BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding error. CAFD not found
Studio RSR
      09-22-2017, 05:57 AM   #45
shawnsheridan
General
shawnsheridan's Avatar
Originally Posted by jaskor View Post
Your response is like the speed of lightning.
Thank.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      10-31-2017, 05:13 AM   #46
Okan2630
Drives: BMW
Hello I have the same issue with this fem_body cafd. Anyone that could help me ??
This is the cafe: Cafd_00000794_014_040_122
      10-31-2017, 09:01 AM   #47
shawnsheridan
General
Or, you could just help yourself:
http://f80.bimmerpost.com/forums/sho...&postcount=189
      11-26-2017, 08:09 AM   #48
Barre
Drives: 320xdT-16
Thanks
Thanks, this was very helpful!
      12-09-2017, 10:19 PM   #49
cj168
Drives: 2013 X3 M Sport
Hello Shawn,
I had similar issue with several CAFD files not found after dealer’s recall on F25 program US version control units this week…
Looks like I may need to update PSdZData and E-System (3.18.4) as well?
Please advise/PM me once you got a chance.
Many Thanks,
      12-09-2017, 10:21 PM   #50
shawnsheridan
General
Originally Posted by cj168 View Post
Hello Shawn,
Many Thanks,
PM sent.
      12-09-2017, 10:34 PM   #51
cj168
Thumbs up
Originally Posted by shawnsheridan View Post
PM sent.
Awesome!
Thanks for the prompt response.
      01-23-2018, 11:54 AM   #52
pasam
Drives: e90
i have the same problem like in the #26. No cafd assignment possible for zgw and champ2 with emulator. Can someone please help me?
      01-23-2018, 11:57 AM   #53
shawnsheridan
General
ZGW is not a codeable ECU. It has no CAFD by design.
      01-23-2018, 01:01 PM   #54
pasam
Drives: e90
Thank you shawnsheridan. Thank really much!!!!!
One additional question. My Champ2 is a retrofit navi and i try to use a most emulator.
After i plugin the emulator the navi loose the coding values. I check it with E sys and see there is no cafd file assigned to the champ2.
Now im not able to code the navi in Esys. I start CAF to SWE and than try o start a fa coding with following error msg.:
CAF File is: cafd_000000f9-007_001_105
Service WDBI_CPS returned a negative response with code requestOutofRange; ECU: HU_CHAMP_63_Ethernet
i try coding with changing the VIN of the Navi with same error. And with different connection via gateway and direct vin..
(Car is a f10 preLCI without Navi)
After reading the fehlerspeicher i find following errors:
- 0xB7F8A9: Codierereignis datenübertragung fehlgeschlagen
- 0xB7F881: codierungsereignis nicht codiert.
      01-23-2018, 02:50 PM   #55
shawnsheridan
General
Do you try injecting CAFD and VO Coding without Emulator hooked up?
And you need to make sure you have proper FA for CHAMP2.
      01-23-2018, 05:06 PM   #56
pasam
Drives: e90
big thanks for the super fast response, Shawn.
At the moment I can start a FA Coding without a emulator and everything works fine. The Navi start with the correct menu and i see the Navigation menu item. After installation of the Emulator, the Navi starts and make during the startup phase a reboot again and i see only the standard menu without all the items like navigation.
My car vin is: C704785
and the retrofit Navi has the vin: C659157
I read the Fa form the car and i add 606: My current FA contain following SALAPA Elements:
1CA 1CB 1CC 1CD 230 2K1 320 423 428 488 494 4AT 508 548 575 606 612 614 615 616 620 633 698 6AA 6AB 6FL 6VC 801 851 863 879 8KA 8KA 8TL 8TN 8V1
I dont know so much of injection and of this stuff.sorry that is new for me..
      01-23-2018, 05:18 PM   #57
shawnsheridan
General
If you can code CHAMP2 without Emulator, and then hook up Emulator and it is messed up the iDrive Menu, then it seems Emulator is messed up. All it should be doing is handling the VIN mismatch between CHAMP2 and its FSC Codes compared to Car's CAS Module.
I notice 6VC in FA. I trust car has Combox to go with it.
      01-23-2018, 05:19 PM   #58
pasam
Drives: e90
i see that i have add 620 voice control and 614 internet my mistake into the FA. Do you think this cause the problem?
      01-23-2018, 05:26 PM   #59
pasam
Drives: e90
Hello shawn, it is possible to confirm that the emulator is messed up?
      01-23-2018, 05:27 PM   #60
shawnsheridan
General
No idea. CHAMP2 is technically capable of Voice Recognition so long as it FSC Enabling Code AppID 36 (24) Champ2 iSpeech High, but I do not know if in such a case, 620 is used in FA.
But, that is a coding issue. FA has nothing to do with Emulator issue.
No idea. I never used one before.
      01-25-2018, 02:41 PM   #61
pasam
Drives: e90
Hello Shawn
do you think the problem come up because of the cafd assignment?
https://ibb.co/dfJsgw
https://ibb.co/jSLf1w
i try followingpoints without a success:
- Change the VIN in the FA xml file and try to code
--> Problem not possible to activate the fa. XML error comes up.
change the VIN of the retrofit champ2 and try to start coding
--> i receive the same error
Shawn do oyu know if the champ has a second coding EEPROM Data (default) which will be activate if the coded VIN is different to the received VIN?
Because i see that my idrive menü and my setting restored again, if i disconnect the emulator and restart the navi....
strange strange strange...
      01-25-2018, 02:55 PM   #62
shawnsheridan
General
Hello Shawn
You say you have error trying to activate FA, but picture shows FA successfully activated.
What happens when you righti-click on CHAMP2 and select Code after the CAFD was injected?
I have no idea about EEPROM(s).
      01-25-2018, 03:11 PM   #63
pasam
Drives: e90
Thank you Shawn,
i will try it tomorrow.
if i try to code it i receive following msg in E-Sys:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
TAL-Abarbeitung gestartet.
VCM Update: Automatische VCM-Aktualisierung ist deaktiviert. VCM wird nicht aktualisiert. [C197]
ExecutionID=2018/01/25-18:59:08.438
[] "prepareTALExecution" wurde gestartet.
[] "prepareTALExecution" wurde beendet.
[] "prepareVehicleForCoding" wurde gestartet.
[] "prepareVehicleForCoding" wurde beendet.
[HU_CHAMP - 63] "prepareECUforCoding" wurde gestartet.
[HU_CHAMP - 63] "prepareECUforCoding" wurde beendet.
[HU_CHAMP - 63] "authenticateECUforCoding" wurde gestartet.
[HU_CHAMP - 63] "authenticateECUforCoding" wurde beendet.
[HU_CHAMP - 63 - cafd_000000f9-007_001_105] Transaction type: cdDeploy; Message: Transaktion wurde gestartet.
[HU_CHAMP - 63 - cafd_000000f9-007_001_105] Transaction type: cdDeploy; Message: Transaktion wurde beendet.
[HU_CHAMP - 63] "finalizeECUCoding" wurde gestartet.
MCDDiagService<Id: 80649, Jobname: com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, Diagnoseservice: WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, Beschreibung: error: negative response : requestOutOfRange, LogicalLink: HU_CHAMP_63_ETHERNET>
[HU_CHAMP - 63] Bei der Aktion "finalizeECUCoding" ist ein Fehler aufgetreten.
[HU_CHAMP - 63] Während der TAL-Abarbeitung ist ein Fehler aufgetreten, bitte überprüfen Sie die Log-Datei.
[HU_CHAMP - 63] - [Exception - HU_CHAMP - 63] Job-Ausführung ist fehlgeschlagen: negative response error:
code: service returned global negative response
description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; ECU: HU_CHAMP_63_ETHERNET
severity: ERROR
[] "finalizeVehicleCoding" wurde gestartet.
[] "finalizeVehicleCoding" wurde beendet.
[] "finalizeTALExecution" wurde gestartet.
[] "finalizeTALExecution" wurde beendet.
TAL-Abarbeitung beendet.
TAL-Abarbeitung beendet mit Status: "FinishedWithError". [C207]
TAL-Abarbeitung beendet. Dauer: "15s". [C206]
Abarbeitung beendet
      01-25-2018, 03:12 PM   #64
pasam
Drives: e90
Thats my Fehlerspeicher:
F E H L E R S P E I C H E R L E S E N
Datum: 21.05.2017, 21:28:59
JobStatus: OKAY
Variante: CHAMP2.PRG
Version: 12.001
ERGEBNIS: 6 Fehler im Fehlerspeicher !
0xB7F881 Codierungsereignis nicht codiert
Testbedingungen erfüllt
Fehler momentan vorhanden und bereits gespeichert
Fehler würde kein Aufleuchten einer Warnlampe verursachen
Dies ist kein Ereignis-DTC. Das SG ist für den Fehlerspeichereintrag (DTC) verantwortlich.
Fehlercode: B7 F8 81 0F
0xB7F882 Codierungsereignis falsches Fahrzeug
Fehlercode: B7 F8 82 0F
0xE1C447 MOST: ein Steuergerät hat sich abgemeldet
Fehler momentan nicht vorhanden, aber bereits gespeichert
Dies ist ein Ereignis-DTC. Das SG ist somit nicht für den Fehlerspeichereintrag verantwortlich.
(Z.B. falsche oder fehlende Netzwerkinformationen.)
Fehlercode: E1 C4 47 0C
0xE1C440 Reset
Fehlercode: E1 C4 40 0C
0xB7F80F Verbindung Head-Unit zum GPS-Antennenfuß: Leitungsunterbrechung
Fehlercode: B7 F8 0F 0F
0xE1C449 MOST-Knoten: Die gleiche Kombination von FBlockID und InstID wird von zwei unterschiedlichen MOST SG doppelt beim NWM angemeldet
Fehlercode: E1 C4 49 0E
      01-25-2018, 03:15 PM   #65
shawnsheridan
General
Thank you Shawn,
Caf's suchen
Tal wird generiert
severity: ERROR
Abarbeitung beendet
"WDBI_CPS - WriteDataByIdentifier" is VIN issue.
      01-25-2018, 03:45 PM   #66
pasam
Drives: e90
Do you have a plan for me? What can i test to?
Sorry for so much questions...
