12-02-2019, 03:38 PM | #45 |
Rep 1,230
No. You will need a HPFP upgrade. E35 at most.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
12-04-2019, 01:55 PM | #46 |
82
Rep 217
I've been running my DIY Walbro on MHD Stage 2 E30 tune for over a year now and its been fine except for one hiccup. When it was very hot this summer and I was idling for over 20 minutes and the car shut off with a fuel fault. It started backup after an hour. Before summer arrives I plan to enhance the cooling on my EKP.
12-04-2019, 06:19 PM | #47 | |
Rep 1,299
12-04-2019, 07:42 PM | #48 | ||
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
04-15-2020, 01:43 PM | #51 |
27
Rep 137
I did this the other day. It was pretty simple and took about an 1.5-2hrs to complete. Def make sure your fuel light is on before attempting this. Also to assist in fuel pressure bleed down make sure you disconnect the pump's wiring and then start the engine (a lot) until it just cranks w/o firing. Then disconnect the fuel line (carefully use a small flat head to pull the tab out).
I used a large flat head and 3lb hammer to spin the lock ring off and on vs buying a tool, it was pretty easy. Next you just disconnect the connector with the blue/black wires from the cover, then 2 black quick disconnect 90* fuel lines (squeeze with your fingers), then pop the venturi out of it's holder (reach you fingers back there and pop it up), then pull the 3 large clip ears away from the pump assy and then just snake it out of the tank. When reinstalling the just make sure you watch and make sure the fuel filter sock goes in nice. I used male spade connectors clamped onto the Walbro pump wires (removed the plastic insulators from them). Make sure you have good spades that are solid and not cheap ones that are bent to make the spade part. You need to trim the negative one so that it is thinner (or get 2 sizes) in order to fit into the OEM connector as the negative is thinner on the pump. Reinstall how you took it apart. I then started it with the seat and chassis cover still off (lock ring on) just to make sure it worked nicely. I then reset some of the adaptations and you should be good to go. Bought the parts on Summit Racing Walbro Pump: https://www.summitracing.com/parts/VPN-F90000274 Walbro Corrugated Hose: https://www.summitracing.com/parts/VPN-TF0002516 And for those that are concerned about the potential EKP Module issues (overheating) with the rise in current here is a neat thread about cooling it. I bought a 12V 40x40x10 fan and some small stick on heat sinks for an arduino to attach to the Mossfet. I haven't done this yet as I don't have the pieces but it should be a good piece of preventative maintenance. https://www.bimmerfest.com/forums/sh....php?t=1316911 Last edited by naCAnItihS; 04-15-2020 at 01:53 PM.. |
jayster0966209.00 Trainwreck914132.00 |
04-15-2020, 02:40 PM | #52 | |
Rep 668
I'm on the YouTubez now!! Check it out -> https://www.youtube.com/@turbospool
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
04-15-2020, 04:06 PM | #53 |
Rep 1,442
Drives: 2011 535i 6MT
Nice write up. One thing that has NOT been clear in this thread is how much the older continental hpfps can take vs the newer ones of e85.
I have an older one so if I did the lpfp and did my fuel lines to the hpfp, how much e85 could I run? This should be a different answer compared to the newer pumps. Please LMK!!! |
04-15-2020, 04:29 PM | #54 | |
27
Rep 137
Fuel-it sells a kit to upgrade the lines for like $145. If you want a sensor etc that will obv be more money. https://www.fuel-it.com/bmw-f-series...nsor-upgrades/ Last edited by naCAnItihS; 04-15-2020 at 04:39 PM.. |
04-15-2020, 04:45 PM | #55 |
Rep 1,442
That's what I was thinking, thanks for the info!
I was going to go look at N54 threads for this reason but you confirmed it. So for basically 250 bucks and a couple hours I can go full e85 or a high % blend. I heard around 50 is optimal with 93 octane. I need to do this before I get my custom tune done. I wonder what kind of gains you'd get with this with just bolt-ons. EDIT Just answered my own question: https://f30.bimmerpost.com/forums/sh....php?t=1312822 Last edited by BimmerHausPerformance; 04-15-2020 at 05:43 PM.. |
04-15-2020, 08:03 PM | #56 | |
209
Rep 221
04-16-2020, 10:27 AM | #57 |
Rep 1,442
NICE! What other mods do you have? What tune do you run and have you gotten a dyno?
04-16-2020, 04:08 PM | #58 | |
209
Rep 221
We are only on the second revision of the tune before current lock down started so have not had a chance yet to test how we are doing on revision 3 which does feel a touch quicker. Last time I ran it on my buddy's dyno we did 442 whp and 433 wtrq. If you factor in drivetrain loss that puts it above 500 at the crank. Not the most powerful thing out there but nice/quick and reliable. Of course power numbers always vary by vehicle, weather, and dyno. |
Bmwdoubles_194.00 |
04-25-2020, 09:23 AM | #59 |
Rep 452
Just got finished doing this. Took about 2 hrs being meticulous and clean. And still found debris in the bottom of my tank. And yes I vacuumed before hand. Not sure if it fell in or was already there even with me being very careful. So used the wet vac to suck out fuel and debris. Can't stress enough to wait until you are at very low reserve to do this. Thanks for the heads up. I waited til It said 8 miles to empty. It's a bit of a pain snaking the pump out. The line that wraps around from the cover to the regulator to the pump was a bit intimidating. Only because you can't see it. Or the regulator. I looked in newtis and saw they referred to popping the regulator out. But could not see/find it. After I did that it was smooth sailing. Only 1 issue. I finished and drove off to gas up. And found out only after filling the tank that I forgot to plug the sender unit back up. That's the plug where it sends the fuel level to the gauge! The one on the bottom side. (Doh!! Homer Simpson voice). Have to wait until tank is low again to go back in there. Only thing is I don't know how much fuel I have??? I marked my mileage so I should be ok. But thanks for all the previous posts and advise.
04-26-2020, 10:34 PM | #60 | |
Rep 668
Thanks for sharing!
04-26-2020, 11:25 PM | #61 |
Rep 452
Nothing in particular that I'm trying to "get to". I guess I just got motivated seeing it as an "upgrade". And preventative maintenance for $100. I don't typically get stranded. But would hate if I was. Hpfp goes out car will go into limp mode. LPFP goes and your a sitting duck. Car has 127k on it now so I figured sooner than later. I went with the lp450 ends in 267. I have the newest version jb4 installed and figured it might be cool to do the whole e85 thing. But I'm second guessing using that in my car. Lots of mixed reviews/myths about it.
95blkmax215.00 |
04-27-2020, 07:54 AM | #62 | |
Rep 668
Every car will be different, but I can tell you that based on my logs, my 2011 (so I have the Continental HPFP), running FBO and E30 with a max of 12psi (problem being trouble-shot this week hopefully, see my Boost Troubleshooting thread for reference), my HPFP is holding at 1650psi. I'll still upgrade the LPFP as I doubt it'll keep up once I fix my boost issue (sitting just over 112k miles right now)
04-27-2020, 08:10 AM | #63 |
Rep 1,442
I just put 4 gallons of e85 without any lpfp to see what my car would do and it's running without issue at all. One thing I noticed was the sign said "at least 51% ethanol." How the heck are you supposed to do proper calculations with out an ethanol reader? When I do this I'm definitely going to go with that. Oh an of course when I got onto the freeway there was a 50th anniversary vet and low and behold there was NOT an old guy driving it so we actually raced. Yea... didn't win but he didn't pull on me that hard... need PS2.
04-27-2020, 12:35 PM | #64 | |
209
Rep 221
04-27-2020, 01:27 PM | #65 | |
Rep 1,442
jayster0966209.00 |
04-27-2020, 02:41 PM | #66 |
209
Rep 221
It is a project that a buddy and myself undertook to provide real-time ethanol content in the fuel system of any vehicle. We use a GM ethanol sensor spliced into the main fuel feed to the motor. Board is a Arduino and programmed by my buddy. Case was 3D printed back then but we do use a pre-made case now.
