BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > ► Official APEX Wheels Showroom Gallery Thread
ARMA SPEED
      07-23-2020, 08:39 PM   #89
MikeyMrtnz
MikeyMrtnz's Avatar
Drives: 2016 328i M Sport
Originally Posted by Stucks View Post
Looks good! Doubt it, but any rubbing? No spacers right? Do you think you had enough room to go a little wider on tire (say a 235 in front and 265 in rear?)
Thanks! No rubbing and no spacers. The recommended front tire size is 235/40-18 tires but 225/45-18 will also work which is what the original wheels had. Previously had staggered BMW 400Ms so I just used the tires I already had.
Handy fitment guide here:
https://support.apexraceparts.com/hc...-Fitment-Guide
Originally Posted by Expert@ApexRaceParts View Post
Loving the ARC-8s! Looks like a clean setup!
-Tom
Thank you!
      08-04-2020, 09:10 AM   #90
pauli18c
pauli18c's Avatar
Drives: 2017 340i RWD M Sport
Originally Posted by leadfoot12 View Post
Just installed some Anthracite EC-7s on my 340i! Love how it looks.
EC-7 specs:
245/40R18 MPS4S on 18x9 ET31
275/35R18 MPS4S on 18x9.5 ET43
Suspension:
Stock M Sport suspension
Alignment changes:
None, no rubbing.
Body modifications:
None
This is exactly the specs I was looking for, thank you
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup
      08-04-2020, 02:39 PM   #91
leadfoot12
95
Drives: 2016 340i
You're welcome.
Just to update, I'm lowered on Bilstein B14 coilovers now. Did about 0.75" drop in the front and 0.5" in the rear from M Sport suspension.
Had no issues with 2.2deg front camber and 1.2deg rear camber.
Currently running 1deg front camber and 1.2 deg rear camber.
No rubbing at all with any of the above changes.
Some pics:
Appreciate 3
      08-06-2020, 09:18 AM   #92
pauli18c
pauli18c's Avatar
You're welcome.
Some pics:
How much room did you have between the tires and struts / shocks on the stock adaptive? Do you think you could have fit a 255 in front and 285 in back?
      08-06-2020, 10:04 AM   #93
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
You're welcome.
Some pics:
Tried searching through the thread to find your wheels and tires spec, can't seem to find it.
      08-06-2020, 12:58 PM   #94
pauli18c
pauli18c's Avatar
Page 3 at the bottom
"Just installed some Anthracite EC-7s on my 340i! Love how it looks.
EC-7 specs:
Suspension:
Alignment changes:
None, no rubbing.
Body modifications:
None"
      08-06-2020, 03:13 PM   #95
leadfoot12
95
Drives: 2016 340i
I had standard M Sport suspension not the adaptive.
Not sure on those sizes. I'll try to get some pics of the strut clearance when I have time. I think the bigger concern would be clearing the fender liner in the front when turning the wheels. It's pretty tight as it is with the 245s.
      08-11-2020, 10:42 AM   #96
itsrichierich
Moto Lover
187
Expert@ApexRaceParts Do you guys have any experience with Yoko A052 fitment?
I should be getting my Arc8 (18x9 ET30) next week and looking into tires. After doing some searching, I have settled for Yoko A052 in 255/40-18 (squared setup). However, I hear they run wider than normal. Any experiences with this? Right now the car is on stock M-Sport EDC suspension but will be lowered on Bilstein PSS10 in 2 weeks.
Thanks!
      08-11-2020, 12:46 PM   #97
Expert@ApexWheels
Expert@ApexWheels's Avatar
3546
Drives: M3
Thanks!
Thanks for the question! We generally recommend a 255/35-18 for these wheels so the extra height of the 255/40 setup combined with the fact that the A052s run wide will likely cause some rubbing. If you can source a 255/35-18 A052 that would be the preferable size, or if necessary you can drop down to a 245/40-18. Considering you plan on lowering the car, the 255/35 tires will likely be the most ideal setup although you may need to dial in some additional front negative camber after lowering to clear your fenders.
-Tom
      08-11-2020, 03:34 PM   #98
itsrichierich
Moto Lover
187
-Tom
Tom, thanks for the fast response! Is -2 typically enough from what you guys have seen?
      08-11-2020, 04:08 PM   #99
Expert@ApexWheels
3546
Drives: M3
It's tough to make a blanket camber recommendation here as it will depend on how much you lower the car. We also have not tested this setup with the A052s as I said before. -2 degrees would be a good place to start if camber is needed, but first you should test fit the wheel setup to confirm that it is necessary.
-Tom
      08-11-2020, 04:43 PM   #100
fLatLinE-
15
Drives: 2016 BMW 340xi
Thanks!
-Tom
Have you guys tested this setup with Michelin Pilot Sport A/S 3+ in 255/35/18 on a 18x9 square setup? Am stock now but will be putting coil overs on down the line.
      08-11-2020, 05:11 PM   #101
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
EC-7 18x9 +31 square (xdrive)
255/35/18 Federal SS595
More space than I thought honestly, I could see the offset being slightly lower but love it either way
      08-11-2020, 05:14 PM   #102
itsrichierich
Moto Lover
187
Originally Posted by 328iX View Post
EC-7 18x9 +31
David, any way I can see your setup sooner than later? I want to buy tires tonight and would like to see your setup in person.
      08-11-2020, 05:18 PM   #103
328iX
David
328iX's Avatar
Sure, I could also get you pictures.
I don't have my alignment specs off hand, but got it done at the BMW dealership and they're within factory specs, it's not necessary to run any crazy negative camber.
      08-11-2020, 05:26 PM   #104
itsrichierich
Moto Lover
187
I have tried looking at pictures but I can't get myself to accept what it will look like.
I head up to Winchester from Escondido at 5, I can meet you briefly on the way home? I have a haircut appointment I need to get to so we have to make it quick. If you're out and about, great. If not, no worries.
      08-11-2020, 05:28 PM   #105
328iX
David
328iX's Avatar
Just give me an address and when you'll be there and I can drive out I don't mind
      08-11-2020, 06:11 PM   #106
Expert@ApexWheels
3546
Drives: M3
We have not tested this fitment with A/S 3s but at stock ride height generally these tires are a direct fit if they aren't aggressive summer or track compounds. Some of our customers have needed to add front negative camber or roll the rear fenders slightly in order for this tire size to clear.
If you are looking for a surefire direct fit, the 245/40s are a better option especially at stock ride height.
-Tom
      08-13-2020, 05:38 PM   #107
Constantinos
Drives: 2014 328 xdrive
APEX Arc-8 18x9 +30 squared with 245/40/18 Michelin P/S 3+
View post on imgur.com
      08-14-2020, 12:24 PM   #108
Stlblues
Stlblues's Avatar
Drives: BMW 340i Xdrive
Picture doesn't work
      08-16-2020, 05:48 PM   #109
Runner340
Runner340's Avatar
369
Drives: F30 340i xDrive
18" ARC-8's Powder Coated Gloss Black on F30
https://www.amazon.com/photos/shared...ed-nwwn7CLNIiX
      08-20-2020, 12:30 PM   #110
Sidewinderpb
Drives: 2017 340i xDrive 6mt
Originally Posted by ApexRaceParts View Post
Perfect fitment on our customer Egor's F30 featuring 18" FL-5 wheels.
Front:
18x9" et30 FL-5 wheels
245/40-18 Hankook Ventus V12
Rear:
18x9.5" et35 FL-5 wheels
255/40-18 Hankook Ventus V12
BC Racing Coilovers
Would you happen to know if a squared setup (FL-5; 18x9 et30; 245/40-18) clears with KW V1 on an xDrive? Looking to achieve similar fitment.
