      02-28-2024, 10:01 AM   #1
bender128
bender128's Avatar
40
Drives: BMW 128i Coupe
2011 128i  [0.00]
Reduced traction after alignment
Hey everyone. I had some camber plates installed, and got the alignment set to -2.7 front and -2.4 rear.
I thought -2.4 in the back wasn't too crazy but I have a noticeable decrease in traction when i accelerate in a straight line.
This is 128i with a 3sim so about 230 lb-ft of torque.
I use this car for daily + autocross, for those that have run similar set ups, is this reduced traction normal?
      02-28-2024, 11:04 AM   #2
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
I'd stick to -1.5 to -1.8 rear. If you don't mind me asking why do you want to much rear camber?
Could also be that you have zero toe, or that toe isn't symmetrical.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      02-28-2024, 12:10 PM   #3
bender128
bender128's Avatar
40
2011 128i  [0.00]
Toe was symmetrical from what I remember, can't find the alignment sheet right now.
I got the negative camber figure from another thread. If -1.5 would be sufficient for autox and occasional track days I'll get it realigned, I'm not a fan of the way it is now.
      03-01-2024, 03:21 PM   #4
bender128
bender128's Avatar
40
2011 128i  [0.00]
Found the sheet with alignment specs
      03-01-2024, 04:42 PM   #5
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Different sidewall stiffness's will like different camber settings. There's no one size fits all.
      03-01-2024, 07:57 PM   #6
N55e82Simon
N55e82Simon's Avatar
151
Drives: BMW 135i
2011 bmw 135i  [9.33]
Doesn’t seem like anything too crazy. How are your tires? What psi are you running?
Also as the suspension compresses when the rear loads up under acceleration you will go more negative camber.
      03-03-2024, 02:49 PM   #7
bender128
bender128's Avatar
40
2011 128i  [0.00]
About 30psi.
      03-03-2024, 02:50 PM   #8
bender128
bender128's Avatar
40
2011 128i  [0.00]
Got alignment booked for Tues, thinking to keep everything the same and just change rear neg camber to -1.5.
Appreciate all suggestions, feel free to let me know if i should change anything else.
      03-04-2024, 07:55 AM   #9
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
I am not an alignment expert but I'll throw in that the rear toe is slightly more than normal. I feel like it's typically more like .1 or so, perhaps even slightly less. I'd let others weigh in before actually asking to change it. And I doubt it affects grip very much anyhow.
      03-04-2024, 01:57 PM   #10
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
I usually go zero toe for front and 1/8 total toe IN for the rear
      03-20-2024, 09:41 PM   #11
HP Autosport
Supreme Allied Commander
Drives: F80 M3
That is way too much negative rear camber. No more than -1.5 unless have a particular driving style. Such as getting the power right after apex with the car nearly sliding sideways. You will want to maximize outside tire grip in that case.
if your rear toe is good, check the toe arms. Deflections in the toe arm bushings will reduce available traction.
