Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Hawaii > For Sale: 2009 335i Coupe Twin Turbo 6spd Blk/Blk Leather - $18000
      06-23-2017, 05:01 AM   #1
Figure807
Power without control is no power at all...
Figure807's Avatar
Drives: 335i 6spd Blk/Blk
Purchased brand new; I am the original owner. The car is registered in Hawaii and has a valid safety sticker. Clean front bumper - no front plate holes. The car has been modified to make a reliable ~370hp and ~400ft-lbs of torque with no speed limiter, so it can easily run past 155mph. Although it is a coupe, the car comfortably seats four full-sized adults. The car has been well-maintained and never abused. The major maintenance that has already been completed would easily cost $8k; BMW makes outstanding driver's cars but they are not built to run maintenance free. If you were to purchase any other E90/E92/E93 335i with over 50k miles you can expect to pay at least that amount in a few years, so why not buy one that has already had the work done! This is one of the most popular cars to tune at the moment (they can easily make well over 600hp without modifying the engine's internals). An OBDII code scanning tool (Bav Tech) will come with the car so you can perform your own diagnostics. I am forced to sell because I'm moving off island to Japan and the car does not deserve to sit in storage. $18k. 562-270-3182.
2009 335i Coupe (E92)
N54 twin-turbo engine (min 91 octane)
6-speed manual transmission
Hydraulic power steering
Xenon auto-focusing headlights
Black sapphire paint (metallic)
Black Dakota leather interior
Cold weather package (headlight washers, heated steering wheel, heated seats, trunk pass-through for skis)
97k miles (mostly autobahn/highway miles)
Major Maintenance Completed:
Spark plugs and ignition coils replaced at 91k
Transmission and differential fluid replaced at 88k
Battery upgraded to AGM-type at 86k
Brake rotors and pads replaced at 84k
Brake fluid flush at 84k
A/C evaporator and condenser replaced at 83k
4-wheel alignment at 82k
Suspension upgrade at 82k
Coolant flush at 79k
Valve covered gasket and oil filter housing gasket replaced at 77k
Walnut shell valve cleaning at 77k
Exterior Modifications:
BMW M front/rear bumpers
BMW gloss black front kidney grilles
AC Schnitzer roof spoiler
BMW M3 trunk lip
Carbon fiber BMW emblems
Euro blind spot side mirrors (outer third of the mirrors are curved)
Yellow fog lights
Interior Modifications:
P3 boost gauge in driver's side A/C vent
BMW ZHP weighted shift knob
BMW winter mats
Rear fog light switch
Amber LED interior lights
White LED interior trunk light
Window coding (windows roll up and down with key fob control)
Additional power outlet
Engine/drivetrain Modifications:
Vishnu Procede V5 Engine Tuner
BMS dual cone intakes
Active Autowerke downpipes
Forge diverter valves
Cobb charge pipe
RB PCV valve upgrade
Mishimoto oil catch can
Silicone vacuum lines
UUC magnetic oil drain plug
Clutch Delay Valve (CDV) delete
Clutch pedal stop
Suspension Modifications:
Bilstein PSS10 Coilover 10-way adjustable suspension
M3 Front Control Arms
Michelin Pilot Super Sport tires
Misc Modifications:
Diehard Advanced Gold AGM battery 80Ah/140RC/800CCA
BMW wheel lock set
Backup hood release
Additional items available:
OBDII cable for coding
17" factory wheels with Wintersport 3D tires
Walnut shell blasting kit
AR Design oil catch can
New water pump and thermostat
Bentley repair manual
2009 335i Coupe 6MT Blk Sapphire / Blk Leather
2007 328i Coupe 6MT Blk Sapphire / Blk Leather *Sold
1985 Toyota Corolla GTS 5MT 1.5-way Slvr / Blk *Sold
1987 Toyota Corolla GTS 5MT KAAZ 2-way Blk / Blk *Sold
      07-03-2017, 04:36 PM   #2
Figure807
Figure807's Avatar
Bump.
