05-04-2014, 12:54 PM | #67 | ||
M Power
43
Rep 50
2011 135i M Sport LeMans Blue (sold)
2016 M235i Estoril Blue (sold) 2016 M3 San Marino Blue |
06-19-2014, 10:25 PM | #68 |
25
Rep 216
Has anyone thought about running the kit with swift springs?
I like the idea of the B12 kit but not the idea of dropping by an inch. I think the swifts would drop it slightly less? |
06-20-2014, 12:22 PM | #69 |
Resident Tamed Racing Driver
298
Rep 4,697
Why not just get the Bilstein struts and run them with stock springs? Factory BMW springs are pretty damn good.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
06-20-2014, 02:40 PM | #70 |
Rep 3,856
06-20-2014, 02:59 PM | #71 |
298
Rep 4,697
No, but I would if I was using off the shelf Bilsteins or Konis(like my fiance's ZHP). The TCKs are developed with the springs they use for a comprehensive package. I don't entertain even the slightest thought that I am at TC Kline's level when it comes to suspension development.
Food for thought though, BMW puts enough care into their spring rate choices that individual options change the rates you get from the factory.
06-20-2014, 03:13 PM | #72 | |
Rep 3,856
06-20-2014, 03:31 PM | #73 |
298
Rep 4,697
They used to compared to most. Apparently not anymore though. Amusing recent C&D where the F30 lost a comparo to the E9x thanks to its awful unpredictable suspension.
06-20-2014, 03:51 PM | #74 |
Rep 3,856
06-20-2014, 05:53 PM | #75 | |
25
Rep 216
The b12 kit uses the b8 struts? Maybe combined with the BMWP springs it would be a nice setup with a small amount of drop. |
06-21-2014, 06:39 AM | #76 |
Rep 1,317
That's certainly not my experience.
I found the OEM 135 M-Sport to be severely underdamped and over-sprung. But that maybe the more to do with the nature of our UK roads which BMW clearly didn't design the suspension for. Fortunately Birds Tuning in the UK had a solution, albeit an expensive one...
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass.
06-23-2014, 08:03 AM | #77 | |
298
Rep 4,697
07-01-2014, 03:04 AM | #78 |
Rep 701
What size of front tire is everyone running with this kit?
Any rubbing at full lock? Alignment specs? Camber plates?
07-02-2014, 05:28 PM | #79 |
Rep 701
07-03-2014, 12:31 AM | #80 |
S58 Love
490
Rep 432
Drives: 2023 M4 Competition xDrive
225 - No camber plates - No rubbing
MAC
Current: 2023 G82|BG over BLK Prior: 2008 N54 E82|AW over CR Also: FJ60, Volvo Recharge |
07-03-2014, 04:09 PM | #81 |
Rep 701
Thanks.
07-11-2014, 10:49 AM | #82 |
Rep 172
Soooo....I've had this kit for a little over a year now. And I swear that I got an alignment right after install. Anyways, I've noticed some questionable tire wear lately up front, so I took it into a very reputable alignment shop to get it checked out and possibly aligned. The same shop that aligned it the first time. I just got a call from them saying that the car is too low to do the full alignment. I guess he was able to check the camber and caster up front, but either checking the toe or adjusting the toe is out of the question because it is too low. I'll be getting more details at lunch. Has anyone else run into this issue? This place does a ton of track cars, which is weird because they are usually pretty damn low.
UPDATE: He said he couldn't get equipment on the front to measure toe and thrust angle. He said he could manually dial toe in, but the thrust angle would be off. Last edited by dubluv17; 07-11-2014 at 02:17 PM.. Reason: Update |
07-11-2014, 05:25 PM | #83 |
40
Rep 323
07-11-2014, 08:33 PM | #84 |
Rep 4,040
Drives: 130i coupé ;)
Photos, Links or GTFO LOL
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
07-11-2014, 08:40 PM | #85 |
40
Rep 323
this will have to do for now. Still havent had a chance to take a full shoot
http://www.1addicts.com/forums/showthread.php?t=987716 |
07-22-2014, 02:22 AM | #86 | |
Rep 701
07-22-2014, 04:53 AM | #87 |
Rep 1,409
Im running stock linear springs and struts on my 2011 135i, camber plates and M3 control arms. I track the car a lot and use a square style 261 wheel and 255/35R18 tire setup and 10 mm spacers in front.
Would my tire setup clear the B12 kit with no rubbing?
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
07-23-2014, 10:19 AM | #88 |
9
Rep 65
Thats hard to answer, depends on your wheel offset and how close you are to rubbing right now.
MKV GTI - Gt3071r/ 400Whp - Sold
2010 135i |
