TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Public XDF Repository
      09-15-2016, 03:49 PM   #67
WedgePerformance
WedgePerformance's Avatar
Drives: Slot Machines.. Keep Taking $
Originally Posted by CarAbuser View Post
Will the tables for enabling exhaust burble be added into the XDFs?
So I can change duration without using the flash time options in MHD.
No, the tables will remain private.
      09-22-2016, 01:45 PM   #68
jyamona
177
Drives: 2010 135i
No, I found them for MHD as an exclusive feature, sorry
Enjoying the new tables discovered and the XDF progress made? if you'd like. Every bit is appreciated!
      09-22-2016, 05:05 PM   #69
CarAbuser
CarAbuser's Avatar
469
Drives: Z4 35i DCT / E92 335i DCT
Perfectly understandable. I just like to keep as many things set in the BIN file as I can since MHD occasionally has problems with the flash time options not correctly applying.
      12-07-2016, 12:04 PM   #70
jyamona
177
Drives: 2010 135i
XDF Update!
The Fuel (Start) table has been added Click here to enlarge So go enjoy no more cold start E85 issues!
Also, very big thanks to MHD Tuning for adding ALL missing table axis. If anyone spots an issue, please comment.
Thanks!
Appreciate 3
      03-15-2017, 11:14 AM   #71
clay6316
Drives: E82 135i
Dear all
I am a new tuner in the tunerpro ,i want to tune my 335i,i have elm327 ,but i don't connect tunerpro, and i don't know to load the car Bin,can give me some support?
thank you so much
      03-16-2017, 01:42 AM   #72
WedgePerformance
Originally Posted by clay6316 View Post
Dear all
thank you so much
You cannot use TunerPro to flash the car. You'll need MHD Flasher and you can use TunerPro to modify the bin and flash via MHD.
      03-16-2017, 11:58 PM   #73
clay6316
Drives: E82 135i
so~frist i need use MHD read my car Bin file,
then use Tunerpro to modify the Bin file ,
last ues MHD to flash my car?
thank you so much
      03-17-2017, 12:54 AM   #74
WedgePerformance
thank you so much
Yes
But I also recommend just paying the $49 for a stage 1 or 2 map pack and flash your car with a decent MHD/WedgePerformance map.
      03-17-2017, 10:14 AM   #75
clay6316
Drives: E82 135i
Yes
Dear sir thank you so much
but i Want to learn about tuning,and where can Let me learn to tuning know how?I am very interested in it
      03-21-2017, 01:09 PM   #76
jyamona
177
Drives: 2010 135i
Please keep this type of discussion out of the XDF thread. Thank you!
Appreciate 3
titium326.50
OlliD28.50
      01-17-2018, 08:58 PM   #77
xQx
General
Australia
903
Drives: 2008 BMW 135i (E88 N54 6AT)
Does anyone have a xdf file which defines the Toggles for Diagnostic codes 29F4 and 29F5 in the IJE0S bin file?
(or can link instructions of how to define them in tunerPro?)
I'm Australian, so we're legally allowed to code these out, but since they're not in the XDF file, I can't.
Thanks,
Will
      01-18-2018, 03:04 AM   #78
Ballistic
Ballistic's Avatar
Netherlands
127
Drives: 335i E91
Thank you for all the work and making it publicly available.
however;
converting them from metric to standard values
I'm sorry... YOU DID WHAT!? Your "standard" is NOT A STANDARD!
Stop using retard numbering. Its 2018 ffs!
Appreciate 7
feuer4275.50
LMB335IS1299.00
OlliD28.50
Pete.J321.50
Sav.50.00
      01-18-2018, 08:00 AM   #79
feuer
feuer's Avatar
Drives: wife crazy!
very well said!
Ballistic127.00
      06-20-2018, 09:44 AM   #80
veer90
28
Drives: .
The github link in post 1 always has all the most up to date XDFs right?
Was looking at the IJE0S XDF and noticed the last commit was a year ago, just wanted to double check. Thanks.
      07-22-2019, 08:35 AM   #81
studio54
studio54's Avatar
Belgium
201
Drives: n54
Thanks for this !
Anyone knows the difference between torque request high & low tables for a 6 MT ?
Is "low" is for when DTC is pressed once ? and high for the rest of the time?
      10-04-2019, 01:10 AM   #82
svvag2000
Drives: BMW M3
good day
great jobe
      01-06-2020, 02:43 AM   #83
Gixfighter
Drives: E91 2006 335i, M-sport
I've been struggling to get the exhaust flap to stay closed when car is idle or low speed driving. I've tried many settings for static exhaust flap position, and also torque request % map for 0 and first gear but it won't stay closed.
I've tried MHD and that keeps the valve closed during idle so the valve works fine.
I'm thinking the problem might be the '1' setting for the static exhaust flap postion, according to the comment in the XDF info, 1 should be closed. can anyone confirm this is the case? Maybe i need to input a different number there, as for many other toggles?
      02-03-2020, 09:10 AM   #84
paolotonzini
Drives: 335i
Is there an xdf for e9x n55 that will allow modifying fuel start and idle setpoints for cold start idle changes?
      02-04-2020, 03:12 AM   #85
335ir1r6
Drives: 335i
any xdf file for tcu with gke195 family ?
      02-05-2020, 03:29 PM   #86
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Drives: '16 M3, '23 718 Spyder
Is there any way to determine which lines need to be modified to disable cold start and CEL for carless DP on a 2011 N55 xdf?
      04-01-2020, 07:27 AM   #87
B6T
24
Drives: 2008 BMW 335i 6-speed
Had a similar problem with my E82 a while back. Turned out to be a hole in the vacuum that runs from the brake booster tube under the hood.
      08-05-2020, 03:23 PM   #88
6ixSpd
Save the manuals!
6ixSpd's Avatar
6015
Anyone? Looking to do the same on a 2010 N54 as well. I don't want to tune the car for power or any Stage 2, just disable the CEL for the catless DPs.
