11 BMW 328i Eccentric Shaft Actuator Motor installation question.
09-26-2023, 10:31 AM | #1 |
Rep 20
I am replacing the valve cover gasket and have following question.
To remove the Eccentric Shaft Actuator Motor the steps are: 1. use a T25 (or 4mm Allen wrench), turn the motor service port clockwise till stop. 2. Remove all three bolts 3. Turn the motor counterclockwise to get it off. Instructions all saying reverse steps for install but not sure if the following steps are the correct "reverse sequence": 1. Turn the motor service port clockwise so it gets into the position and locked 2. Install the three bolts 3. Turn the motor counterclockwise to work mode Thanks. |
