10-23-2023, 02:17 PM | #1 |
Rep 2
BMW Shark Fin Antenna Cover Mount
I recently started getting a leak from my Shark Fin Antenna into the interior of my car. I need to replace the seal and seal the cover down again. Has anyone used any seal/tapes that worked for this? Has to be completely waterproof so that the Telecoms module underneath does not get ruined.
10-23-2023, 05:37 PM | #3 |
Rep 2
The problem with the 3M double sided tape is that it is almost impossible to curve it the way that the fin edges curve. I fear that it won't properly seal. I am wondering if anyone here has used any sealants that worked well to keep the water out.
10-23-2023, 09:00 PM | #4 |
Rep 16,089
Thinking about it if mine leaked I wouldn't pull it. Going by my Bentley manual that process is pretty daunting. I'd use a thin bead of UV cure glue around the joint.
10-27-2023, 10:16 AM | #5 |
91
Rep 250
Drives: 2014 BMW 228i, 2017 BMW M240i
I've used 3m double sided tape before and leaking isn't the issue. The issue for me was that it wasn't tall enough. I can't quite remember what I did to solve that but I'm 90% sure I ended up stacking the tape and it never fell off when driving 110+mph or through automatic car washes.
