07-01-2019, 01:14 PM | #70 |
Rep 1,818
I've been driving on 2wd mode in my F31 for over a year now, via ESYS FDL coding. Not done through your phone, but it's a money saving option.
It's basically for being foolish with the car and doing massive slides. It doesn't benefit you in any other way. For them to suggest you can use it as an alternative to repair is ridiculous.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
07-01-2019, 01:19 PM | #71 |
That Libertarian Guy
4039
Rep 6,363
Seems silly, your driving a rwd bmw with 1000 extra pounds because of the disable awd system.
floridaorange10284.50 |
07-01-2019, 02:02 PM | #72 |
Rep 1,818
It's about 250lbs, but point made.
It is silly. The diesels don't care as much for the extra weight, but the additional friction does add up. If one would want to remove the front wheel hardware, you can remove axles, front differential, and front driveshaft.. however you'd need a cut axle stub to bolt in place of the axle end, because it holds the bearings together.
07-01-2019, 02:17 PM | #73 |
Rep 776
07-01-2019, 03:35 PM | #74 | |
Rep 1,375
-Nick |
07-01-2019, 04:50 PM | #75 | |
24
Rep 11
https://www.schmiedmann.com/en/produ...3-10-7-555-607 Fits only models with automatic transmission (S205A), or sport-automatic transmission (S2TBA) F30 Sedan 335i 335iX F31 Touring 335i 335iX F32 Coupé 435i 435iX 440i F33 Convertible 435i 435iX 440i F36 Gran Coupé 435i https://www.realoem.com/bmw/enUS/par...&q=33107555607 "The specified part was not found" Last edited by retypeNick; 07-01-2019 at 05:12 PM.. |
07-01-2019, 05:11 PM | #76 |
No 55mph
1622
Rep 8,477
I didn't say F36 AWD specifically, stated includes xdrive models - normally this relates to F30 & F32 335ix & 435ix
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
07-01-2019, 05:18 PM | #77 | |
24
Rep 11
I dont understand why F36 GC xDrive will not support OEM M-performance LSD as all other models basically support it |
07-02-2019, 12:43 PM | #78 | |
Rep 1,818
DSC > 3000 > C_Funktion_LaengsMomentVerteilung_aktiv_e > aktiv to nicht_aktiv You will get a DSC fault for "Subfunction coded out", meaning that the DSC system is checking against the VCM for vehicle type, and finding out it was tricked. However everything works fine as it should, and you still have all your modes available. The transfer case actuator will remain open. There are a couple of ways to get the DSC to not have that error and check control message, but that's beyond the scope here. Any esys expert can take care of that, changing vehicle type, etc. Then have some fun. I could have roasted the tires a bit more in place, but this was my dad's driveway. Permanently burned 11s not appreciated.
e46m3to335i171.50 |
07-02-2019, 12:48 PM | #79 |
Rep 1,818
Also, the title of this thread is implying that there is something wrong with xDrive, and this is absolutely not true. It's a great upgrade over the previous generation system in terms of function and some reliability. It's not perfect (re: output flange), but closer to it than before.
07-02-2019, 11:12 PM | #80 | ||
81
Rep 168
07-03-2019, 04:50 AM | #81 | |
No 55mph
1622
Rep 8,477
It clearly lists the xdrive cars as in my post as being compatible on every site that sells them & realoem.com In realoem the MPerf diff is under the retrofit/conversion/accessories section https://www.realoem.com/bmw/enUS/sho...diagId=03_1127 Plus the fact that I have a 435iX, just had the MPerf diff installed & it worx fine Couple others with AWD have had them installed also with no problems Remember, you can't believe everything people post on the internet - just because they post doesn't mean they have any idea what they are talking about...
Insane435480.50 |
07-03-2019, 08:00 PM | #82 |
Rep 1,169
It doesn't fit your xDrive or mine either. Car on invoice is an automatic, part number they attempted to install is #33108659989.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
07-06-2019, 12:18 PM | #83 |
24
Rep 11
07-06-2019, 02:17 PM | #84 |
No 55mph
1622
Rep 8,477
Yes, unfortunately the P/N I listed does not fit F36 xdrive, or 340 xdrive
Fits only: F30 335ix USA/EUR F31 335ix EUR F32 435ix USA/EUR F33 435ix USA/EUR
07-07-2019, 10:05 AM | #86 | |
Rep 1,934
It just sounds like jealousy that you can't have the option of both, and now xdrive users can.
07-07-2019, 10:58 AM | #87 |
Rep 776
Rwd car will never be the same as x delete until the xdelete disconnect is at the front hubs. Even then it's still going to have extra weight, and different suspension options.
07-07-2019, 01:21 PM | #88 |
Yoda of mods
1678
Rep 3,008
Drives: X5 RWD
Yup.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
