11-07-2012, 09:30 AM | #265 | |
Love All
170
Rep 740
11-07-2012, 09:46 AM | #266 | |
Love All
170
Rep 740
Connect to the car As usual read FA and SVT Now save FA and SVT to a location of your choice but outside E-Sys. In the process save all the cafd files too Disconnect ESys You are now ready for off line reading. Start ESys Don't press connect button Press load to load saved FA (this may be optional) Press load to load SVT Right click on any green cafd file marker and New>FDL Point to the right saved cafd file Now follow your steps |
11-07-2012, 10:57 AM | #267 |
10
Rep 33
Thanks April!
Perhaps you can give some further quidance based on following info: My psdzdata folder "c:\ESysSData\psdzdata" contains all files extracted by WinRAR from the original psdzdata 47.4 rar -packages (using all the 23 downloaded *.rar files). In the "psdzdata\mainseries" subfolder there are some additional folders & files generated during the installation. The data files in psdzdata were just extracted by WinRAR and there was no any other processing before using them, is this ok ? The "status" of the other subfoldres in the ESysData -folder is: CAF - no files here EST - two files here, e.g. Code Away.est Etc - no files here FA - on sample xml file here FP - no files here Logs - several log files ODX - no files here Rules - three .jar files SWE - no files here SVT - no files here SWT - no files here TAL - no files here ...and My car is X3(F25) built on 9/2011. |
11-08-2012, 08:03 AM | #268 | |
9
Rep 85
Drives: 2022 X3 M40i
11-08-2012, 08:17 AM | #269 | |
General
10515
Rep 41,040
If you want to look at an unread CAFD file, launch the CAF-Viewer, and then navigate to your CAFD folder (C:\ESysData\psdzdata\swe\cafd) and select the desired CAFD.
11-08-2012, 08:47 AM | #270 |
9
Rep 85
I have tried both your way and April1 and I get an error message "No EST file chosen". I have associated the cadf files to the SVT but still can't get any further.
11-08-2012, 09:31 AM | #271 | |
General
10515
Rep 41,040
Launch E-Sys, and Under Options, Settings: On the EST Tab, set the Developer-Soft-Token EST Path to "C:\ESysData\e-sys est\Code Away.est" Also, while there, make sure that on the PROGRAM TAB, you set the Directories - Data Path to C:\ESysData
11-08-2012, 09:57 AM | #272 |
9
Rep 85
11-17-2012, 11:39 PM | #274 | |
Love All
170
Rep 740
psdzdata folder should have following sub-folders: extLibs kiswb mainseries mapping security swe temp please check that there is a dist folder in each of the odx folder of sub-folders of odx of each series. Other folders and contents are corect as stated by you. |
11-18-2012, 01:49 AM | #275 | |
General
10515
Rep 41,040
11-18-2012, 02:07 AM | #276 |
Love All
170
Rep 740
Yes ESYS creates the temp folder, so it can be ignored.
11-29-2012, 08:51 PM | #278 |
Rep 859
11-30-2012, 04:57 PM | #280 | |
29
Rep 165
close trunk/tailgate with key fob and with driverside button DVD in Motion disabled iDrive and camera disclaimer temp and pressure to TPMS screen show gear (S1-S7) in sport mode pressure and temp readings in TPMS unlock doors when engine stops close mirros+windows+moon roof through key fob and comfort access fog lights w/high beams digital speed displayed in BC set auto stop/start to last setting by default Also coded weatherband Last edited by X3Bimmer; 12-04-2012 at 08:30 PM.. |
12-01-2012, 03:16 PM | #282 |
General
10515
Rep 41,040
EGS module, set both of these to aktiv:
Sportschalter Sportschalter_alt
12-01-2012, 04:57 PM | #283 |
9
Rep 145
Drives: 2016 M235xi
Finally got a chance to do some coding ... reminds me a little of changing registry settings in windows anyways got:
DVD in Motion Disabled iDrive and camera disclaimer More tommorrow. Big thanks to April1 got his coding kit and works perfect right out of the box ! |
12-02-2012, 07:52 PM | #284 |
Noice
125
Rep 217
Drives: 2023 BMW iX 50drive
Hey guys, I just tried coding and I am missing modules such as HU_CIC and CMD_Media??
Any ideas why? I was able to code BKOMBI and gain access to the MPH on the BC Any immediate help would be gratefully appreciated
2023 BMW iX xDrive50 - Blue Ridge Mountain Metallic / Oyster Perforated / Ultimate PKG 2 / Sport PKG
2023 BMW X1 xDrive28i - Portimao Blue Metallic / Black perforated /Shadowline/ M sport / premium package |
12-02-2012, 08:03 PM | #285 |
General
10515
Rep 41,040
Your Head Unit is HU_CHAMP instead of HU_CIC because you do not have 609 Navigation. You do not have CMB_MEDIA, because you do not have 6VC Combox. And as you already discovered your KOMBI is BKOMBI for basic Instrument Cluster.
12-02-2012, 08:08 PM | #286 |
Noice
125
Rep 217
that sucks! so i can't unlock half of these cool new features!!! very sad day indeed wasted money on a cable for nothing
