      03-05-2010, 09:20 AM   #45
Cris C125i
Mexico
Drives: 125i Coupe
Hi There:
Im wondering if someones knows what is the differents between 125i Coupe (Mexican version) and 128i Coupe (American version), because I have had to get lower my coupe with EIBACH Pro-kit progressive performance springs part # 2098.140 but Im not sure if they will assemble in my 125i coupe. Thanks for your help.
      03-19-2010, 09:30 PM   #46
mineo77
mineo77's Avatar
Drives: 2010 135i,1989 PRO3,2001 530i
2010 135i coupe  [7.56]
KW V2's installed
Just wanted to post the before and after of the KW V2 install. Love these things...car drives substantially better.
Prior to install
After install and adjusted for the springs settling during 1st week
Pics of KW kit and install process..done by HPF (horsepowerfreaks)
      08-09-2010, 10:15 PM   #47
mkppk
mkppk's Avatar
17
Drives: 335i xDrive M Performance
KW V2
KW V2
Set at 1.75" from max drop front.
About 0.5" from max drop rear.
May have to raise a bit because the alley I have to drive through to get to my parking garage has a nasty dip and I scrape the resonators on it now.
Other responses to questions about the setup:
http://www.1addicts.com/forums/showp...25&postcount=1
      08-16-2010, 06:21 PM   #48
The1
76
Drives: white 135
how is the ride quality on the KWs? does it ride more nicely then stock?
      08-16-2010, 07:31 PM   #49
mkppk
mkppk's Avatar
17
Pretty good. A little stiffer than stock, but not quite as harsh.. if that makes any sense. I guess I'd say on small bumps on the street it feels a little softer than stock (which is nice), on larger bumps and during harder cornering you can tell they are a bit stiffer. I have the not changed the factory dampening setting on the KWs.
I think my fronts are too low, I think something is hitting on rough road, maybe the sway bar and some other suspension component are now too close, I feel/hear a slight clunk. I don't think the suspension was designed to be this low in front.
Note: it has settled a bit more in front than the pictures show.
      08-16-2010, 11:34 PM   #50
The1
76
Drives: white 135
makes sense. I find the stock suspension feels a bit hollow somehow sometimes, reminds me of the feeling of the old Z3s..... I'm just wondering if that feeling is all down to the weight of the wheels and tires, or if that funny feeling is the suspension setup BMW goes with.
I don't mind a hard ride, but i don't like a bouncy ride or a teeth shattering ride. but i guess coilovers should take care of that.
thanks for the info. And i think that 1.75 is definitely low. I went that low on the front of a subaru and 2 inches at the back.... i had to life the back up about half an inch to get some drivabilty back.
I loved the handling though.
      08-29-2010, 08:06 PM   #51
evilstib
Bimmer Newbie
22
Drives: CSM N54 Prem/Comf/Sound
What color is that beemer?
Originally Posted by jthorst75 View Post
Is that silver or cashmere silver? ;D
I just bought a 'new' 2009 135i Cashmere silver. Hard to find pics of what it will look like when my brain's finished modifying it...this pic helps!
Thanks!
      10-16-2010, 11:36 PM   #52
MikeVictor
Australia
210
Drives: anything given a chance
For those interested, here are some pics of my MY08 135i fitted with Koni FSD struts, and BMW Performance springs (related post here -> http://www.1addicts.com/forums/showthread.php?t=436719)
      04-21-2011, 01:13 AM   #53
Sylon
Sylon's Avatar
Drives: 2011 135i, SG/CR, 6MT, M-Sport
2011 135i  [9.20]
Is there anything warranty-wise I should worry about for getting something other than BMW suspension bits put on my car? I was thinking of Eibach Pro-kit springs. Can just the BMW Performance springs be installed or does the whole BMW Performance Suspension (the one for about $1500) have to be done?
2011 BMW 135i | Space Gray | ///M-Sport | BMW CCA #450291
Facebook / Instagram / YouTube / Twitter
      04-24-2011, 04:12 PM   #54
Sylon
Sylon's Avatar
2011 135i  [9.20]
^^^Bump. Anyone???
      04-24-2011, 05:32 PM   #55
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I have seen some ppl use the Perf Springs with other shocks. Sure why not?
I think the main reasons are three fold why everyone seems to go with Perf Suspension.
1). Warranty & Designed to work properly and tuned for our cars.
2). Best package deal. ie: it comes with everything you need: shocks, sprigs, front sway bar and all the misc mounting hardware.
3). price. The PS is cheaper than going your own route on springs and shocks.
      04-26-2011, 01:08 PM   #56
SpacE82
SpacE82's Avatar
Drives: 2009 M-Sport 135i
2009 BMW 135i  [8.50]
Does anyone have the ST Coilovers or seen any pics? I'm thinking of doing these!
      06-03-2011, 04:32 PM   #57
KinoBoom
KinoBoom's Avatar
Drives: 2018 M2
This is my favo height setup so far...
Originally Posted by Harold View Post
120d on Hartge lowering springs:
Do you have spring rates and how much did the car drop?
      06-10-2011, 07:44 PM   #58
spiral
Drives: 2008 135i
I had Sonic MS put on the STs yesterday, but I'm waiting for them to settle before I post pictures. Stay tuned!
      06-23-2011, 01:15 AM   #59
AJN54135i
sksksk
AJN54135i's Avatar
17
Drives: 2008 BMW 135i
Kw coil overs are the way to go
      07-19-2011, 04:59 PM   #60
xoxoluvcrisxoxo
xoxoluvcrisxoxo's Avatar
Philippines
19
Drives: 2006 330i white/black
anyone on b&gs?
      07-19-2011, 05:04 PM   #61
xoxoluvcrisxoxo
Philippines
19
jst did a little search! it was on the photo section. B&Gs
http://www.1addicts.com/forums/showthread.php?p=9017035
      08-04-2011, 10:35 AM   #62
Specter88
22
Drives: 120d Coupe
kw v1 with shorter springs and adjustable camber plates in the front
      09-14-2011, 11:31 AM   #63
MGallop
MGallop's Avatar
49
Drives: 12' 135i
2012 BMW 135i  [10.00]
bump for more photos!!
Matthew Gallop: '12 N55 Mods: JB4 Flex ISO | iCarbon DP | VRSF 5" FMIC | BMS Intake | ER Charge Pipe | Race Axleback | ST Coils | Alufelgen CS7's | iCarbon 3 fin Diffuser |
Blackline LCI | CarbonFiber Spoiler | Orion v4 AE's | 30% tint | red+blk roundels | Cyba Scoops | H-Style front Lip | WeissLicht LED Smoked Sidemarkers | Matte Grills | Coded |
      09-23-2011, 02:50 PM   #64
anttmann
anttmann's Avatar
Drives: 18' CQM M3
just installed my H&R sport springs 4 days ago heres a pic .. and the springs still haven't settled yet.
Current: 18' F80 M3 |Champagne Quartz Metallic/Amaro Brown |ZCP / Exec
6MT
Past: 09' E82 135i Alpine White/Coral Red |CCW'D/Caged
6MT
Antoine Spignardo
      10-08-2011, 11:24 PM   #65
MGallop
MGallop's Avatar
49
Drives: 12' 135i
They should have settled in now, so snap us more pics
      10-09-2011, 05:16 AM   #66
Harlequin
Harlequin's Avatar
Australia
331
Drives: F32 Coupé
Eibach Pro Kit with M-Sport Shocks:
