The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > 2013 Map updates - USB Stick
      12-26-2013, 09:30 PM   #727
gwavz
Drives: 2009 335i 2D Coupe E92
Hi guys, does anyone have updated maps for Australia please?
Road Map Australia New Zealand PREMIUM 2013 or 2014 if availlable.
      01-16-2014, 11:09 PM   #728
Killemall
Drives: E92 M sport
email sent
      01-25-2014, 08:30 AM   #729
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Any updates for ccc idrive?
      04-28-2014, 08:24 AM   #730
The.Lows
Drives: E91 330i '08 (272hp)
Hello,
After reading the 36 pages of this very interesting thread, I need to talk :
I have a E91 LCI 330i from October 2008, fitted with a GPS Pro CIC (large screen). The current map is "ECE BMW 1.2.4 Road Map Europe PREMIUM 2008-2".
I would like to update the map to 2014 (6 years of udpate won't hurt). My concerns are :
1/ How can I know for sure if I need a firmware upgrade prior to the map update ?
2/ Is the USB map update more reliable than the DVD map update ?
Thanks for keeping this topic alive
      08-11-2014, 06:47 PM   #731
pshovest
BMW CCA 69606
89
Drives: '15 435i,'10 535i,'08 X5,'98M3
Emailed 1:30 PM for 2015-1 maps
PayPal sent 2PM.
Download completed
Activation code received 9:30PM
Maps installed by 11PM.
WoooHoooooo!!!
Everything works great! Thanks!!
      10-20-2014, 02:41 PM   #732
gxt6551
Drives: 07 BMW 335i coupe Sport
PM sent. thank you.
      03-13-2015, 02:24 AM   #733
bobbychoo
Drives: 325i M-Sport
Hi everyone!
I've a Dec08 CIC and I tried to update my navi's map to the latest version.
(...should have read this thread before embarking)
Anyway, the USB did not get detected. I know it works because I tried importing songs.
Then I burnt the navi files onto a DL DVD. Popped it into the drive. Very happy that it asked for a FSC code. Entered it. It went on until close to 20% and then trouble... the update refused to proceed further.
And now, the CIC restarts itself every 2 ~ 4 minutes. The other functions of the CIC still work well though.
Hope to get some advice on what to do next...
Many thanks!
      03-13-2015, 04:28 AM   #734
GreQonE
Poland
34
Drives: '2011 E92 LCI 335i
Probably there was some error on the disc, making a part of it unreadable.
Try again with the usb sticks (Make sure they are formatted FAT32, and you follow the guides)
      05-02-2015, 02:05 PM   #735
viperrj
viperrj's Avatar
Drives: 2011 335d AW
Hope this thread isn't too old. I wanna get the map update but does anyone have any ideas on how to upgrade the iDive as well? Not the Mx/Tx but the iDrive itself to get connected drive and the apps. Can it be done remotely? Sorry for the hijack.
2007 e90 (retired). I miss you babe
      07-20-2015, 03:36 PM   #736
Snootyfox
Drives: Series 3-320dm sport coupe
FSC code price
Hi, could you please pm me the cost of the FSC code and instructions for CIC europe west premium 2015-2 update.
      07-23-2015, 02:00 PM   #737
Boka
Drives: 2009 328xi
Hi Baccus. I have a 2009 328xi with the old North America PREMIUM 2009-1 maps. Would like to get this updated. Thanks
      08-29-2016, 08:58 PM   #738
amiralshoq
Drives: bmw
3steps to generate BMW CIC& NBT FSC Code
here what i fund but it dosnt work when i tray to connect the cable
software program, easy 3 steps.
Equipments needed:
FSC Code Generator software
ENET (Ethernet to OBD)) cable
EDIABAS Tool32 software
FSC CODE Calculator Software for BMW Navigation can be free downloaded from search engines:
http://www28.zippyshare.com/v/20206387/file.html
Password: “Eintracht_Frankfurt”
Or you can get from other search engines
In addition, you’ll need an ENET cable and a working EDIABAS installation on Win XP 32-bit. 64-bit will properly not work.
Disclaimer: You are on your own risk. It will generate the codes for BMW North America Premium 2014.
This was tested on a 2012 F30 with CIC.
It generates the FSC in three steps. But you have to change the “year-parameter” in the batch-file to a later map (e.g. 2016 – or even later – instead of 2014), then it works perfectly.
The Default 0x06 for 2014 does not work, but 0x09 does!
Main steps:
1) READ FSC
Open FSC Generator software on desktop
Click “Read FSC”
Select BMW chassis, e.g E-series
Click Connect
Click Read VIN
The software will display vehicle information
Click Read FSC (1B)
Click Save to File
Exit
2) DECODE FSC
Back to FSC MAP menu
Select DECODE FSC button
Click Load file and load dump bin file
Click “Search” and browse to C:/EC:APPS/a hex
Click Decode button
Finish decoding
3) GENERATE FSC
Select “GENERATE” button
Code has been generated
Open C:﹨EC:APPS﹨code.txt to check the FSC code
PS: If you fail o generate for NBT, try do following settings:
You can actually grab the 1B or DE file from E-sys by doing the following:
FSC Extended
Base variant 0x63 (For HU_CIC or HU_NBT)
Click Identify
Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <— This is the App for your Nav enabler
Upgrade Index 0x1
Move Store FSC from the left to the right
Click Read
Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN.
Both CIC and NBT work.
And if you use NBT&CIC Navigation Map Update Calculator for BMW, it could be easier.
iatacs19462.50
      11-24-2016, 05:31 AM   #739
Nafy
Nafy's Avatar
49
Drives: 11 328i sedan
I would like to update my 2011 328i with cic north america map. Please pm. Thanks.
      03-30-2017, 08:18 PM   #740
victor247
Drives: 08 335i E93, 2012 GTI KO4
Hi guys, Im trying to find updated maps for a CIC with the 2011 maps. Anyone have the latest map torrent? Thanks!
2008 335i E93 Single Turbo
Join our national street racing community!
https://www.facebook.com/groups/streetracingcreed/
https://wwwStreetRacingCreed.com
Instagram - StreetRacingCreed
      01-11-2018, 02:36 PM   #741
Kadlik
Drives: BMW 135i, 330d LCI
Important - there is a solution for those who has older car than 2009 and cannot update maps via USB because of old car firmware. There is no need to update the cars firmware.
Put the same folder as on USB to DVD DL (dual layer) medium and write it on the lowest speed possible. You will have 3 CDs as 3 USBs.
I just upgrade it during the ride, it took 2 hours. No problem.
PS: For FSC code or maps I recommend this seller:
https://www.ebay.com/usr/bimmer_fsc_...p2047675.l2559
      11-21-2019, 04:03 PM   #742
FatboyDean
Drives: 2010 BMW 335XI
Originally Posted by mkolodij View Post
Apparently - this may not be the case. Cars manufactured before 09/2009 appear to have a different CIC --- possibly with only a 40GB HD instead of an 80GB --- and the USB upgrade method doesn't work.
My 328xiT is a 08/2009 and I was unable to update to 2012 maps using USB no matter what I tried -- FAT32 or FAT or NTFS partitions --- 8GB, 16GB or 32GB thumb drives --- SANDISK, Imation or some other manufacturer --- bootable or unbootable, using Linux or Windows to format --- made no difference. The update would not start when the USB stick was inserted into the glove compartment port. Not even starting the update with the first DVD and trying to use the USB instead of the last 2 DVDs would work. I finally just painfully installed using DVD. Had to reburn the DVDs a few times to get ones that would work all the way through.
I can use the USB port to download music to the hard drive without difficulty, therfore the USB glove compartment port is "working". The ISTA/P software was updated in Sep 2010 (to version 2.37.1 I believe) and the maps to v 2010 by the dealer when I purchased the vehicle.
I have independent confirmation from two different BMW dealers -- Tischer and WG BMW near Philadelphia that the USB method will not work with my car. They're both happy to sell me the FSC code but I need to take the car to the dealer to upload the media -- $322 total. I believe my inquiry to Tischer is the reason they put the pre-09/2009 info on their web page.
As always YMMV
Hi just wanna know how did burn them into dvds, I downloaded an rar file with different folders inside and do not know how to burn them into dvds in the right order. Please do let me know! Thanks
