
8500RPM
152
Drives: 2012 M3 CP
Don't worry about those lames. They would be the same ones complainingif you did dyno before and after and with held the info lol
tdott3950.00
      06-20-2019, 05:31 PM   #57
wfdeacon88
Drives: E90 M3
I would just get it dynoed with the funds already collected. I'm tired if waiting
330iToy71.00
      06-20-2019, 11:05 PM   #58
tdott
Drives: M3
Thank you Sam.
We are at 80% , Dyno is planned for Saturday.
8500RPM152.00
      06-21-2019, 02:46 PM   #59
tdott
Drives: M3
I couldn't wait any longer, I want to install the headers, so I went and got the before dyno today.
Thank you to everyone that contributed. All the info I provide is a direct result of the generosity of the community.
8500RPM SAMM3Y amrazM burnrbr Krypptic 6ixSpd and all my M3Post WhatApp Chat Buddies.
Results are not great (peak number wise), but it is 93F Heat & 40% Humidity
STD: 344rwhp 251rwtq
SAE: 336rwhp 245rwtq
jdamore432.50
DrFerry6730.00
      06-21-2019, 03:07 PM   #60
tdott
Drives: M3
For comparison, N/A S65 cars on this dyno have made 333whp and 369whp, no idea what mods they had or what temps were or if it was SAE or STD.
ESS625 kit with primary cat delete made 527whp
      06-21-2019, 05:14 PM   #61
8500RPM
152
Drives: 2012 M3 CP
Tire shredding torque lol, I love our cars. You planning on getting back on the dyno before Monday with the headers?
      06-21-2019, 05:48 PM   #62
yidgyi
///M
yidgyi's Avatar
Drives: 2013 E92 M3 ZCP
For what its worth being an amazon / ebay setup, I have the becker full catless exhaust system (which is a steal at $950 when I bought it) and after 2-3 years its holding up fine. Only downside I had was the catback had to be extended an inch so the elbow wouldn't rest on the diff. Also, the gaskets it came with are trash, I got misfires in almost all cylinders.
Tempted to possibly buy the headers if the dyno results are promising.
Follow me on IG: dre.pt
      06-21-2019, 08:11 PM   #63
Dave07997S
Drives: 2020 Ford Mustang GT
tdott, what octane are you running?
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk
2007 Porsche 997C2S Speed Yellow/Blk sport seats
2004 BMW M3 Imola/Blk
      06-21-2019, 08:13 PM   #64
Dave07997S
never mind double post
      06-21-2019, 08:16 PM   #65
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
[img]https://i.postimg.cc/Bv6qnMXj/Before-STD-4.png[/img]
[img]https://i.postimg.cc/LsbmYL1N/Before-SAE-4.png[/img]
[img]https://i.postimg.cc/nhTFx6c8/DynoPic.jpg[/img]
Nice and linear, numbers are about what I'd expect....
9ers
      06-22-2019, 08:50 AM   #66
Gossypiboma
Drives: 13' M3 6MT 18' M3 CS
Those numbers seem odd, thats what a stock M3 puts down. Of course dyno to dyno comparisons aren't equal, but my car with your same mods made 380whp and 275tq as do most M3's with test pipes and a tune.
If you install the headers and then happen to make 380ish whp its going to look like the headers and x-pipe alone added 40 more hp. When in fact your "baseline" numbers are off for some reason.
m3post
