BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      01-02-2013, 12:38 PM   #23
DLSJ5
DLSJ5's Avatar
Drives: 2016 F82 M4 ZCP
Originally Posted by VCMpower View Post
Can someone explain what the NClass motors and their failure/lack of failure rate has to do with the S65?
Totally agree, or how anyone here without inside knowledge can actually make an accurate analogy in the first place.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP
ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ
ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ
Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH
      01-02-2013, 12:55 PM   #24
US///M3
Drives: 1973 Jensen Interceptor
With all your mods,i can tell you, your engine is on borrowed time.
      01-02-2013, 01:08 PM   #25
VCMpower
25
Drives: 2010 Dakar, 2013 Fire Orange
Really? You can tell me that? Do have any tangible evidence on what I have done or not done to prevent the inevitable? Do you know how often my oil is changed? Do you know if I have had S65's apart and seen the what wear occurs at different mileage and being FI or NA? You are aware that ALL combustion motors wear and sooner or later need re builds?
      01-02-2013, 01:32 PM   #26
passing
hey
passing's Avatar
Tanzania
56
Drives: caprice wagon
its so hard to tell by those videos what the root cause of the noise is.
overhype indeed. my motor makes such a racket that i dont even think or worry about it.
if any of us out of warranty people have a bearing issue, i for one am not waiting around for BMW to step up and fix what's wrong. i didn't buy this car just to listen for a bearing failure.
      01-02-2013, 02:29 PM   #27
Superfly_M3
Drives: 2011 M3
Well said.
On the same topic, you only live once. Why the hell would you chew your nails and worry about that 1-2% of blown motor that are possibly related to bearings. If it blows under warranty, BMW will replace it. If it blows after, then you're in for a couple of grand. Again, its not like 50% of the motors have blown up. And to add to this, no one really knows what conditions the motors were when they blew up. Like someone mentioned above, we don't know when the oil changes were done, how the person took care of the car.
Rember, most wear and tear happen during start up when the oil is cold. Whos to say that the blown engine haven't been overreved during operation with cold oil temp. There are simply too many unknown variables for anyone to make a statement that the S65 has a general problem.
      01-02-2013, 06:31 PM   #28
M3PO
M3PO's Avatar
84
Drives: '08 IB E92
Mine doesn't make any scary sounds but my used oil analysis showed very high wear metals from the bearings and extremely low additive after only 7K miles. I'll be doing another one very soon.
Also, I just drove the piss out of it (as best I could as a track noob) last weekend on the track!
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R
      01-02-2013, 06:42 PM   #29
VCMpower
25
Good plan! My is done every 5K or immediately after track sessions. Life blood
      01-02-2013, 06:52 PM   #30
guardodoc
guardodoc's Avatar
Drives: M3 e92, 1986 325e 2021 X5 40i
Bearing shells
Looks like part number of bearing shells changed
Oct 2008
01 AT-CRANKSHAFT WITH BEARING SHELLS 1 11210443639 $2,504.51
02 Bearing shell green 70,00MM(0) 4 10/2008 11217841489 ENDED
03 GUIDE-BEARING SHELL YELLOW 70,00MM(0) 1 10/2008 11217841498 ENDED
04 Bearing shell green 70,00MM(0) 4 10/2008 11217841484 ENDED
05 Guide bearing shell violet 70,00MM(0) 1 10/2008 11217841495 ENDED
      01-02-2013, 07:30 PM   #31
Vic311
Drives: 2011 e92 M3
Originally Posted by Superfly_M3 View Post
Well said.
Exactly the point..the engine makes all sort of ticking noises that are completely normal. all threads like this do is spread paranoia about something that happens so infrequently.. its not even statistically significant
      01-02-2013, 08:21 PM   #32
VCMpower
25
Not a concern at all.
Oct 2008
      01-02-2013, 09:35 PM   #33
MRSSIIM3
General
MRSSIIM3's Avatar
Drives: M4 SO
my 2013 with 1300 miles on it that i have just gotten the break in service of, does the clicking sound from the second video......now you guys are gonna tell me it has rod bearing failure? give me a break
      01-02-2013, 09:43 PM   #34
passing
hey
passing's Avatar
Tanzania
56
you might want to get that checked out..
      01-02-2013, 10:02 PM   #35
ES_TRADER
344
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Wait for it to throw a code and then take it in. Or get limp mode is best and flatbedded in.
      01-02-2013, 10:33 PM   #36
aus
Drives: Odysse
How about the blown engines that arent reported because their owners were asked or dont post on the foruns? There are by far more N55's on the road than the S65 yet there more documented cases of blown s65's.
I know of another case on bimmerfest that was reported only because BMW NA denied warranty on a blown engine and accused the good Dr of overreving his DCT causing the engine failure.
Most people sign the BMW release, get a new engine and keep quiet. The low production s65 has more catastrophic engine failures than the N54 .
Could you post a link to that case?
      01-02-2013, 10:47 PM   #37
MRSSIIM3
General
MRSSIIM3's Avatar
Drives: M4 SO
this is a joke right?
      01-02-2013, 10:58 PM   #38
ES_TRADER
344
2013 X5  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Basically when u go in and complain about noises, dealers aren't going to do shit. Your car will sit around for the whole crew to test drive and then they come back and tell u it's normal or nothing is wrong, unless a code is thrown. When u come in on a flatbed because of limp mode or just cause, that tells them you're serious. That's what I meant by it. But I doubt ur car gonna have issues that early.
      01-03-2013, 12:27 AM   #39
RenoE92M3
Drives: melbourne red e92 m3
I'm still waiting on my motor to be delivered from germany FYI.
      01-03-2013, 08:13 AM   #40
US///M3
Originally Posted by aus View Post
[/B]
http://www.bimmerfest.com/forums/sho...d.php?t=439844
"BMW has shown me that it is a classless operation...the ultimate nightmare." From the physician.
      01-03-2013, 12:27 PM   #41
VCMpower
25
A 3 year old post. Wow.
      01-03-2013, 01:56 PM   #42
US///M3
I'm sorry, you dont see those 2010 M3's much anymore.
      01-03-2013, 02:01 PM   #43
VCMpower
25
Point exactly! You do not see 3 month old 2010's anymore. Delete your browsing history.
      01-03-2013, 03:07 PM   #44
US///M3
How old are you?
m3post
