BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Driver side front wheel has more negative chamber. Please help!
GetBMWParts
      03-07-2024, 10:35 PM   #1
Lxil_Luci
Lxil_Luci's Avatar
Drives: 2014 335i X-Drive
Hello! I recently found out my front driver side wheel has more negative chamber than my front passenger side. Car still drives straight but it’s causing uneven tire wear. What would most likely need fixed/ replaced? Please refer to the images attached. No weird rattles/ sounds.
      03-08-2024, 07:29 AM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
I would start with an alignment
      03-08-2024, 08:02 AM   #3
freakystyly
Drives: F22 B58 6MT
How would the alignment shop adjust camber without camber plates?
A suspension component is likely damaged and needs replacing.
      03-08-2024, 09:41 AM   #4
alohasurftoad
You'll need to inspect it yourself or have a shop do it if you aren't able to.
The components that are easy to change are both upper and lower control arms and the strut/spring. If something else is bent it'll be much more difficult.
I wouldn't arbitrarily change parts without looking though.
      03-08-2024, 10:51 AM   #5
LA430
53
Drives: 430i
https://f30.bimmerpost.com/forums/sh....php?t=1608356
Easy to check yourself with wheels at full lock.
There’s no camber adjustment in the stock suspension so while an alignment will tell you how out it is, it won’t fix the issue. I wouldn’t even waist my time or money if it’s confirmed with uneven tire wear.
