2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Brake upgrades from other BMW models on F10
      01-08-2019, 09:09 PM   #89
alexmolavi
Drives: 535D
Great Thread and very useful. I am going with what is being recommenced by .BMW. and Addy27, BUT what most people doing for the rear brakes upgrade? the 535D rear brakes are not all that good to begin with and I generally like to have a balanced braking front to rear. If front caliper biting force is increasing so should the back.
I do understand that the front brakes do most of the work but I like balanced approach.
Original Posts:
Looks great, complements the Alpina wheels!
So these are the front brakes from F01 760i/Alpina B7?
The rotors are 374x36, the same diameter as the Euro spec 550i/M550d brakes I used, but the size of the hat is reduced to allow calipers with larger brake pads.
I also noticed that the caliper carrier is the same as on my setup.
I add all part numbers on the same way as in my post on the first page in this thread for future readers:
F01 7 Series 760i and Alpina B7 2-piece directional 374x36 rotors.
L: partnr. 34 11 6 789 543
R: partnr. 34 11 6 789 544
Caliper housing.
L: partnr. 34 11 6 786 827
R: partnr. 34 11 6 786 828
Caliper carrier.
Partnr. 34 11 6 786 829
Brake pads.
Partnr. 34 11 6 794 464
Correct me if I'm wrong addy27.
      02-01-2019, 11:10 AM   #90
itsnota2ma
itsnota2ma's Avatar
20
Drives: 2012 550i xDrive Msport
M5 brakes
So I recently purchased some stupid cheap M5 front calipers and unknown rear calipers.
Question 1. I have the 550i Msport brakes currently. Do I have to use the M5 rotor with these calipers? What are my other rotor options?
Question 2. Do I need to get an adapter? It looks like there is one on the brakes already. The mounting hole center to center measurement match the stock calipers, however I don't know if the depth is the same.
Question 3. Anyone know what the rear brakes are? I would like to use them, I know I will need an adapter.
John H.230.00
      02-01-2019, 01:15 PM   #91
addy27
Drives: F10 550i
Stock M5 won't fit directly onto your 550i. The holes for the screws are at different locations. You'll need an adapter. Also yes, you will need new rotors to go with them.
not sure about the rear brakes..
BTW, are you sure those are M5 and not M3/M4?
      02-01-2019, 01:37 PM   #92
itsnota2ma
itsnota2ma's Avatar
20
I actually think they are for an X5M. Those look like X5M brackets. I think the rears might be a newer X M series brake. But for the price, I could not pass them up. I know there are brackets on Ebay for like $300. Not sure about the rears, but I don't wonder if the M5 bracket might work.
      02-08-2019, 12:08 AM   #93
f10_will
f10_will's Avatar
Drives: F10 535 msport xdrive
Originally Posted by 187F10 View Post
Originally Posted by f10_will View Post
M6 brakes on my 535 front and rear
Will those fit a 550i ??
Yes
      02-17-2019, 11:36 AM   #94
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Those look like what I saw front and rear on a new M550 at the dealer yesterday... I thought it had nice front brakes but they cheaped out on the rear calipers.
Just picked up my 550i from the dealer and they had a X5M in the showroom with the blue calipers like that but the rear did not have the ///M label.
      02-19-2019, 07:03 AM   #95
Kwood-F10-535i
54
Drives: 2016 535I
Originally Posted by Bozman52 View Post
. . . so I'm still looking into brake mods for my 530d.
One thing that I hadn’t researched much up to this point was tangible evidence of the actual improvement these brake mods make, so I started looking into braking distances. The 550i has the larger front and rear rotors that would be an easy upgrade for my 530d, so I pulled up 550i braking distances. As I can’t get figures on an F10 with X5M calipers, I figured the M5 would be a decent comparator to judge what slapping on some Brembo multi-piston calipers would do. Here’s what I’ve found for 60-0mph braking distances:
530d- 118ft (http://www.zeperfs.com/en/fiche4317-bmw-530-d.htm)
550i- 116ft (MotorTrend)
M5- 110ft (MotorTrend)
M5- 113ft (http://www.zeperfs.com/en/fiche3969-bmw-m5.htm)
The short story is that there isn’t nearly as much difference as I’d expected. I appreciate that these braking numbers will have been done at different outside temperatures, on different track surfaces, with different tires, etc. Nonetheless, I really expected the M5 to stop a LOT quicker than the numbers I’m finding. Given that the mod I’m looking at would put 550i calipers/rotors on the rear and 4-piston X5M calipers/rotors on the front, I’d expect to see an improvement somewhere between the 550i and M5 numbers.
After seeing these numbers, I’m having a hard time justifying spending $1,200-1,500 on this brake upgrade just to shorten my stopping distance by a couple feet. Moreover, the X5M upgrade will add 7kg per front wheel to my car (and 2-3kg per rear wheel), so I’ll have to sacrifice some acceleration. Other than the obvious cosmetic improvement, I just can’t see why this would be a valuable upgrade to my 530d. I could put a full set of KW coilovers on the car for this kind of money, which would be a much more noticeable improvement!
I’m happy for dissenting opinions, as deep down, I totally want to do the X5M brake conversion . . .
Remember that the Weights of the cars you chose to compare are significantly diff rent than your 530d and each other.
530d 3,792Lbs.
535i 4,090Lbs.
550 4,200Lbs.
M5 4,288Lbs.
This being stated the stopping distance on your lighter car should be significantly better than the direct comparison you listed.
      02-21-2019, 04:13 PM   #96
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Keep in mind that while stopping distances may not improve significantly, fade resistance under high speed, high temperature braking circumstances will be drastically better and that's where you'll see the real improvements in larger rotors and better pads.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      02-23-2019, 09:08 PM   #97
Luky
Luky's Avatar
So what did you use for the brake pads for 34 11 6 794 464? OEM? I see Jurid at Bavauto and Pagid at eEuroparts for about $130. Are these any good? They don't seem to make akebono ceramic pads for this front fitment.
      03-24-2019, 11:49 PM   #98
Luky
Luky's Avatar
Does anybody know if the F02 760i/Alpina calipers will bolt up to the 550i with the 374x36 rotors?
I bought a set of used calipers from ebay just to get the carriers to add to my 550i calipers (was less than one carrier new), but now I am thinking of having the 760i calipers powder coated black and rebuilding them, then just swap out with my stock 817/818 calipers when I install the 374x36 rotors. The Calipers I bought are PN 34116786827 left side and PN 34116786828 right side. Can I still use the 550i pad wear sensor with the new bigger pads? Or do I also need the 760i wear sensors?
Brake lines should just bolt up? I am thinking maybe SS brake lines while I'm in there. I already bought the solid Bronze bushing/pin kit from ECS to install on the calipers too.
      03-25-2019, 10:27 AM   #99
DARKKN1GHT
29
Drives: 535XI
I cant speak for all brakes and brake carriers, as I simply used the entire caliper assembly when I did my test fitting. The brake lines all appear to be interchangeable along with the brake sensor, which can be reused as long as it isnt broken.
      03-25-2019, 07:00 PM   #100
Luky
Luky's Avatar
Did you rebuild any of the calipers you worked with? Looking at realoem.com the picture shows the rebuild "kit" (#10 )with the piston seal, bellows gasket and the piston. But when I looked for the cost for the kit to buy them they dont show the piston to be included? If I need to buy pistons any idea where I can find them?
      04-03-2019, 08:36 AM   #101
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I don't believe that the 760 calipers will bolt up to the 550 rotors. The reason being is that the brake pads are slightly larger in the 760 calipers, and as such, the hat of the rotor of a 760 is slightly smaller to account for this. Basically, I think the pads will rub on the 550 rotors.
The 760 rotors are different part numbers: 34116789543 and 34116789544
      04-03-2019, 08:41 AM   #102
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
Originally Posted by addy27 View Post
Here's my new setup from this weekend....(pardon the dirty wheels/car)
Zimmerman rotors, EBC Yellow stuff pads, ALPINA/760i Calipers/Carriers powder coated to match paint code used by Alpina on calipers (RAL 5002).
Did the calipers on Alpina B7s come painted like this from the factory? I know that newer B7s come with painted calipers, but they also have 4-piston calipers from what I can tell. However, I can't find any pics of F01 B7s that have painted Alpina calipers.
      04-03-2019, 12:00 PM   #103
Luky
Luky's Avatar
Thanks. I know the 760i/Alpina rotors are larger 374x36mm from the second post.
I pulled one of my calipers over the weekend and confirmed the 760i calipers are the same and bolt onto the 550i with the "taller" caliper carriers for the larger rotors. However I got a deal on a Stoptech BBK for my 550i and will be installing that instead. So I have the 760i calipers/carriers and the larger brake pads (new BMW OEM pads) to go with for sale if someone else wants to do this "upgrade". $350 + actuall shipping costs (~50lbs for the calipers and pads). They will need to be cleaned up (maybe painted), maybe replace seals, guide pins, rubber bushings (was my plan). You will also need the larger rotors. The larger 374x36mm 2 piece ATE (OEM) rotors were listed at $177 each from FCP Euro. This think would be a good upgrade for a 535i/550i and a lot less than a BBK. Probably can do the whole upgrade for under $800 and some elbow grease.
      04-03-2019, 12:26 PM   #104
DARKKN1GHT
29
Drives: 535XI
Yes I rebuilt them at home. I changed the seals only as the pistons were fine, the pistons are stainless steel and hardly ever get messed up from normal use. I think the pistons can be found online, they should be stamped with a part number on them. Its most likely a common brembo size piston.
      04-05-2019, 11:17 PM   #105
pf10
pf10's Avatar
Drives: F10 550i 535xi
Got mine done today with some help from DARKKN1GHT. I love it. So far no real difference in stopping range, I don't know maybe I need to break them in. Still trying to figure out what route I'm going to take with the rear setup because right now the oem 535i brakes looks too small compared to the fronts.
      04-16-2019, 07:24 AM   #106
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
That looks great! Well done! Regarding the rears, I think the easiest option is to bolt on the 550i rear rotors/calipers (345x24mm). My understanding is that anything other than this set up will require special brackets or fabrication to work. I know that some guys have retrofitted M5 fronts/rears, and there was some Russian guy who was selling a special bracket to make everything bolt up correctly, but the bracket alone was pretty big money. I'd have to dig a bit to find the details, though.
I know that you can get cross-drilled 550i rear rotors (at least in the UK), so that will help match the look of the fronts, even if the rotors are still not as big as you'd like: https://www.buycarparts.co.uk/zimmermann/7517745
Otherwise, you could do an aftermarket BBK for the rear, but then you're getting into some big money as well.
      04-16-2019, 08:35 AM   #107
pf10
pf10's Avatar
Yeah I'm getting the 550i rear rotors/calipers. I got some r1 concepts drilled rotors to match the look of the front. Should be installing them tomorrow, I'll post pics.
      04-20-2019, 10:43 AM   #108
Krueger84
Drives: 2011 535i
So, will I need to do any modifications to put the front/rear calipers and rotors from an E60 M5 on my 2011 535i? In not sure if I'm confusing myself by reading too much into it. I found a good deal on E60 M5 brake setup (front and rear), but don't want to buy if I can't use them.
Or would the better option be to replace them with the F01 front calipers/rotors and rear F10 550i calipers/rotors? If so, which 550i? U.S. spec of EU spec?
      04-20-2019, 11:18 AM   #109
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
That's a great question. It was discussed on the first page of this thread, but there was nothing definitive in there about whether or not an E60 M5 caliper would directly bolt onto the front of an F10 . . . so I'm actually wondering the same thing as you are.
Regarding E60 M5 rears, that hasn't been discussed on this thread to my knowledge, so I really have no idea. It appears the E60 M5 has a single piston rear caliper, but it has a much larger rotor, at 370x24.
So I have zero help but the same questions! Hopefully someone will chime in with answers, but I may do some digging on this to see if I can find more info about this brake conversion.
      04-20-2019, 12:12 PM   #110
Bozman52
Bozman52's Avatar
71
Drives: 2015 M5
I just did some searching on RealOEM and noticed that the E60 M5 rear calipers don't have an integrated parking brake, like the stock F10s do. I believe this issue is what prevents us from using F01 rear calipers, so I assume E60 M5s won't work either unless you can find a different solution for the parking brake.
5post
