New 2009 2010 BMW Z4 - ZPOST
      08-10-2010, 05:12 PM   #67
Roadstergal
Roadstergal's Avatar
Drives: 2010 Z4 35i
I would go to another dealer. I had the whining noise and I first tried to run the car with a full tank and did not let it get below 1/2 to no avail. I brought the car in and they replaced the lpfp right away. I asked the SA if he used diagnostics or just listened to it to make the determination to replace it and he said that they simply listened to it. That was about two months ago and I have not had a problem with it since. It is as quiet as it was when I first took delivery.
From reading the posts here, I think I may have brought the problem on by allowing the tank to get down to 1/4 full a few times. Since I had the lpfp replaced, I will not let it get below 1/2. I would fight them on this. It is not normal or enjoyable to drive the car with that much noise.
E89 - 2010 Z4 35i (Orion Silver, Ivory White extended, anthracite trim)
E85 - 2006 Z4 3.0i (Monaco Blue, beige leather, Dark Poplar wood trim)
E85 - 2003 Z4 2.5 (Sterling Gray, black leather, Sycamore wood trim)
E36 - 1998 Z3 2.8 (Red, black leather, wood trim)
      08-10-2010, 05:17 PM   #68
davidmbell
davidmbell's Avatar
17
Drives: 2012 E91 318d Exclusive
Two more clips taken this evening with FULL TANK of fuel - you know - the thing that was meant to quieten the noise down....
http://www.davidmbell.com/z4/whine3.mp4
http://www.davidmbell.com/z4/whine4.mp4
(700kb files!)
Can those who had theirs replaced already and then told that it won't be replaced again but a software fix will be implemented please update us on progress?
Thanks
David
2012 e91 318d Touring
Executive Edition
Vermilion Red
Automatic
Business Nav
      08-10-2010, 06:04 PM   #69
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
Drives: Like a Demon!
2010 BMW Z4 35is  [10.00]
2013 BMW X5 30d  [0.00]
Making us drive the car with the tank above half full is not an acceptible solution in my book.
55 litres is a small tank to start with.
Making us limit ourselves to 25 litres between fill ups is a crazy limitation.
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-10-2010, 09:15 PM   #70
teagueAMX
teagueAMX's Avatar
Drives: Some are road worthy
(700kb files!)
Thanks
David
That's crazy! Absolutely unacceptable.
What bugs me is the dealer has nothing to gain by putting the screws to you.
Go to a another dealer. Don't know what sort of issue resolution system you have in the UK, but I would use it and not give up until that is fixed!
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
      08-10-2010, 11:53 PM   #71
tranquility
sportscars only
tranquility's Avatar
3291
Drives: 2011 Z4 sDrive 35i
Sorry to hear about your prb, David. Have you tried my very non-scientific way to see if the noise cuts off if you brake hard? ***If you want to test this, please do it on an empty road w/ no one behind/around you.*** When I brake hard (when I had the noise), the noise would cut off and go back on, almost as if the sloshing fuel had something to do w/ muffling the sound. Mine had the same noise as yours but now it's gone, even though your mileage is higher...who knows, maybe it'll disappear like mine. ...but of course, you should really get a good solution instead of the dealer ignoring what is an obvious prb here.
      08-11-2010, 12:18 PM   #72
zEdP
Ed
Netherlands
18
Drives: Z4 sDrive30i
I'm very disappointed with the car itself and the dealership and don't know what to do now. Try another dealer? Live with it till the bl\\dy thing breaks down AGAIN!?
A dealer does not decide if a repair is covered by warranty or not. It is BMW who does. So BMW rejects noisy pump warranty claims. Visiting a different dealer won't help. You have to contact BMW directly and make them clear that you are not happy with the noise.
In my case, the pump made a different noise than yours. First BMW rejected the requested because they assumed it was the 'standard' high pitch whine sound. After they heard the low humming sound, they decided to approve the replacement. It took almost 3 working days before the dealer got the approval.
EdP
      08-11-2010, 06:08 PM   #73
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
People being people though, (in my experience) it is common for a dealer's service advisor or service manager to take the initiative and decide they will not even ask the manufacturer. I would not be surprised if this barrier is what has been experienced in this case.
If BMW had globally stopped fixing this problem after sooo many have been fixed / repaired so far, I believe we would be seeing an avalanche of people here complainign of this change in BMW policy on the fix.
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-11-2010, 06:17 PM   #74
Roadstergal
Drives: 2010 Z4 35i
EdP
When I took mine in, they immediately telephoned me within a couple of hours to let me know that they were replacing the pump and that I had to leave my car overnight. They also stated they were overnighting the part.
I agree with Dr Stig that it is the dealer calling the shots on this one.
      08-12-2010, 05:10 AM   #75
Phat Cat
Drives: 2009 Z4 35i
Hi all:
My 2009 3.5 has already gone thru HPFP failure and is exhibiting this rear whine since return from that repair. It seems to be getting louder over time. Has anyone actually had their LPFP fail as a result? TIA
      08-25-2010, 09:33 PM   #76
tranquility
sportscars only
3291
At over 3,200kms, unfortunately the 'whining' noise has come back. Now instead of an 'on and off' sound, it is a low constant noise at idle and at low throttle (I wonder if it's always there when the engine is on, just that when at high throttle the engine noise blocks out this 'whining' noise?).
Anyway, I'm wondering if members have a permanent fix for this...I know Roadstergal replaced hers and it seems fine now, but I think she is not going below 1/4 tank just to be safe? Is there anyone else w/ this issue resolved? Thx.
      08-25-2010, 10:06 PM   #77
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
as a rule of thumb, regardless of car, i never let it go under a quarter tank. and i don't baby my car, i beat it into submission every chance i get, that cleans all the build up in the engine. all my cars have never failed for the length of time i've held them. i'm not saying scratch it and slam the wheels on curbs and doors on other cars...
      08-25-2010, 11:02 PM   #78
flpnout
flpnout's Avatar
Drives: 2010 Dinan S3 Z4-35i
2010 E89 Z4  [7.83]
Mine is resolved, but it also took an entire tank replacement and I still wait until I am below 30 miles left on gas. I've gone as low as 8 miles at one point. I know I heard it is not good to drive it that low. I think I just hate going to the gas station..... I wish they made the tanks a little bigger.
2015 BMW i3 REX
      08-25-2010, 11:45 PM   #79
teagueAMX
teagueAMX's Avatar
I'm glad to hear you got some resolution on it. Seems I remember you were pretty upset with you Z so maybe you feel better about it?
      08-25-2010, 11:59 PM   #80
flpnout
flpnout's Avatar
2010 E89 Z4  [7.83]
Haha. Yeah I feel better now, therefore I cancelled the M3 order....lol
Time to continue my planned mods..... Thanks for asking!
2015 BMW i3 REX
      08-26-2010, 12:03 AM   #81
tranquility
sportscars only
3291
Ya, I never let it go below 1/4 either...well, maybe once it was a bit below 1/4 before I filled up. Still, the noise comes whether I'm full or 1/2. It's a bit aggravating.
Wow, that's good to know! What exactly was your prb...the LPFP or the tank as well?
You came back to your senses lol.
      08-26-2010, 12:07 AM   #82
flpnout
flpnout's Avatar
2010 E89 Z4  [7.83]
Yeah but my sales man insisted on keeping the order.....He is betting that once I see it, I will want the M3 especially in the new Mineral White ZCP package. They never took a deposit since they know I go through so many....lol I've been told many times that the Z4 looks best and I should stick with it. Besides, I would miss the low end torque if I did. The Z4 is a handful and a blast to drive.
2015 BMW i3 REX
      08-26-2010, 12:13 AM   #83
tranquility
sportscars only
3291
Yeah but my sales man insisted on keeping the order.....He is betting that once I see it, I will want the M3 especially in the new Mineral White ZCP package. They never took a deposit since they know I go through so many....lol I've been told many times that the Z4 looks best and I should stick with it. Besides, I would miss the low end torque a lot!!
Depends what you want. The Z4 is the best looking BMW imo right now. The M3 looks very powerful but is 'just' the top-of-the-line 3-series.
Btw, how did your service ctr diagnose your noise tank prb? Did they have to drive it or just let it run on idle? I guess they replaced the WHOLE tank, including the LPFP and everything else inside?
      08-26-2010, 12:15 AM   #84
flpnout
flpnout's Avatar
2010 E89 Z4  [7.83]
Yup LPFP, changed out in tank fuel pump, then the entire fuel tank.
2015 BMW i3 REX
      08-26-2010, 12:24 AM   #85
flpnout
flpnout's Avatar
2010 E89 Z4  [7.83]
The shop foreman got in my car, listen to the idle, heard the hum, then drove it to another Z4 on the lot and compared the noise. He agreed that it was NOT normal. So they changed out the LPFP. After I picked it up and drove home, noise came back. Brought it back in and they recommended to change entire fuel tank. And that seems to have taken care of the problem so far.
2015 BMW i3 REX
      08-26-2010, 12:39 AM   #86
m999psw
Drives: 35i
Hi,
I have had the software updated now which included a mod for the LPFP and to my and the managers surprise the noise has gone. Fingers crossed it stays that way.
      08-26-2010, 10:50 AM   #87
tranquility
sportscars only
3291
Originally Posted by m999psw View Post
Hi,
Did you mean a software update for the LPFP or an actual replacement?
      08-27-2010, 12:52 AM   #88
m999psw
Drives: 35i
A software upidate only.
zpost
