07-31-2014, 12:00 PM | #23 |
Rep 6
Hello Shawn,
Thank you so much for your help! The manual was really the missing link. I've managed to do my first successful code change (Speedlock). Not sure its the safest one, but its definitely cool to see that it worked. Now i'm trying to find how to store DivX movies on the CIC hard drive and be able to play them, but I wasn't able to find anything like that. Do you know if that is even possible with these great displays? I understand my question might be random without my car's details so i'm off to create a footer like yours so you can see whats there. Thanks again for your help, I really appreciate it. Best, C. |
07-31-2014, 12:19 PM | #24 |
General
10445
Rep 40,793
Video Playback from Hard drive is not possible, not in CIC nor even newer NBT.
07-31-2014, 12:44 PM | #25 |
Rep 6
That's strange because I had found these codes somewhere last year :
HU_CIC / HU_NBT 3000 HMIENT_CODEC_OGG HU_CIC / HU_NBT 3000 HMIENT_CODEC_XVID HU_CIC / HU_NBT 3000 HMIENT_CODEC_XVCD HU_CIC / HU_NBT 3000 HMIENT_MC_VIDEO_SUPPORT HU_CIC / HU_NBT 3003 API_USB_VIDEO -> Both Have you ever heard of these? I know i'm supposed to be able to put music on the HD (that's what the dealer told me).
2012 328iA Sport (Born 08/12) S2TBA S2VFA S2VFA S2VLA S322A S3AGA S3BEA S403A S430A S431A S441A S465A S481A S488A S4ADA S4AEA S4DNA S4NEA S502A S508A S521A S522A S524A S534A S544A S563A S5ACA S5DCA S5DLA S609A S610A S612A S614A S615A S616A S676A S6AAA S6ABA S6NFA S6NLA S6NRA S6VAA S6WAA S710A S760A P7ACA S8S3A...
07-31-2014, 01:06 PM | #26 | |
General
10445
Rep 40,793
And you can copy and play audio files to the Hard Drive, but not Video files.
07-31-2014, 01:17 PM | #27 |
Rep 6
So does that mean that I can read them from a USB key for instance?
That's what I'm really trying to do, I just can't figure out how to enable it. Right now, it only displays audio files from the USB drive but ignores the videos completely.
07-31-2014, 07:44 PM | #28 |
General
10445
Rep 40,793
Oh, sorry. You have CIC, so no. It only works with NBT Head Unit.
08-03-2014, 08:29 AM | #29 | |
Rep 4
Hi Shawn,
would it be possible to send across the files? I tried using the files in the OP on this thread but the target selections are not populating. thanks. Quote:
08-03-2014, 03:13 PM | #30 |
General
10445
Rep 40,793
PM sent.
08-03-2014, 03:24 PM | #31 |
Rep 4
thank you very much!
do you know if this is also compatible with the E93? or does that require a different application/ psdzdata? |
08-03-2014, 03:28 PM | #32 | |
General
10445
Rep 40,793
NCS Expert / EDIABAS and SP-Daten, and DCAN Interface Cable is for Exx only.
08-05-2014, 12:34 PM | #33 |
Rep 4
thanks for the info
08-09-2014, 10:26 PM | #35 |
General
10445
Rep 40,793
PM sent.
08-15-2014, 09:54 PM | #38 |
General
10445
Rep 40,793
There is no MAC E-Sys version. You have to run it in a VM / Parallels on a MAC.
TokenMaster began a project to port E-Sys over to MAC, and made some good progress, but then hit a brick wall.
08-30-2014, 01:26 AM | #41 |
Rep 3
Hey Guys
at first thanks for the SW. But it seems that a need a little bit of help. I intsalled e-sys and applied the patch. copied the pzdata files to e-sys/data and the folders to SWE. Attached the obd cable to my car and connected with e-sys. so far it is working, but when I try to read "CAFD_..." in HU_CIC I get an error message... Transaktions-Report: Aktion: Codierdaten lesen HU_CIC [63] [DV01958] readCPS o.k. CAFD_000000F9_007_003_022 Fehler: Datei für "cafd_000000f9-007_003_022" wurde nicht gefunden! [C012] Then I checke "I Stufen" and found that the version on my car (F010-14-07-504) higher is than the version I have for e-sys (F010-14-03-502). Could that be the problem or do I have made an other mistake? Thanks in advance for your help... |
08-30-2014, 06:08 AM | #42 |
General
10445
Rep 40,793
Yes, you need newer PSdZData.
PM sent.
09-13-2014, 03:24 PM | #44 |
49
Rep 235
F31 coding
Hi guys got an F31 july 2014 built bmw 320d m sport touring arriving in a couple of weeks, it has professional nav installed but no enhanced Bluetooth, I understand its just a case of coding it in on the newer pro nav system using e-sys.
Could someone send me the required files (I have the cable) in preparation for me receiving the car? Many thanks, Jamie |
