04-06-2020, 09:07 AM | #221 | |
Rep 3
Iīve tryed but it keepīs on not doing nothing. And i donīt know anyone in holland that could help and check it. I donīt know the version of my android it just worked 2 weeks after i buyed the car. I didnīt understood nothing about it.Really donīt know what to do....and i donīt want to buy a new one. Itīs frustrating.... |
04-06-2020, 01:54 PM | #222 | |
Rep 41
04-07-2020, 09:50 AM | #223 |
Rep 21
Hi to all! I found a solution for the silent bug.
Edit the line with Android media volume and set it to 39 instead of 28 in factory_config.xml and then import the file in the hidden menu in settings. No need to start and close the KsWMediaKit with Tasker. Seems to be a bug in the r/w settings in MCU or Android. @Kri Would you be so kind to update your gorgeous version of factory_config.xml with my setting in your repository so everyone can finally forget this bug? |
04-07-2020, 11:11 AM | #225 |
Rep 16
Hi All,
I am with 2014 F34 with NBT. The sound system using is the very basic one (not H&K, Alpine, etc.). I am going to change to 10.25 Android 10 unit. But my main concern is the sound quality problem. I heard someone said the sound quality will be bad after changed to android unit. Hope anyone can advise to my concern. (p.s. I only use bluetooth for music and i want to use carplay for music after upgrade unit) Thanks! |
04-07-2020, 11:18 AM | #226 | |
Rep 4
Hello, I advice you to buy the Snapdragon 625 Unit because the sound quality is better than others, it's like the standard bmw radio quality |
04-07-2020, 12:36 PM | #227 | |
Rep 1,048
You are shure you used my translated xml file ? the Setting at mine is at 26 not 28. also i don`t know if its good idea to post a file where AUX is nearly at MAX by default, at least on my E-Series with a setting over 35 the sound does become bad! Not that more people are then complaining about Sound quality issues again Kri |
04-07-2020, 05:28 PM | #228 |
134
Rep 399
I tried it, unfortunately it didn't work on my unit, but I'm on Android 9 still, so maybe other users can try on their 10 units and verify?
04-07-2020, 09:07 PM | #229 |
94
Rep 143
I posted on April 5 that I was installing Netflix version 6.26.1 on my Avin Android 10 unit and that I would report back.
Well it's two days later, and surprise, boot-loop! And this was after the unit had no boot-loops for over a month without Netflix installed. The unit runs fine and indefinitely without it. So until someone has a fix or more concrete evidence that another version works fine on these units, I will be doing without Netflix unfortunately. |
04-08-2020, 01:07 AM | #230 |
14
Rep 30
https://wetransfer.com/downloads/a10...3d073e5f0GEQYd
Ksw-Q-Userdebug_OS_v1.4.1-ota.zip NOT TESTED - maybe for MB only Last edited by Slepoipew; 04-08-2020 at 01:16 AM.. |
04-08-2020, 01:11 AM | #231 | |
14
Rep 30
04-08-2020, 03:13 AM | #232 | |
77
Rep 86
The OEM file inside that folder indicates that this update might be only for Mercedes. Selectable UI's and DisplayParameters shows no sign of BMW. |
04-08-2020, 03:53 AM | #233 |
Rep 21
Seems like it works, but only for me... I have a unit from Andream / LZH vendor. A friend of mine has an e90 with ccc and GS Vendor. It really doesn't work for GS. Sorry for that.
BTW, recently my unit started to live its own life. Sometimes tasker works properly, sometimes not. Sometimes I can access the SD Card in it, sometimes not. Sometimes the TPMS works as expected, sometimes the tpms app starts on its own before even the car launcher starts normally. My device is rooted. The whole unit is not really worth of 400 Euros. There are "simple" things to manage: clear sound, good bluetooth with support of everything like Android does, good wifi with 1 button tethering, nice gps with decent gps-receiver and thats it in common. All these things are well done in an 100 Euro low end Samsung. 400 Euro is enough to do things properly. The only reason I have the unit is because of navigation. My f30 has a lowest end basic entry hu with 6,5 screen. The only extra is oem bluetooth. I also had to install the new set of Audiosystem loudspeakers because the oem loudspeakers were so bad I couldn't stand it. @Kri I had your translated version since you have posted it here. Looks like an input mistake of mine. BTW the "0" solution for the password is just great. |
04-08-2020, 03:54 AM | #234 |
14
Rep 30
04-08-2020, 04:13 AM | #235 | |
Rep 1,048
So you already updated it and it does run ?
Kri |
04-08-2020, 04:18 AM | #236 |
14
Rep 30
Yes
OEM by Kri :прохладно!: Last edited by Slepoipew; 04-08-2020 at 06:38 AM.. |
Kri1083.50 Alpina_Guy4.50 |
04-08-2020, 04:26 AM | #237 |
Rep 8
Hi Guys,
any idea how to start tasker faster after boot? In my case it needs at least 20 seconds after the HU is up (GUI) until my tasker profiles are accessible? Is there any chance to give tasker a higher priority during boot? BR |
04-08-2020, 06:45 AM | #238 | |
Rep 16
original: phone via BT > car idrive machine > speaker Android: phone via BT > android via AUX> car idrive machine > speaker Is it correct? |
04-08-2020, 11:02 AM | #240 | |||
62
Rep 66
My unit is an Avin Snapdragon Android 10 v1.3.0 I want to add more UI config options! Thanks in advance |
04-08-2020, 11:57 AM | #241 | |
Rep 1,048
As this update is coming form Mercedes Unit for sure most changes have been made for Mercedes GUI, but also some changes for our units. Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v1.4.1 ro.build.version.incremental=eng.zlx.20200407.101557 ro.system.build.date=Tue Apr 7 10:13:58 CST 2020 ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx04071013:userdebug/test-keys * Feature: ZLINK , does automatically enable Wireless Hotspot on start for Wireless Carplay * Feature: Lots of updates to Benz GUI * Feature: When Bluetooth is now disabled at Settings, the Connection tile does now has also a text "closed" to show that it is disabled. * Feature: Bluetooth Phone Callback Feature at ID7 GUI implemented ? new code found. * Update: Audio Drivers, changes/fixes unknown * Update: Tile Pictures of GS ID6 Gui have been shrinked to save memory. * Update: changes to Music/Video player app, USB Update Feature and Scanning function ? Better Idrive Support ? (i don`t use it) * Update: Carplayzlink.apk updated * Update: ECARSOS and TXZcore have been updated, but afaik only useful for china user * Update: USB-HOST Modus function seems to have been removed from application code, however the function is still listed at the factory settings screen. My unit is not installed at the moment, so i can`t test all the features at the moment, maybe someone else can do a deeper check based on this information Maybe someone with Integrated Wireless Carplay can give information what application is startet when using Carplay. As the external sold Dongle is from Autokit, it would be interesting if the built in is also Autokit or ZLINK. I also Updated the Factory_config.xml *Feature: ZLINK Auto Start String (set to 0) *Feature: added Flitsmeister to supported navigation apps factory_config_A10_141.zip Kri |
daschacka76.50 |
04-08-2020, 11:59 AM | #242 | |
Rep 1,048
* Ensure it is formatted at FAT32 * Ensure it is accessible via ES-Explorer * Ensure it is at the sub folder \OEM of the thumbdrive. Kri Last edited by Kri; 04-08-2020 at 12:09 PM.. |
