TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > REST (Residual Heat) feature coded back on a 2011 335i!!!
      03-05-2011, 03:07 PM   #1
Kalud
Kalud's Avatar
24
Drives: e92 335i
Smile REST (Residual Heat) feature coded back on a 2011 335i!!!
Quick background: I have a 2011 LCI e92 (sept built) and every time I see a picture of a 2007-2010 dash I always regret not having the REST feature. I was simply jealous. California, Florida and Texas (to just name a few) fellow 3-series drivers doesn't care at all and love the introduction of the ALL feature to sync both sides temperature, but here in Canada I think REST (residual heat) is more useful.
Some months ago I came across a thread over here (link) about buying a cable and do some coding yourself. I don't want to explain all the steps here, all the required info is over there, its just a bit long to have an in depth look... Take your time to study it if you're interested.
I've made numerous read of all the available parameters that can be changed and came across one that pretty much shocked me! Its called "REST_TASTE_VERBAUT" some quick google translate revealed that its "REST Button Installed". Interesting ? Well I thought so and made a test to change it from "nicht_aktiv" (not active) to "aktiv" (active).
After all its only a button with a LED and some marking. Its nothing like a old school hardware toggle switch.
After the feature is coded to active, first try. I shut down the car. Start the car: the ALL button that was normally always lit is off. Okay... I press it: nothing -> wow, maybe it works. I took a quick ride, then return home. Shut down the car completely, press the ALL button -> it WORKS!
I exit the car, close the door, lock the car, light is still on and its heating... Come back 15min later, light is off, I open the car its very warm !
I knew it was possible to do something, after all, the 2011 cars still have an electric water pump and all the electronic is there. BMW engineers / marketing decided to react to complaints about the lack of an ALL sync button and decided to replace the function.
Some pictures of the car completely off with the ALL button lit, its heating trust me. And the best off all: in May i'll get the ALL function back for the summer.
      03-05-2011, 03:12 PM   #2
InsanePineapple
Shenanigans
InsanePineapple's Avatar
Drives: See Signature
This is a triumph! I'm making a note here:
HUGE SUCCESS!
      03-05-2011, 03:38 PM   #3
Roowah
Roowah's Avatar
Drives: 2006 E90 330i 6MT
Holy !
If this actually does work (and I personally believe you), then this would be the answer for a lot of people. In fact, it's even better than the original REST since you can toggle it back to ALL when not needed in the summer. I'm predicting this may become a very popular thread. Great job!
2006 E90 330i 6MT: TiAg|Black Leather|Poplar Trim|Premium Package|Cold Weather Package
2003 E46 325i 5MT: Retired - The beginning of my BMW obsession!
      03-05-2011, 03:40 PM   #4
Kalud
Kalud's Avatar
24
Drives: e92 335i
Originally Posted by Roowah View Post
Holy !
You just cannot imagine how excited I am right now. That was the only thing I wished my car has...
      03-05-2011, 04:30 PM   #5
alex2364
alex2364's Avatar
2868
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
So for older cars, does this mean we can turn it off and have the ALL feature?
      03-05-2011, 04:43 PM   #6
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Fyi, the REST feature activates the water pump. So I wouldn't use it too much if are still on your original water pump and have high mileage. See page 17: http://www.socale90.com/forums/attac...ttachmentid=56
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      03-05-2011, 04:50 PM   #7
Kalud
Kalud's Avatar
24
Drives: e92 335i
Thats exactly the next question to answer, I would think not but who knows. We would need a FSW_PSW.TRC dumb of an older car for the IHK (Climate Control Module) to see if the software switch is there. This will probably be answered in the next couple days in the original coding forum, see link in first post.
      03-05-2011, 05:41 PM   #8
tomz17
35
Drives: 2020 M340xi
!!!! Awesome! I love the rest feature on my 2008 335i. Glad to hear it can be programmed back easily if I were ever to upgrade!
      03-05-2011, 06:19 PM   #9
31 Hz
Drives: 08 E92 N54 ZSP 6mt
Somewhat unrelated, but would the REST feature be appropriate to use after shutting down the car after a hard run (so that coolant continues to circulate throughout the engine)? Seems like it would be.
      03-05-2011, 06:20 PM   #10
X2Board
X2Board's Avatar
Drives: I'm back, bitches! '13 E92 ZCP
I love that feature, in my '09 with iDrive, I can program what time it turns on and off.
      03-05-2011, 07:22 PM   #11
Kalud
Kalud's Avatar
24
Drives: e92 335i
Sounds like a good idea too. I've made some tests already and it does reduce the oil / coolant temperature a lot (when its cold outside) from 110C to about 70-80C
      03-05-2011, 07:26 PM   #12
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
Rest Features FTW...
Need an all button Now LOL
Btw I love how the coding is in German. They have the best words.
///Mik3119.50
      03-05-2011, 08:23 PM   #13
Want
YVR
Want's Avatar
22
Drives: A Monaco Blue
Nice job. The only thing I hate about the rest button is sometimes I forget to turn it on.
mbmbmbmbmbmbmb
      03-05-2011, 09:26 PM   #14
Chriztofor
Chriztofor's Avatar
Never thought about that, but I don't think BMW would let the consumer be responsible for hitting the REST button every time you run it hard, otherwise our cars would be in trouble (who would remember to do that?)
      03-06-2011, 09:21 AM   #15
Kalud
Kalud's Avatar
24
Drives: e92 335i
I am looking into that right now
      03-06-2011, 09:33 AM   #16
timmahh
ghey
timmahh's Avatar
Drives: Viertürigen Fahrzeugs
That's not REST, that's parked car ventilation.
Parked Car Ventilation = Airflow through the car at the specified time. No temp control, just air flow
REST = Residual Heat [via coolant] is blown into the cabin after the vehicle is off for up to ?? minutes to keep the car warm while you're in a grocery store or something
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
      03-06-2011, 01:30 PM   #17
Kevin Harney
Drives: 2009 335i Convertible
up to 30 minutes !
      03-07-2011, 02:32 AM   #18
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
this is pretty sweet i must say
IG:d.violet.m3
      03-07-2011, 07:27 AM   #19
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
When I saw this I got so excited that I emailed this link to my service advisor. He just replied with "yes, I think this can be done. I'll check and get back to you".
This has made me so happy, it's the one thing that has kept me from liking this car as much as the last one because I used it all of the time. If they can do it, I guess I'll change the knob to the REST one since I'm kind of OCD like that.
OP, thank you.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
      03-07-2011, 07:56 AM   #20
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
OP, thank you.
Ummm..why did you link the coding thread in the email you sent to your SA?
Not a good idea.
      03-07-2011, 09:20 AM   #21
Kalud
Kalud's Avatar
24
Drives: e92 335i
Not a good idea.
Well, sounds like a weird idea... In any case, I think they must already know that those threads exist...
      03-07-2011, 09:43 AM   #22
reprod
Drives: '16 M3 ZCP
I had a 2011 5-series for 2 weeks. I was able to activate the residual heat function just by tapping the fan speed up button once. Has anyone tried this on their 2011 3-series?
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned)
'16 Mineral Grey F80 M3 ZCP
2011, coded, coding, feature, rest
