03-16-2013, 02:32 PM | #89 |
Command Sergeant Major of the Army
142
Rep 639
Have to say that this install was a piece of cake. Love the way it looks and feels.
Many thanks to nolan12 for the awesome DIY!
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
03-17-2013, 04:59 PM | #91 | |
149
Rep 373
03-17-2013, 07:30 PM | #92 |
Rep 268
I'm about to order the F10 M5 knob, and my question to those of you that have done this, is for an ultra clean OEM look, and easy as possible, would you still have done the trimming and glue onto the original plastic frame?
What's the easiest way to get this knob done? |
03-17-2013, 10:17 PM | #93 | |
Rep 495
Some of us have trimmed and glued, others have not. Based on the pics we have all posted, they look the same on the outside. I don't regret trimming and gluing but if you're looking for an OEM look and want an easier install, just fold it over the ring and snap it in. |
03-18-2013, 07:12 AM | #94 |
Rep 6,864
03-18-2013, 08:47 AM | #95 |
Rep 3,178
I've caved in and put the order in to give this a try! Should be interesting to see if the weighted aspects feels really that different
///M3 | E90 LCI | Space Grey | Fox Red with CF Structure | 6MT | 260M | My build
03-19-2013, 05:07 PM | #97 |
Rep 1,616
I'm getting ready to do this mod and was wondering. Do you even need to glue the boot to the ring? If you cut the holes in the boot and wrap it around the ring and then snap the ring back in place won't that be enough to hold the boot in place?
03-19-2013, 05:10 PM | #98 |
Rep 495
The answer is three responses above yours.
03-21-2013, 11:47 AM | #100 |
Rep 268
just finished the mod, have to say the easiest method is just to wrap it as right as you can around the base and cut new wholes that keep it secure..
QUESTION - Is the base a bit of a pain to snap back in? mine seems to come up of I pull on the corner of the frame at all.. it will all unsnap and come up very easily.. I pushed it in as much as I could, and it doesn't go anywhere when I drive around, but was that the case for most?? It just comes up very easy if you manipulate it at all, but other then that it stays secure and in place while driving.. guess it's not a big deal? |
03-21-2013, 12:32 PM | #102 | |
Rep 495
The leather is thick and it makes it hard (or impossible for me) to get it clipped from the top. I popped off the whole center console trim so I could get to it from the bottom. I carefully made sure the clips were in place, then put snapped the console back on. Hasn't moved a bit since then. Removing the console trim is easy; just pull up gently from the hold where the boot goes and work your way around. Good luck. |
03-21-2013, 12:39 PM | #103 | |
Rep 6,864
03-21-2013, 03:28 PM | #104 | |
Rep 268
FOR PEOPLE EXPERIENCING THIS PROBLEM: The issue is generally caused by you not making the holes around the clips big enough, so there isn't enough clearance for it to go down all the way, all you have to do is cut a small "square" not just a circle and it can be a little loose as long as it's secure and doesn't cover any of the clip. I did this again, and it looks in perfectly, run your fingers around the edges to make sure it's not going to pop up easy. There is no need to pull the trim piece up. |
03-21-2013, 03:31 PM | #105 |
Rep 268
03-23-2013, 02:03 PM | #107 | |
Rep 386
2011.5 M3 Coupe: Space Gray, 4MY, ZCP, ZCV, ZP2, 494, 5AC, 655, and 752
Mods: Full Venture Shield protection kit, RPi scoops, Euro fog light switch, LUX V4, clear reflectors, OEM black chrome grilles and side gills, black hood vents, IND F10 M5 shift knob and boot |
03-26-2013, 04:01 PM | #108 | |
Rep 1,616
At first i was hesitant to cut much of the leather but once i glued the leather to the ring and tried to snap it in the first time I realized that i have to cut a lot more leather because the ring would not snap into place. You have to cut and fold the leather so there is a snug fit since the M5 boot is bigger and you'll just a lot of the leather bunched up if you don't
03-29-2013, 01:40 AM | #109 |
Rep 46
Received my M5 shift knob today and installed it in about half an hour; looks factory.
Thanks for the inspiring right up and contributors...best $120 sent on a mod so far. Last edited by ///m3e90; 04-02-2013 at 12:14 PM.. Reason: Added photo |
04-01-2013, 06:13 PM | #110 |
Rep 3,178
So 2 years have I had my 6mt m3.. 3 days ago did the f10 m5 shift knob install.. No glue nothing just cut some holes in the boot tucked it over and clipped it in. Just drove 1000km and I'm very pleased .. Weighted and shorter feels great!
