Power for boost gauge and map sensor
07-12-2015, 08:21 PM | #1 |
39
Rep 259
Hey guys,
Just checking where you guys scab power for auxillary devices? I need to find a 12V accessories wire which is always on the the car is on. Was thinking the back of the stereo? Splice into accessories off that? Can go off the fuse box but thats a lot of work. Any other ideas? Boost gauge will obviously be mounted in the car so around the dash would be good. |
07-12-2015, 10:39 PM | #2 |
Rep 1,426
you can use the ciggy lighter under the shifter trim or theres a empty fuse in the fuse box. FUSE 5! to be exact. which can be tapped with one of these
07-13-2015, 02:56 AM | #3 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
You can also use the cigarette lighter BEE35i.
But what nate posted would probably be easier, i use tapafuse to wire my dashcam. |
07-14-2015, 06:19 AM | #6 |
619
Rep 3,021
I have a dash cam and a 3 socket cigarette charger (wired in) with no issues.
07-14-2015, 07:43 AM | #8 |
619
Rep 3,021
07-14-2015, 08:41 AM | #10 |
Buy a 335 they said... It'll be fun they said...
117
Rep 995
Drives: 2007 E92 335i
I don't get why people need boost guages in the 335...?
It's not a custom turbo job, the computer knows where the boost is and it knows how to use it... just let the computer do its thing. |
07-14-2015, 06:46 PM | #11 |
Rep 1,426
its accurate but a tad delayed. Scotty, having a boost gauge can be very useful because when you idle it sits at a certain kPa, so if you have a vacuum leak you'l be able to tell straight away, also when you wot and you dont hit peak boost, you know you have a problem.
07-14-2015, 06:48 PM | #12 |
Rep 1,031
Drives: 335 E92 DCT
Cos he's from Turbosmart and probably making something cool
Certified Australian
07-15-2015, 02:55 AM | #13 | |
117
Rep 995
07-15-2015, 03:06 AM | #14 | |
619
Rep 3,021
He may have plans for other things requiring a direct boost gauge. I.e. BOV for N55's etc etc |
07-25-2015, 05:16 PM | #15 |
74
Rep 197
Drives: e93 N54 335i MHD TUNED
Boost gauge ftw it's a great tool to have, vacuum leaks and peak boost levels. Good to know how much boost your running when your tuned.
07-25-2015, 05:30 PM | #16 |
117
Rep 995
With a guage mounted like that, the cops would bend you over so hard.
Mounting in front of the main instrument cluster is screaming "I'm tuned! Give me a defect notice!" |
07-25-2015, 06:07 PM | #17 |
Rep 605
I've recently ordered the ECS boost gauge, and it should be arriving soon.
I wanted a boost gauge because: 1. Ive recently had troubles with not hitting peak boost after a couple of WOTs. Seems to be resolved now through tuning, but if i had a boost gauge it would be much easier to tell when to stop logging after getting the problem. 2. With my Wedge flash, boost level is going so close to the TMAP sensor limit, i'd like to be able to see if it goes over and the DME can't see it. Being connected directly to the vacuum line I get a true indication of boost. Until putting in an N20 sensor recently, it was hitting the limit at ~21.5psi. 3. As Nate said, easier to spot boost leaks. 4. Having something permanent is more convenient than connecting an App for daily driving. I went with the ECS one because it looks the most stock. I looked at the steering column mounted ones and they appear to really block vision, and just look really boy racer IMO. I agree with Scott that its a bit pointless in respect of seeing anything quicker than the DME can. Realistically while driving at full blast you can only safely check it for brief moments, so its best to leave that sort of thing up to the DME (or JB4 for many people), which both do a very good job at controlling boost. But proper logging is always the best diagnostic tool, and a boost gauge is just a secondary measure. For me it will be good piece of mind that the tune is doing what its supposed to be doing. |
07-25-2015, 06:34 PM | #18 | |
Rep 11,905
07-25-2015, 06:40 PM | #19 |
Rep 605
In the centre vent.
http://www.ecstuning.com/BMW-E92-335...ges/ES1306696/ I'm running under the assumption that centre vents are the same between LHD and RHD cars... hope it fits |
07-25-2015, 07:01 PM | #20 | |
Rep 11,905
07-25-2015, 07:18 PM | #21 | |
Rep 11,905
I've gone with this kit http://www.ecstuning.com/Search/Site...Pod/ES2588091/ |
