BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      11-27-2013, 08:09 PM   #1
DrakeKemper
Sexiest Man Alive
DrakeKemper's Avatar
Drives: 2009 E92 M3
Changed out my Rod Bearings - 08' E90 M3 Supercharged
I recently had my 2008 E90 M3 supercharged, and before doing that I thought it would be a great idea to swap out the rod bearings.
NOTE* - I had ZERO warning signs of any problems, or failing bearings, no ticks, knocks, etc. I just figured supercharging the car would only speed up the process IF something were to fail.
The car had 47,000 miles before supercharging, and 1,800 miles of supercharged driving before the change.
They show signs of wear, however not terrible.
Hopefully the changing of the rod bearings will add 30k or so miles to the life of my supercharged engine.
Overall, it was a good idea to replace them. I believe we went with the 2013 OEM bearings with a High performance coating? I don't know, ask Autotalent lol.
Photos coming soon of the car build, just waiting for my AWRON gauge to go in, and then I will post photos.
I love the car, its a completely different beast. Review will come with photos.
2011 BMW X5//M
2008 E90 M3 - 6MT - AA Gen 2 Level 3
1991 Hot Girlfriend
      11-27-2013, 08:23 PM   #2
PhillyNate
ENTHUSIAST
PhillyNate's Avatar
Drives: 2010 Porsche Cayman
This is encouraging...a little. I'm starting to think like many other car related issues this may be a "hit or miss" issue with our M3's. I'm not gonna worry about it any event. I got enough shit to worry about without rod bearings on an otherwise perfect car being on the list.
Thanks for posting.
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt
2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15)
2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14)
2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11
      11-27-2013, 08:25 PM   #3
///M-Night
14
Drives: M e93
What was the cost of replacing the bearings if u don't mind me asking?
      11-27-2013, 09:11 PM   #4
tony093
tony093's Avatar
111
Drives: E92 AW M3
One of them seems to be pretty bad in the third picture
      11-27-2013, 09:34 PM   #5
Crazy Bimmer
The Jesal
Crazy Bimmer's Avatar
Drives: E90 M3
2009 BMW M3  [0.00]
How often was the oil changed? Just curious.
2009 E90 M3 - SOLD
      11-27-2013, 10:39 PM   #6
flint
flint's Avatar
Drives: 2008 E90 M3
I see copper showing through on one. Is that normal wear?
2008 E90 M3 | Jerez Black | Fox Red | 6MT
__________________________________
      11-27-2013, 11:14 PM   #7
tinman831
Drives: M3
I always thought that showing copper was a bad thing. It seems like all of the bearings show at least some copper along the edges. Is this considered normal for this engine?
      11-27-2013, 11:19 PM   #8
okusa
okusa's Avatar
846
Drives: 2011.75 E90 M3 - SSII
Any oil analysis done before the operation?
      11-27-2013, 11:38 PM   #9
Someone?
Perception is King
Someone?'s Avatar
Drives: M4
For a 08 w/SC'er them bearings look real good, you didn't do bad by replacing them tho.
Perception and Reality are Two totally different Things.
      11-28-2013, 12:10 AM   #10
e-solo
14
Drives: e46 M3
+1
      11-28-2013, 01:20 AM   #11
speedaddictM3
Drives: 2008 E90 M3
That engine only has 47000 miles and already some of the bearings have completely worn through the lead and began digging into the copper. What are the odds of those bearings surviving another 100k miles?
      11-28-2013, 10:05 AM   #12
5soko
5soko's Avatar
333
Drives: M5
How many cars have actually failed from bearing wearing out?
I ask because i have a few friends with 100K+ modded S85's on the factory bearings.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      11-28-2013, 01:12 PM   #13
EvenSteven
EvenSteven's Avatar
17
Drives: '11 m3
It seems if you're going to have bearing issues it will happen early in the lifecycle of a car. That car can probably go another 50k on those bearings with no issues.
If you're going to supercharge, swapping the bearings is probably a good idea. Doesn't coating the OEM bearings make the problem worse though?
      11-28-2013, 01:18 PM   #14
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
There is an "acceptable" wear as designated by the factory. This rods show some wear, but not to the point where OP will be driving on the road, and the engines ceases. Granted the type of driving this car was put through.
But I think, OP, you have took the proper route in tackling rods failure once a S/C is added. Should be good to go for another 60k to 80k depending on the style of driving.
      11-28-2013, 01:50 PM   #15
bigtracing
bigtracing's Avatar
Drives: 2008 ///M3
rod bearings should last 300k+ not be half way gone at 47k.
      11-28-2013, 06:50 PM   #16
fbm3cab
fbm3cab's Avatar
35
Drives: M3
If I wanted a car with an engine that would last for 200k plus then I sure wouldn't buy an M3 with a 8400 rpm redline engine in it.
Some compare this engine to exotics that typically see 5k or less a year and those engines don't last for 100k plus either.
Perhaps a Honda or Toyota would be the car to buy if we wanted to enjoy high mileage, but even then if you beat the shit out of it then it wont last that long.
      11-28-2013, 08:31 PM   #17
PandaM3
Drives:
If you want a car that will last 200,000+ miles and be 95% as quick as the M3 both in a straight and in the turns... There's always the IS-F.
If my oil analysis starts going south as far as copper and lead I'm unloading this car to carmax or autotrader and picking up an IS-F.
      11-28-2013, 08:54 PM   #18
Black Gold
Drives: M3
This
      11-28-2013, 10:03 PM   #19
speedaddictM3
Drives: 2008 E90 M3
So how come bmw in all their marketing about the M3 conveniently forget to notify you of this little factoid that their engines don't have much of a life expectancy
There isn't a single thing on the M3 including the engine that is remotely exotic. It's a mass produced higher performance variant of BMW's volume-selling grocery getter 3 series. No one buys an M3 to drive it one weekend a year like they do with Lambos or Bugattis. People buy an M3 to drive on the road, a lot, and put a lot of mileage on them.
You can get a C6 Z06 or GTR that will smoke an M3, and beat the shit out of them daily, and they still will probably be more reliable than an M3.
Originally Posted by Dashman View Post
Where do you see that it is half way gone
Maybe your statement applies on a Honda engine, but this is an engine built to extreme close tolerances and spins faster than 90% of what's on the road. I don't think it's crazy to expect moderate wear and this is very moderate wear, even for a car that I'm sure was not babied.
One such Honda engine is that in the S2000. Remember it? Made more hp/L than the S65, and also revved to a whopping 9000 rpm. And I'm sure it was built to very close tolerances. Yet it can still keep going on and on without eating up its bearings.
      11-28-2013, 10:14 PM   #20
FogCityM3
FogCityM3's Avatar
499
Drives: M3 (E90) & Porsche GT3 RS
Exactly. Remember seeing a video with Steve Dinan saying that BMW designed these engines (S65/85) to last about 150k miles. He also said that modifying the engine with typical bolt ons, tune, rpm limit raise, etc would likely reduce its life by about 25k miles. For this type of engine, I'd be happy with 125k-150k miles. No such thing as a free lunch.
      11-28-2013, 10:39 PM   #21
Boo-E
Boo-E's Avatar
Drives: 2011.75 E90 M3 ZCP DCT AW
+1. I'm thinking about changing mine out if it's not cost prohibitive.
2011.75 E90 ZCP DCT AW OEM CF splitters, mirror, and spoiler. Feeling so stock right about now.
      11-28-2013, 10:46 PM   #22
speedaddictM3
Drives: 2008 E90 M3
150k miles is a mediocre lifespan for any modern engine that isn't in a racecar or some rare exotic. I wonder if they would have awarded it all those "engine of the year" awards if this information you mentioned was more well known (assuming that Dinan knows what he's talking about).
active autoworke, e90, rod bearings, supercharged
m3post
