01-20-2013, 07:17 PM | #2201 |
48
Rep 385
Thank you all. Especially Shawn and Andy for the new 3.22.5 patch and token. Worked perfectly on the latest 505 iLevel on my F30 335i with 48.3 data.
01-20-2013, 08:05 PM | #2202 | |
Rep 16
'Read FA Failed! Possibly there is no FA stored in the VCM [C060]' I think that was after a Read (VCM) attempt. This error and several others that didn't display a dialog are all over the log file. The errors all seem about not connecting properly. E-sys seemed to start well (connected via VIN), and I got the success dialog after it connected to the car, but I couldn't go any further than that. Same error when trying to read the I-step, so I can't find that. It feels like I need to try again with the latest software and token? |
01-20-2013, 09:49 PM | #2203 | |
Rep 1,892
Are you able to read the FA without error? I'm pretty sure you have to do that before trying to read the VCM. |
01-20-2013, 10:57 PM | #2204 | |
Rep 490
so no, the problem are not related to 48.3 when he can't even read... seems serious... |
01-21-2013, 12:41 AM | #2205 | |
General
10515
Rep 41,049
Since you are in Ottawa, are your Windows regional settings English or French?
01-21-2013, 09:38 AM | #2207 | |
dj1
Rep 17
Good stuff
Thanks for the update. Great news for people that are new at this; like me
01-21-2013, 09:40 AM | #2208 | |
dj1
Rep 17
news
all good things come to a end
01-21-2013, 09:41 AM | #2209 |
dj1
Rep 17
delays
01-21-2013, 09:54 AM | #2211 |
48
Rep 385
Setup: I have E-Sys 3.22.5 with the latest patch and my own paid for token and using them on MY2012 335i F30 with the latest iLevel and 48.3 Data Files.
Successfully coded: - turned off orange side markers - turned on rear DRL - M Performance logo - Unlock all doors at engine off - digital speed in the BC - Turned off all disclaimers - DVD in motion - Weatherband radio - Fog lights come on at unlock with welcome lights - Trip import for navigation - 2nd handsfree phone connect to bluetooth - Auto-Stop-Start remembers last setting Tried but confused: - I did a VO coding of the FA to change 6NH to 6NK hoping that would give me Microsoft Office functions and white apple USB cable for my iPhone 5 etc. I don't see anything different in the menus and the white apple cable doesn't seem to work when connected to either of the 2 usb ports in the car (it charges only, no music, album art etc.) Where can I check in the Menu iDrive to see if this change worked? - I also noticed today that it is -7.5 degrees Celsius outside and the Auto-Stop-Start is still shutting the car off at lights. I find that unusual as it's freezing outside and in the past I can't recall car shutting off when outside temperature was below 0 degrees Celsius. Am I just being paranoid? Problem: - Coding was done yesterday and I drove the car for the first time today and got a check engine light that won't seem to go away. Any suggestions as to why that check engine light would be on based on the coding I did above? - How do I check what the check engine light is on for? Where can I see the code that it is giving? Thank you in advance for your assistance. Last edited by RASHID007; 01-21-2013 at 11:39 AM.. |
01-21-2013, 12:45 PM | #2212 |
Rep 16
regional settings are English, USA. I tried again and the same error conditions repeat. I get the initial happy 'Connection established [G168]' pop up, and then I hit the Read button in the VO section. Some delay, and 2 error messages pop up in return- C060 followed by C096. The header is read Psdz error, with the 'read FA failed' note. C096 talks about the Backup Partner, whatever that is. C060 talks about no FA stored in the VCM. I'm now thinking something might be wrong with my Psdz data files?
01-21-2013, 07:16 PM | #2213 | |
Rep 490
01-21-2013, 08:26 PM | #2215 | |
Rep 490
Have you tried VO code in option 522 for XENON_LIGHT, default settings for DRL is on even when low beam kicks in albeit slightly dimmer... |
01-21-2013, 08:43 PM | #2216 |
47
Rep 101
01-21-2013, 08:58 PM | #2217 |
48
Rep 385
Ok all, complete success thank you.
1. shawnsheridan's instructions here (http://www.bimmerfest.com/forums/sho...9&postcount=94) cleared the check engine light. Thank you! 2. I had made a mistake in programming 6NH to 6NK. Edited the FA (VO) by replacing 6NH to 6NK but did not 'Code' the VO for the Head Unit (HU_CIC or HU_NBT) to finalize it. Instructions from shawnsheridan here: http://www.f30post.com/forums/showpo...postcount=1729 Now white Apple cable works, album art work, bluetooth audio etc. Very happy and appreciative. Happy to try and answer questions and help others. |
01-22-2013, 09:48 AM | #2219 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Has anybody successfully coded to enable satellite radio? I get that you still have to pay for the service from Sirius, I just need the option to show up on my iDrive
Is it as "simple" as coding the FA (VO) to delete 693 and add 655? |
01-22-2013, 10:03 AM | #2220 | |
Rep 3,780
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
01-22-2013, 10:16 AM | #2221 |
Rep 1,027
it also appears in HUD.. its in cheat sheet version 3
M Sport Line Estoril Blue
01-22-2013, 10:23 AM | #2222 |
Rep 3,780
Only for Tech/Premium package cars and not for the base cluster/6.5" screen I assume?
