06-13-2014, 10:26 PM | #68 |
Rep 5,262
well not really sure what's going on....
now I re encoded the original binary through the site and got a working base64.... something I found out is that the name of the file does matter.... good.hex will generate a different code than bad.hex even if the files are exactly the same.... the good code that the car accepted was generated with KS91992_00DE0001.fsc now wonder if either code would work |
FlorinQCK-2.50 |
06-13-2014, 10:53 PM | #69 | |
Rep 1,892
Try fc /b <file A> <file B> to perform a binary comparison. |
FlorinQCK-2.50 |
06-20-2014, 11:11 AM | #74 | |
Rep 1,892
You can check by looking in the Info_Map.imp file. The region code is 2 bytes at offset 8, and the sequence number is the 2 bytes after that. Last edited by Frogman; 06-20-2014 at 11:17 AM.. |
FlorinQCK-2.50 |
06-20-2014, 11:16 AM | #75 | |
Rep 88
Like the poster above, I just read FSC from car using E-Sys, and without encoding, i used the following command: nbt.exe DE.fsc 0xA8 0x06 <7DIGITVIN> Map is currently updating Last edited by F30EDR; 06-20-2014 at 11:23 AM.. |
FlorinQCK-2.50 |
07-16-2014, 02:04 PM | #76 |
Rep 706
Well, I managed to get my FSC code for my M4 ready to put it in...
When it finished loading the maps from the USB stick (2014-2 Europe NEXT) it started with no request for the FSC code!!!! Why is this, have they stopped using FSC codes? |
FlorinQCK-2.50 |
07-16-2014, 03:36 PM | #77 | |
Rep 1,892
For your case, I think the FSC code built into your car at the factory was already enabled for the 2104-2 map (sequence 0x05) even though it was loaded with 2014-1 (sequence 0x04). I've heard of this happening in the US too. I'm guessing that when you start the installation of a new map, the software checks that the map region codes match and only prompts for a new FSC code if the installing map sequence number is greater than the sequence number stored in the cars' current FSC. This would explain the ability to revert maps to prior versions (which I have heard other people doing) without having to re-install an old FSC code. This has interesting implications! |
FlorinQCK-2.50 |
07-16-2014, 04:26 PM | #78 | |
32
Rep 297
FlorinQCK-2.50 |
07-17-2014, 01:42 PM | #79 |
85
Rep 280
Should be hopefully true for MY2015:
https://www.press.bmwgroup.com/globa...tem=node__5238 |
FlorinQCK-2.50 |
07-19-2014, 04:27 PM | #80 |
Rep 626
Thanks to the information in this thread I have been able to update to the Europe Next 2014-2 maps.
I used E-Sys to obtain / create the .fsc file. The question I have will this .fsc data ever change or will I be able to use the same file on my next map update? I presume it would only change if the car was updated? |
FlorinQCK-2.50 |
08-08-2014, 11:17 AM | #81 | |
Rep 524
FlorinQCK-2.50 |
08-08-2014, 12:59 PM | #82 |
Now in the dark side !
65
Rep 1,136
Does anyone have the link to download the MAP 2015 Premium NA ?
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
FlorinQCK-2.50 |
08-15-2014, 03:52 PM | #84 |
65
Rep 1,136
Thanks guys.
Map is now updated 100%, in the Navigation map version, it's now: - North America Premium 2015-1
FlorinQCK-2.50 |
08-28-2014, 02:04 PM | #85 |
Rep 3
I think I'm very close but perhaps missing a step. I got the FSC directly from E-sys. It is in hex and 256bit. From what I gathered by reading here I should be able to do what exactly F30EDR mentioned but I'm getting error that my FSC file is not in correct format.
I really appreciate any help I can get. Last edited by napolean82; 08-28-2014 at 02:24 PM.. |
FlorinQCK-2.50 |
08-28-2014, 02:59 PM | #86 | |
Rep 1,892
FlorinQCK-2.50 |
08-29-2014, 09:23 PM | #88 |
General
10445
Rep 40,774
Road Map North America PREMIUM 2015-1 = 0x2D 0x09.
FlorinQCK-2.50 |
