N54 Dyno Chart Compilation
07-16-2011, 01:45 PM | #133 |
Rep 596
Summary graph of 2009 135i stock, Cobb AP Stage 1 (93 oct), Cobb AP Stage 1 (93 oct) + DP + FMIC
Additional details found here: http://www.e90post.com/forums/showthread.php?t=523889 |
07-21-2011, 10:46 PM | #134 |
36
Rep 359
just got her dyno'd today!
2007 335i 44,xxx miles. BONE STOCK Max HP: 263.2 Max Torque: 296.0 Dyno Type: Dyno Dynamics *95 Degree weather* Thoughts? it seems normal, but almost a little low? tell me something is wrong so i can tell my dealer before warranty expires 8/20/11. lol 3 sheets are provided: HP + AFR, HP + TORQUE, TORQUE + PSI Here is HP + Torque: HP + AFR: Torque + PSI: Thoughts?!?!?! |
07-25-2011, 03:35 PM | #135 |
Rep 923
08-18-2011, 05:16 PM | #137 |
Rep 2,991
did this JB4 vs Cobb comparison back early April in 93 degree weather at Cobb's facility.
Mods: ETS, DCI and 93 Octane facility was impressive - nice and clean and everyone looked as if they were having a great time. friendly environment with smiling faces all around. got strapped on the dyno and away we went. 1st set of pulls were JB4 Map 1 on 14psi: average of 311whp and 350wtq 2nd set of pulls were JB4 Map 0 stock boost: average of 251whp and 290wtq 3rd set of pulls were Cobb Stage 1 on 15.5psi: average of 326whp and 385wtq sorry for the "picture" graphs but i didn't get the screen shots emailed to me - just the logs. |
08-19-2011, 02:19 AM | #138 |
Rep 488
Drives: 2008 335xi E90
Thanks for the comparisons. It seems that Cobb consistently slams down the AFR to about a constant 12 after 2900 RPM, whereas the JB4 stage 1 gradually reduces AFR starting a little later at around 3000 RPM, and whereas stock only gradually gets to 13. Isn't this the reason why Cobb fuel mileage suffers so much above 3000 RPM?
08-19-2011, 09:48 AM | #139 | |
Rep 2,991
i'll gladly lose a couple mpg's if it means that my car is running much safer A/F's. that was worth it to me and it was one of the reasons why i switched. |
08-19-2011, 06:35 PM | #141 |
Rep 2,991
on the gauge it was reading more like 14.
either way, consistent 12 A/F's at 15.5psi on the Cobb is more comfortable to me than high 13 A/F's at 14psi from JB4. p.s. i didn't try MAP2 because Terry said "MAP2 is too agressive for some cars". i wasn't about to risk it. |
10-07-2011, 02:12 PM | #147 |
Rep 67
335i E90 6MT Cobb Stg 1 Aggressive w/ exh from dp back (secondary cat deleted)
All files are 93 octane. Both "runfile" pulls are baseline numbers w/ the same exhaust but without the Cobb. The dyno equip was having issues with it's climate box which is why I posted both uncorrected and corrected.
10-07-2011, 06:16 PM | #148 |
9
Rep 338
Here are some numbers from today. Unfortunately, no graphs.
Dinan CAI Dinan FMIC AR Catted DP's JB4 CM Meth Kit 50/50 Mix 60 Deg Mustang Dyno 92 Octane Map 3/ 30 additive Run 1: 371 hp (5600 rpm), 429 Tq (3750 rpm) Run 2: 365 hp (5600 rpm), 440 Tq (3800 rpm) (I don't see correction info on the printout, and forgot to ask.) |
10-14-2011, 04:04 PM | #151 |
9
Rep 338
Had Terry review my logs and apparently had some issues during the run. Overshot boost, meth turned off, and it switched to map 0. Going to do some logging on the road as he stated the dyno could be causing some issues. Once I can do that may head back to a Dynojet and see what the numbers look like...just for kicks.
10-20-2011, 09:06 PM | #152 | ||
Humanist
272
Rep 398
10-24-2011, 05:17 AM | #153 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Quick dyno run pure stock 335IS JB4 map 2 93 octane
