BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Strut went through knuckle
ARMA SPEED
      02-18-2024, 12:46 PM   #1
Bim20k
Drives: BMW 440i
Last night while driving I went through few potholes and bumps. I later heard a rubbing noise at low speeds and a burnt rubber smell. I didn’t connect the dots at the time but when I checked today I saw that my strut went through the knuckle. There’s this very thick grease all over the fender and wheel well. I made it home safely and the car was driving normal even at freeway speeds.
There’s some thing I suspect that caused this to happen. I recently installed emd m4 springs (on factory struts). This car is also an xdrive. When I installing my springs I didn’t use knuckle spreader and just opened it with a chisel.
Can someone help me pinpoint what exactly happened and what I’m going to need to replace and repair now ?
      02-18-2024, 01:06 PM   #2
Charles B
Charles B
Charles B's Avatar
Drives: 335 M235 Z4 944 Turbo
2013 BMW 335  [9.17]
2016 BMW Z4  [10.00]
1986 Porsche 944 Turbo  [0.00]
Looks like the strut slipped downward in the knuckle, and it touched the CV boot, ripped the boot, and the grease inside spun out while driving the car. You probably didn't tighten the knuckle enough around the strut. So you need to reset the strut, make sure the bolt is tight enough and now you have to have the CV boot repaired (replaced) which is cheaper than a new axle.
      02-18-2024, 01:33 PM   #3
casualDIYer
Drives: 340i xDrive M Sport
Charles B +1
That must have be quite a pot hole for the strut to slip through the knuckle. Here would be my list of checks:
1) Take off the wheel and check for cracks or bends. Check for loss of tire pressure.
2) To be through, I'd take off the strut and check the knuckle for cracks. It's a aluminum. If it's cracked or bent , it's pretty much un-repairable. It controls camber and caster so if it's out of wack, you'll find it now becomes a full time tire killer. A new one probably runs $400 but I'd check your local wrecker.
3) Your anti-sway/anti-roll bar end link? That might be bent. Check it.
4) When putting the strut back into the knuckle, use a new bolt and tighten according to BMW torque specs
5) When you get the car in the air, before taking the wheel off, turn the wheel and listening for clicks in the CV shafts. If it is smooth, then you can get a repair kit for it. You will need grease as well. Does BMW sell a convenient $25 repair kit? Well, no. They sell $1200 CVs shafts. The death of $1.25 piece of rubber definitely requires a $1200 repair. If you hear click, a bearing might be dead here. Check local wrecking yards for a new-to-you CV shaft
5) I would also check the wheel bearing. Again, listen for the dreaded click of death. You will need to disconnect the CV shaft as there is no way to tell which of the two are clicking, unless they both click.
Good luck
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
cfm56d7b5886.00
      03-12-2024, 10:07 PM   #4
E90lova
24
Drives: F30 335xdrive
Funny how BMWs Rival Audi never has this problem.
      03-13-2024, 04:05 AM   #5
mmm-five
mmm-five's Avatar
222
Drives: 2006 Z4MC + 2015 320D M-Sport
      03-13-2024, 09:05 AM   #6
space_2001
space_2001's Avatar
78
Drives: F80 M3, E46 M3, G30 M550i
2018 BMW M3 ZCP  [10.00]
I’m pretty sure the designers deliberately had this knuckle design to avoid failure in the strut towers. It’s just unfortunate that it can wipe out a lot of other components, but then again it must have been a really bad pothole.
      03-13-2024, 10:59 AM   #7
freakystyly
Drives: F22 B58 6MT
Reminds me of this from a Porsche...
cfm56d7b5886.00
      03-13-2024, 12:18 PM   #8
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Attachment 3390911
Attachment 3390912
Attachment 3390913
Is there a reputable indy shop in your area? Through inspection is recommended at this point to ensure that any other problems are discovered and addressed at the same time.
      03-13-2024, 12:21 PM   #9
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
this was actually a huge problem on the BMW Z8, bmw released some official upgrades to reinforce strut towers as they were getting damaged from hitting potholes. I believe they released steel plates to reinforce them and strut tower brace.
