E92 335is - front strut leaking. Recommendations for replacement?
04-19-2024, 12:53 PM | #1 |
Rep 22
My 2013 335is coupe's front left strut is leaking (I noticed it a while ago .. finally took it to indy shop for other work, and they flagged it too)
The shop recommends replacing both front struts/mounts/bump stops/guide tubes/hardware. They said they only really use OEM parts. If you were me would you consider upgrading suspension setup to something else? Different brand/setup? Coilovers? And if I were to upgrade, I'd need to do the rears too correct? Lastly the shop quoted $2400 parts+labor for OEM replacement. Is that reasonable? I am in HCOL area (Boston) Thanks in advance |
04-22-2024, 05:20 PM | #3 |
Rep 3
Drives: 2003 E39, 2008 E90, 2011 E92
$2400 is obscene, but that's dealer pricing. I recently installed Koni Special Active, front and rear, on my wife's E92 Coupe. She is a very happy camper.
05-03-2024, 09:53 AM | #4 |
953
Rep 2,677
Drives: e92 + f15
Depends what you're looking for in terms of ride and handling.
I'd skip the shop that you went to, and I have an idea of which one it might be. Can make recommendations for a better local shop if you want to go aftermarket / bring your own parts route. I would consider options from FCPEuro, have them shipped to you, and get a quote for install + alignment. For $2400, you could get into a nice coilover setup, (factor in some include camber plates to replace mounts, etc) but again it depends on the end goal. |
335is, coilovers, e92, shocks, struts, suspension |
