06-18-2015, 06:37 AM | #23 | |
66
Rep 365
I believe its still in closed loop so it shouldn't affect anything but will compare power and Afr with and without the piggy back. Last edited by rednose; 06-18-2015 at 06:57 AM.. |
06-19-2015, 02:05 AM | #24 | |
66
Rep 365
http://f30.bimmerpost.com/forums/sho...5#post18116185 |
05-24-2016, 03:32 AM | #28 |
10
Rep 51
Out of curiosity have you run into any of the gearbox safeguard problems on the 320i when the torque is raised substantially? Some others (be it overseas) have had this problem after add on type tune boxes etc. Or does your tune address this issue as well?
05-28-2016, 01:13 AM | #29 | |
Rep 6
Thanks |
06-02-2016, 03:12 AM | #30 | |
Rep 5,530
PM sent |
06-02-2016, 03:13 AM | #31 |
Rep 5,530
Couple more N20 results from this week
F20 125i Stock: 149rwkw, Tuned: 179rwkw, gain of 30kw & 20% F30 320i Stock: 114rwkw, Tuned: 174rwkw, gain of 60kw & 52% |
04-13-2019, 08:12 AM | #34 | |
22
Rep 58
Also if you click on each part then you can see different weights like FMIC is 30% heavier in the 328 or you can see the 328i has 75mm mid pipe vs 320i has 65mm mid pipe Piston: 320i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770 328i - http://www.realoem.com/bmw/enUS/show...diagId=11_4770 Rear Exhaust: 320i - http://www.realoem.com/bmw/enUS/show...diagId=18_1105 328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0974 Transmission: 320i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330 328i - http://www.realoem.com/bmw/enUS/show...diagId=24_1330 Driveshaft: 320i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240 328i - http://www.realoem.com/bmw/enUS/show...diagId=26_0240 Front Muffler: 320i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975 328i - http://www.realoem.com/bmw/enUS/show...diagId=18_0975 FMIC 320i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632 328i - http://www.realoem.com/bmw/enUS/show...diagId=17_0632 |
12-04-2019, 03:12 PM | #35 | |
Rep 15
So I own the 420i EUR 2016 (n20) and planning to do this downpipe upgrade with sport cat FMIC. However, the FMIC I am trying to buy is from US, and made for 428i. based on your message there are no hardware differences so 428i FMIC should fit 420i as long as both are using n20? |
12-04-2019, 03:15 PM | #36 |
Rep 15
What I am thinking is that maybe part numbering is different considering that versions are EUR and US? |
05-07-2020, 11:22 AM | #37 | |
Rep 66
320, 420, bmr autowerkes, sydney, tuning |
