09-26-2017, 10:25 PM | #25 | |
121
Rep 152
Drives: F30 335i M-Sport
Instagram: BoostedF30
2013 F30 335i M-Sport 2002 E39 530i |
09-26-2017, 11:36 PM | #26 |
Rep 1,509
I buy little items like cufflinks on the wish.com app all the time. Rock bottom prices and slipping is never more than a few dollars. If this thing ever shows up there it would be less than ten bucks shipped.
09-27-2017, 04:41 AM | #27 |
No 55mph
1622
Rep 8,477
If you bought the button from the original forum member then you should already have it in hand. They were all shipped this past Saturday (9/23) & I received mine USPS on Monday (9/25) here in PA in Eastern U.S.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-27-2017, 07:21 AM | #28 | |
121
Rep 152
09-27-2017, 10:29 AM | #29 |
Rep 589
Actually I'm in the same city as the seller, but he shipped it express post as I couldn't meet up the day he got them in. Received the package earlier this week.
09-27-2017, 10:39 AM | #31 |
Rep 589
Looks good, thanks for posting the pic, Mouse. Still haven't replaced mine yet dammit, lol. So lazy tied in with so busy with a sprinkling of I'm-so-f'kn-tired-after-work. Yeah, I know it only takes 5 min to swap out, that's how tired/lazy I am after my commute, lol.
09-27-2017, 03:11 PM | #33 |
121
Rep 152
Received it today. Will post a picture of it installed later tonight.
09-27-2017, 03:48 PM | #34 |
Rep 589
09-27-2017, 06:37 PM | #35 |
121
Rep 152
Did you all find it necessary to disconnect the negative battery terminal? I was hoping I could unlock the car and leave the door open and let it be for 15 minutes until the electronics turn off then proceed to take it off and replace button
09-27-2017, 06:39 PM | #36 |
42
Rep 142
I did not disconnect the battery, but I also didn?t unplug it from the harness. I just popped the button assembly out without unplugging it.
09-27-2017, 07:35 PM | #37 | |
No 55mph
1622
Rep 8,477
Just open the door, pry out the switch, disconnect wire, swap button and reverse order install Battery does not need to be disconnected or car in sleep mode to unplug this switch
09-27-2017, 08:29 PM | #39 |
Rep 589
Installed mine tonite. I'll hafta go onto my laptop to upload the link properly as using Flickr on my iPad blows.
FYI, if you have a 2012 F30 like I do, the inner tabs to remove the original start button are not the same as in the video install here. You'll need to pry each tab and hold them (do NOT think they'll click apart as in the video; yours WILL break) individually then turn the starter upside down and the button will then fall out easily. Last edited by LiquidMercury; 09-28-2017 at 09:42 AM.. |
scostu1623.00 |
09-27-2017, 08:43 PM | #40 |
95
Rep 279
Same way I did mine.
1QuikWS61621.50 Mountain_Commando303.00 |
09-27-2017, 10:02 PM | #43 |
Rep 3,211
nice red vagina-button
It must be late and I must be getting horny BTW how do you remove the entire start/stop unit from the dash/console Ive not seen a video on how to do that |
09-27-2017, 10:19 PM | #44 |
Rep 589
I used a trim tool and simply pried it out from the dash. Entire unit is held in by 3 metal clips.
