03-03-2016, 01:13 PM | #45 | |
64
Rep 155
03-04-2016, 01:13 AM | #46 | ||
29
Rep 195
03-05-2016, 08:16 PM | #47 | |
189
Rep 377
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
03-06-2016, 07:12 PM | #48 |
29
Rep 261
I had my thermostat replaced at 76k under the recall. My dealer refused to touch the radio button panel, saying I must've scratched it but I know I didn't. I get a parking lamp malfunction when it's really cold but moment it heats up it goes away. Car has been really solid.
2014 BMW F30 328i - Base line 8AT, Alpine White, metallic black roof, Megan Racing CF decklid, CF canards, CF eyelids, CF rear diffuser, matte black kidney grills, gunsmoke tail lights/reflectors, VMR 721 Hyper Silver 19x9.5/19.x8.5, 5mm spacers all around, Bilstein B8s, Injen CAI, H&R Sport Springs, muffler-deleted quad pipe, 20% 3M rear tint, M Performance Pedals
03-06-2016, 10:07 PM | #49 |
40
Rep 125
Drives: 2013 328I Sportline
03-07-2016, 08:24 AM | #50 |
Rep 45
Drives: 2013 328i, 2014 328i
2013 328i built October 2012, 43,000 miles. One problem with dropping Bluetooth connections, fixed with warranty radio replacement. Driver side tail light came partially loose, fixed under warranty. Insert on the trunk lid tag mount pulled out. I fixed that, too much trouble to take to the dealer. Immensely more reliable and fuel efficient than the C240 this car replaced. Zero drive train issues so far.
03-07-2016, 08:27 AM | #51 |
Rep 1,490
Car has 20,000 miles. Basically new, but figured I'd check in. The car is fairly well modified with a tune/suspension and all that since maybe 2000 or 3000 miles. Car has had 0 hiccups besides dropping bluetooth functionality every now and then.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
03-08-2016, 02:21 AM | #53 |
85
Rep 188
A lot of highway driving?
2012 BMW 320i Alpine White (300) Premium Package (ZAR) Lighting Package (ZAU) Navigation Package (ZAV) Rear Park Distance Control (507) Automatic (205) |
03-08-2016, 07:52 AM | #54 |
Rep 410
Drives: One car with good steering ;)
2014 435i xDrive - 20,000km (12,000 miles)
Here's what I can remember at the moment:
Hopefully this is the last of the issues the car will have. The fun I've had driving it (and ragging on loaners) has definitely offset the frustration I've had with the unreliability. |
03-08-2016, 04:17 PM | #57 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
My car: 2015 428 GC. 6200 miles in 11months. Time for it's first oil change. NO issues whatsover (no errant rattles, etc.) Knock on wood.
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
03-09-2016, 10:33 AM | #59 |
38
Rep 232
2012 328i, 37k miles.
Various recall work, oil filter housing, something about a drain somewhere. Driver seat leather squeaks, BMW refuses to repair as its a "non mechanical" wear issue. Funny how there is no wear to the seat, just awful noise unless I stuff a towel between the seat bottom and back. Bmw states "technical bulletin says to condition leather, that is the fix". BS! Just in for leaking oil seal inside turbo, causing smokescreen upon start-up after sitting for more than a few hours. A/C smells awful upon start up or activation when off. BMW says: "there is no fix for this, turn off AC 5 minutes before arrival at destination" !!!!!!!!!!!!! Intermittent electronic squeal/humm from CD player/climate control unit. BMW not able to replicate customer complaint.
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS 1978 Honda CB750k, 1977 Yamaha XT500 1975 BMW R90/6 & 1969 R69S |
03-09-2016, 10:45 AM | #60 |
38
Rep 232
Various recall work, oil filter housing, something about a drain somewhere. Steering wheel column noisey, lubricated under warranty. Driver seat leather squeaks, BMW refuses to repair as its a "non mechanical" wear issue. Funny how there is no wear to the seat, just awful noise unless I stuff a towel between the seat bottom and back. Bmw states "technical bulletin says to condition leather, that is the fix". BS! Just in for failed oil seal inside turbo, causing smokescreen upon start-up after sitting for more than a few hours. Turbo seal replaced under CPO warranty. A/C smells awful upon start up or activation when off. BMW says: "there is no fix for this, turn off AC 5 minutes before arrival at destination" !!!!!!!!!!!!! Intermittent electronic squeal/humm from CD player/climate control unit/center column. BMW not able to replicate customer complaint. When I had an Audi they took care of any complaint, basically just replaced any suspect part all the way through the CPO warranty period. BMW seems to want to dodge any and all warranty costs.
03-12-2016, 10:59 PM | #61 |
Rep 4
I am very curious about high millage issues considering my 2013 328i has over 103,000 miles on it. A little background: I have owned the car since it came off the lot and I have only had one issue with it so far other than standard services. It was something to do with some part of the car that warms the engine. It was stuck on, and had the potential apparently to cause the engine to overheat the dealership said. I think I paid something like 500 dollars for the repair. So, should I be expecting anything to break soon? It seems like a pretty sturdy little car.
03-12-2016, 11:06 PM | #62 |
29
Rep 261
I got a battery warning the other day that it is discharging when parked and the car is shutting off electronics. All electronics still worked. I lock upon exit and the keys are far away from the car. Spent 6hrs charging to full today and will see tomorrow if warning goes off...fingers crossed.
03-13-2016, 07:15 AM | #63 |
16
Rep 43
2014 BMW 428i Sport - CPO
Hi guys,
I am new but wanted to share my comments on my first BMW: Purchased on 2/27. Car had 21,800 miles and was a local lease turn in. Its black on black with a ton of options including the HK stereo upgrade (which rocks). On 2/28 the check engine light came on. Thats right within 24 hours of buying the car The car drives like a dream and the engine was strong and no real issues to be noticed. I checked the gas cap and drove a few more days. No luck. I then purchased a code reader and found cat issues in zone 1 and 2. Its now been in the shop for a week. They tell me no issues have been found but they are reprogramming the car. I am in a 2016 535d loaner and missing my 428i coupe I will keep you guys posted on what comes out of this. I really hope this is a simple fix as I 100% LOVE THIS CAR! |
03-13-2016, 08:42 AM | #65 | |
I can haz cheezburger?
6808
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Original cooling parts still? Drive belt changed yet? Has your N20 received walnut blasting? Trans ever been serviced? Still on original spark plugs? |
03-14-2016, 07:17 PM | #66 |
Rep 4
Yes original cooling parts, never changed the drive belt, no walnut blasting, nothing has been done to the trans, the spark plugs have been changed either three or four times (can't remember) but this is typical.
