BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
BPM
      04-10-2009, 08:27 PM   #1
TonyTone
TonyTone's Avatar
Drives: M3 VERT
HID HALO SEVERE MALFUNCTION!!!!!! Guru's chime in please
After 8 months of having HID halos, I have concluded they are the worst investment you can ever make! Last night about to head out the car wanted to blow up. All of sudden front passenger turn signal flickered and stayed on along with driver fender turn signal and the rear turn signal.....Yes the opposite sides of the car have something wrong with the turn signal staying on. The best part is the halo driver side stays on no matter what!!!!
You like my messages?
I pulled out fuse 86 which turned off all the turn signals but now my passenger side headlight dosent turn on. (I pulled this fuse for trial and error)
I disconnected battery and checked every fuse in the glove box. Is there another place with hidden fuses??
For those of you wondering: MY CAR
      04-10-2009, 09:00 PM   #2
rav7ks
rav7ks's Avatar
38
Drives: e92 M3
08 M3  [0.00]
Oh man.
I doubt that it is the worst investment.
I've had electrical issues-when I installed my Performance wheel with the whole steering/EDC/ABS/wipers going haywire.
Check your wiring as a loose connector can cause failure of the whole lighting system.
      04-10-2009, 09:41 PM   #3
camaross305
camaross305's Avatar
135
Drives: 2008 M3
I told you tony let me put my circuit and harness on there! His stuff taps in the ECU and causes errors! Call me up and ill hook you up with my kit!
      04-10-2009, 09:47 PM   #4
TonyTone
TonyTone's Avatar
Drives: M3 VERT
Originally Posted by rav7ks View Post
Oh man.
Thanks for the help but the kit has been removed and still no luck
What do you mean? You used my car to advertise your product!!!!
      04-10-2009, 09:49 PM   #5
camaross305
135
Drives: 2008 M3
Yea i know but im saying you need my circuit and harness! Its still hooked up from when that guy did it. He taps into the ECU box and didnt use the circuit. That tap into your ECU is causing the errors i promise you. JEMarsal was hooked up the same way and kept going into limp mode. After I installed my kit it worked flawless. You never installed my circuit and harness! Pm me
      04-10-2009, 10:34 PM   #6
TonyTone
TonyTone's Avatar
Drives: M3 VERT
Chris I am asking for someone's help to get this situated. The HIDs were taken off immediately and still nothing! (ECU was never tapped)
      04-10-2009, 10:38 PM   #7
camaross305
135
Drives: 2008 M3
ok i was just letting you know He tapped into the ECU i promise you. Thats how he does it.... your probably going to have to have the dealer reset it.....I already did it for JEmarsal......
      04-10-2009, 10:44 PM   #8
TonyTone
TonyTone's Avatar
Drives: M3 VERT
Chris please read thread.... The lights stay on after the fact the car is off and closed. The lights DO NOT SHUT OFF!! I needed to remove a BMW fuse just for them to turn off. I have to put the fuse back in just to be able to drive around
      04-10-2009, 10:50 PM   #9
camaross305
135
Drives: 2008 M3
I know im telling you i know exactly why.... give me a call and ill fix it for you.... Its from the way that guy hooks up them up. Thats why i dont tap into the ECU or anything with my kit. JEMarsal had THE SAME PROBLEM and i fixed it.
      04-10-2009, 11:02 PM   #10
otherside
50
Drives: 03' E46 325CI TiAg
OUCH, hope you get it solved man, let me know if you need my help, you can pass by the crib. Ill slap on some LED angels in there instead
      04-11-2009, 09:50 AM   #11
DevJ
DevJ's Avatar
Drives: R8 V10+/YMB M4
Maybe you should let Chris give it a try and see if he can fix it! He seems like he genuinely wants to help you
‘23 RRS First Edition
'22 X7 M50i
'18 R8 V10+
http://www.bimmerpost.com/forums/attachment.php?attachmentid=133578&d=1204654487[/IMG]
      04-16-2009, 05:54 PM   #12
Drives: 991TTs
+1
luis plays no games, hes on the other side...
bad joke
      04-16-2009, 09:04 PM   #13
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
So, who did you get your kit from ?
bad, halo, hid
m3post
