EXXEL Distributions
      03-26-2024, 02:11 PM   #1
Wan15bad
Drives: 2008 E90 320ci sport
Misfire on all Cylinders
Hi All,
Car was driving fine then started to stutter and threw up a drivetrain error. Seems to drive fine at speed however very rough and shaky idle and low speed.
Has thrown up misfires on all cylinders (Plugs replaced around 2 months ago).
Recent valve cover replacement however car was fine after and has done around 100miles, no smoke since.
Seems odd to have all the misfires recorded below as wouldn't expect all coils and plugs to fail together. Would a faulty VANOS sensor cause misfires?
Any advice appreciated.
P13C9 [0x13C9] - VANOS, exhaust: control fault, camshaft stuck.
Status: Pending
P0300 [0x0300]
Random/multiple cylinder(s) - misfire detected
Random/Multiple Cylinder Misfire Detected
Status: Pending
P0301 [0x0301]
Cylinder 1 - misfire detected
Cylinder 1 Misfire Detected
Status: Pending
P0305 [0x0305]
Cylinder 5 - misfire detected
Cylinder 5 Misfire Detected
Status: Pending
P0303 [0x0303]
Cylinder 3 - misfire detected
Cylinder 3 Misfire Detected
Status: Pending
P0306 [0x0306]
Cylinder 6 - misfire detected
Cylinder 6 Misfire Detected
Status: Pending
P0302 [0x0302]
Cylinder 2 - misfire detected
Cylinder 2 Misfire Detected
Status: Pending
P0304 [0x0304]
Cylinder 4 - misfire detected
Cylinder 4 Misfire Detected
Status: Pending
Hasd the below recorded as well but seem to be duplicates of above issues.
120408 [0x120408]
140010 [0x140010]
140110 [0x140110]
140510 [0x140510]
140310 [0x140310]
140610 [0x140610]
140210 [0x140210]
140410 [0x140410]
140004 [0x140004]
140104 [0x140104]
140504 [0x140504]
140304 [0x140304]
140604 [0x140604]
140204 [0x140204]
140404 [0x140404]
      03-26-2024, 07:32 PM   #2
Jonwho2
15
Drives: 2015 F83 M4
I'd start with the P13C9 as its the only code you listed that will affect all cylinders.
      03-27-2024, 09:11 AM   #3
Wan15bad
Thanks, I've ordered a new Vanos solenoid will replace that and go from there!
      03-27-2024, 01:35 PM   #4
Wan15bad
To update if anyone experiences this same issue. Started car today very rough idle left running for 5 mins and issue cleared. Took for a hard drive and no issues.
May well come back but im stumped for now.
      03-27-2024, 02:46 PM   #5
headstart101
47
Drives: 2016 MG M4
Would still replace the Vanos because from personal experience, when a problem temporarily clears, it gets worse once it pops up again. Chances are, with all those codes, there is a legitimate problem that needs attention.
f80post
