BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      11-04-2022, 01:49 AM   #89
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
Vacuum lines done and routed and zip tied. Mounted the solenoid to an existing ground post.
2011.5 E90 M3 DCT ZCP Slicktop
chicagob5256.50
      11-04-2022, 02:20 AM   #90
Bimmer Barney
1250
Wiring in the engine bay done.
On the passenger side under the cabin filter area there is a gray rubber grommet that you can move all the way towards the center of the car, allowing enough room to push the white plug into the engine bay from behind the glove box/fuse. It's tricky, and blind, but after a couple minutes, you'll get it.
I notched (the one part of this install that isn't very clean!) under the cowl and ran the wire along the back of the engine bay and zip tied it neatly until I got to the solenoid plug.
Next up is the fuse panel connection and ground.
chicagob5256.50
      11-04-2022, 05:27 AM   #91
Bimmer Barney
1250
All buttoned up:
      11-04-2022, 11:32 AM   #92
Bimmer Barney
1250
Some vids with Valves open. Very noticeable change with anything more than just light throttle input. Some drone between 2500-3000. Very happy with the aggressive sound and the option to keep it mellow. Thanks for following along the install. Hope all the photos and videos help others with the install or when considering the purchase. I'm a happy customer!
https://youtube.com/shorts/I3Lq5Flxy4k?feature=share
Appreciate 3
ETM383.50
L4ces337.00
      11-04-2022, 12:53 PM   #93
ETM3
84
Drives: 2011 Jerez Black E90 M3
Finally the video we've all been waiting for! Sounds amazing, any chance of a flyby video?
      11-04-2022, 01:39 PM   #94
Bimmer Barney
1250
I'll see if I can get one this weekend and post it to my YouTube channel
      11-04-2022, 01:53 PM   #95
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
What's your X-pipe setup?
Can confirm that it sounds very throaty and snappy when valves are open. For the money, it's a great valved unit
2009 BMW 335i 6MT
*big single (eventually)*
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      11-04-2022, 02:45 PM   #96
Bimmer Barney
1250
I list OEM midpipe in all of the video descriptions 👍🏼
Soden82478.50
      11-04-2022, 02:53 PM   #97
UBERV8
UBERV8's Avatar
Drives: '13 MW E92 M3
My shop looks like they hooked it up the same. Hopefully picking up later this afternoon. I'll post some clips with mine and test pipes on my IG @Cali_em3
      11-04-2022, 04:08 PM   #98
aBMWfan
Drives: 08' M3/'15 M4/ '06 M3/ '09 M3/
I will be running a sale on both Version exhausts this month. Contact me for details
My titanium unit should be ready as well for more sound clips!
      11-04-2022, 09:54 PM   #99
Bimmer Barney
1250
https://youtube.com/shorts/cYGheNTTNK4?feature=share
Appreciate 3
Davisca4552207.50
Ajolives922.00
L4ces337.00
      11-05-2022, 09:45 AM   #100
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2019 Audi SQ5  [0.00]
2008 BMW M3  [0.00]
Think mine came out of the box valves open. If not, this is gonna get rowdy. Done with install and waiting on my vacuum pump from Amazon
Update: The valves were closed; she be rowdy. Sounds glorious.
https://youtube.com/shorts/PwUzfBn7U3A?feature=share
Soden82478.50
      11-05-2022, 09:53 AM   #101
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2008 BMW M3  [0.00]
That sounds really nice.
      11-05-2022, 04:24 PM   #102
chicagob5
Drives: E90 ZCP
Got my vacuum control box in and decided to start on wiring that up. I have a V1 hardwired using the V1 hardwire kit, so I had another RJ11 accessory plug available on that harness. I decided to create a custom cable for the vacuum box, removing the cigarette plug and connecting it to a mirror tap so I can just plug it into the V1 accessory slot.
Long story short, the box works great. You can pair it to homelink as well. Took a quick video to show it working: https://youtube.com/shorts/AmrVqSkw-c8
      11-06-2022, 10:37 AM   #103
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2008 BMW M3  [0.00]
I finished the install but it's messy because I'm going to have to redo everything anyways. My jack slipped off the rear subframe while raising her up and cracked the plastic trunk floor. Luckily wheels were still touching the ground.
Either way, i mounted the controller to the amp tables on the left of the trunk. I grounded that and the pump to the chassis near there. I tapped ignition from the rear tail light bundle (gray+yellow). I may find a better source on second install. The solenoid and pump are screwed into the plastic tub but I may glue them to my new one.
The vacuum hoses underneath were fed through a brand new hole I made. I followed the exterior lines of the tub and drilled holes in the ribs for the zip ties. Next go around I'm probably going to feed the hose through the holes. Either practice gives you plenty of room from any pinching heat shields.
Pump I used:
APDTY 015325-Kit 12V Electric Vacuum Pump & Wiring Harness Pigtail -HVAC Cruise Control 4WD https://a.co/d/eHsBx1t
Appreciate 3
      11-06-2022, 12:51 PM   #104
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Did anyone else need to tighten the actuator arms on the valves? The actuator feels tight as it's hard to turn them by hand.
My valves are closed currently but on start up especially I can hear the valves fluttering.
2009 BMW 335i 6MT
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      11-06-2022, 03:56 PM   #105
Bimmer Barney
1250
Mine were tight upon checking and I don't have any fluttering noise.
Soden82478.50
      11-06-2022, 03:58 PM   #106
Bimmer Barney
1250
Can you list the pump you used? For future reference and for others.
Looks good. Glad to hear your jack slipping didn't result in a worse situation!
      11-06-2022, 04:47 PM   #107
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2008 BMW M3  [0.00]
Thanks, same here. Added the pump I used based off an old thread I found. Think Redd is still around, appreciate the post.
      11-06-2022, 05:33 PM   #108
Bimmer Barney
1250
Looks like the autozone Dorman pump. Is it?
Ajolives922.00
      11-06-2022, 07:21 PM   #109
Bimmer Barney
1250
Brushed Stainless Steel Single Wall Tips
Appreciate 4
chicagob5256.50
UBERV8528.00
Ajolives922.00
pjk38088.00
      11-06-2022, 07:48 PM   #110
chicagob5
Drives: E90 ZCP
Damn yea, that does look better. Alrighty, time to shoot off another email to Turner..
m3post
