Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Does N53 330i have a CCV/PCV valve?
      04-11-2024, 03:16 PM   #1
s5s
Drives: BMW E90 SE 330i 2010
Hi,
I'm a little confused about EGR blanking and CCV/PCV catch can. I've got a few questions:
1. Wouldn't EGR blanking make a PCV catch can unnecessary?
2. Do petrol engines, and in particular N53 330i have an EGR valve?
3. Does the N53 330i have a PCV valve?
I am asking the last two because I can't seem to find the PCV valve on the BMW parts page:
https://www.realoem.com/bmw/enUS/par...BMW-330i&mg=11
So I thought, perhaps the N53 330i does not have a CCV/PCV, as strange as it sounds.
      04-12-2024, 02:22 AM   #2
Phil325i
Phil325i's Avatar
623
Drives: E92 325i MSport Coupe
1. Wouldn't EGR blanking make a PCV catch can unnecessary? Personally I wouldn't fully blank the EGR as you will get codes. I partially blanked mine so there was still a small amount of gas flow. I also have an OCC and it catches plenty of liquid.
2. Do petrol engines, and in particular N53 330i have an EGR valve? Yes.
3. Does the N53 330i have a PCV valve? Yes - it's incorporated in the valve cover.
