02-01-2024, 10:04 AM | #4 | |
Rep 470
Roof rack F30/34 GEN1 From:11/30/2011 To:03/13/2018 (ENDED) Weight:5.090 kg Superseded by: 82712361814 (03/10/2015 — ), Bilaterally exchangeable Fits: F30/F80/F34 (all model years) 82712361814 Roof rack F30/F34 GEN2 From:03/10/2015 To:- Weight:5.000 kg Supersedes: 82712295099 (11/30/2011 — 03/13/2018) Fits: F30/F80/F34 (all model years) Do these details answer your question? Other than being slightly lighter (measurement error of 90 grms if anything), the Gen II should be no different to Gen I. I use Thule Aero Blade on mine and have no regrets. It is actually more slimmer and more useful imho than OEM as it is a little wider and there are no obstructions at the top, side to side along the whole length of the bars to carry flat pcs (4 x 8 plywood or drywall with 8' supports on the edges).
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 Last edited by Oksamit78; 02-02-2024 at 09:27 AM.. |
02-04-2024, 10:49 AM | #5 |
Rep 18
Thanks but that’s all info online and I’ve already seen. My question really comes down to how it mounts to the roof of the car and if the newer one provides any better support or protection. Basically are there any changes to the physical design.
02-04-2024, 05:39 PM | #6 | |
Rep 470
The part number change could be due to change of supplier to BMW, even without any change to actual design of the bars. Judging by the overlapping time period of 3(!) years, highly likely, both part number are identical. Also, to me, this means that they were manufactured by different suppliers as it makes no sense for the same supplier to be making the two different and nearly identical products under the same roof without confusion in manufacturing lines.
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
daronk3.00 |
