11-06-2023, 06:21 PM | #23 |
1439
Rep 1,614
Sintered backing that will deform much more easily over time. Dinan has an example of ACL bearings after 30000 miles which could not retain shape and -- according to Steve Dinan -- literally fell out of the rod big end when the cap was removed. Also, the bronze barrier between sintered backing and upper layers tends to bake and cause the upper layers to delaminate over time.
DrFerry6730.00 |
11-07-2023, 01:26 AM | #24 | |
Rep 7,113
Ps. Please answer with "quote"... Thx |
11-07-2023, 01:55 AM | #25 |
Rep 1,106
Drives: 2009 E92 M3 Dakar Yellow II
Helmsman there is a white paper published regarding BEs measurements and work on clearance. It lists various manufacturers claimed clearance vs measurements and even talks about the shape of the bearings when bolted in place if I recall correctly. It has been a few years since I saw it but I found it in a google search.
DrFerry6730.00 |
11-07-2023, 02:20 AM | #26 | |
Rep 7,113
11-09-2023, 04:44 PM | #27 | |
Rep 1,026
Drives: BMW M3 e92 08 & 330d e90 10
PS If you had 'thread notification on reply' turned back on I/we wouldn't have to quote all the time
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
11-09-2023, 04:46 PM | #28 | |
Rep 1,026
11-10-2023, 06:38 AM | #29 | |
Rep 6
Assimilator1594.00 |
11-10-2023, 09:41 AM | #30 | |
Rep 7,113
Cheers |
12-27-2023, 03:53 AM | #32 |
Engineer
51
Rep 172
12-27-2023, 11:03 AM | #33 |
Rep 7,113
12-27-2023, 04:15 PM | #34 |
1439
Rep 1,614
According to the BE Wiki page:
BE Bearings (Version-2): SP1527F Introduction: February, 2022 Not necessarily. Spec changes are occasionally made. The original V1 shells were tweaked four times to fine tune the thicknesses. The V2 shell has been tweaked once already. However, no updated measurements are available as the measuring equipment is packed away for now. |
Robocop30512.00 DrFerry6730.00 |
12-28-2023, 01:40 AM | #35 | |
Rep 7,113
12-30-2023, 07:47 AM | #36 |
Rep 1,026
Yes, that's what I saw anyway.
12-31-2023, 01:31 AM | #37 | |
1439
Rep 1,614
12-31-2023, 06:26 PM | #38 |
Rep 7,113
01-01-2024, 08:27 AM | #39 |
Rep 1,026
Helmsman (tagged, seeing as you have turned off thread notification ).
Yes it is, from their page - http://wiki.rcollins.org/core/index....-2.29:_SP1527F Bearing clearance specification. For v1 bearings :- Nominal Rod Bearing Clearance 0.0597 mm 0.00235 inch For v2 bearings :- Nominal Rod Bearing Clearance 0.0681 mm 0.00268 inch ************************* Apologies to the op for keep talking about rival bearings, but at least you're getting your thread bumped up more often!
DrFerry6730.00 |
01-01-2024, 09:56 AM | #40 | |
Rep 7,113
Ps. Nope, have not turned of notifications! |
01-01-2024, 12:17 PM | #41 |
Rep 5,554
The difference between v1 and v2 nominal clearance is 0.00033” which, although it’s now a larger clearance, is pretty small change practically speaking. However, I am curious why they released a v2 because I have BE v1 rod bearings installed.
DrFerry6730.00 |
01-01-2024, 04:54 PM | #42 |
Rep 1,026
On (I think) their main website, they describe new stronger materials being used for the v2 bearing.
M3SQRD2167.00 |
01-02-2024, 10:09 AM | #43 |
Rep 5,554
Hum…I wonder why they changed to a stronger material(s) with v2 bearings? What was wrong with v1 material(s)? Have had v1 bearings installed since 2018 and as far as I know there’s no unseen bearing issues.
01-02-2024, 10:59 AM | #44 |
Rep 3,988
This sums it up nicely.
