BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > software from the bmw website not "up to date" enough for my car
GetBMWParts
      02-09-2024, 07:01 AM   #1
Kirsche
Drives: 2014 428i
hello all,
I have a 2014 428 that I got a cupel of months ago and its been having some problems connecting to my iPhone through Bluetooth on startup
so I though that maybe I could just run a software update and it would fix it so I found a thumb drive and formatted it and I downloaded the update from the bmw website using my vin but my car says that the "Software on USB device not up-to-date" ?
the file I downloaded was UPD05074.bin
and the version I'm currently running is
Media: MN-002.033.002
Telephone: TN-002.033.002
Any help would be immensely appreciated
      02-19-2024, 02:46 PM   #2
alecba20
Drives: BMW 328i F30 2013
Originally Posted by Kirsche View Post
hello all,
Hi! I have 2013 328i and have the same problem! And same file I downloaded.
Do you have any advance?
Have problems with iPhone too (15 Pro Max)
Thanks
      02-20-2024, 03:25 AM   #3
FreshDumble
Drives: BMW F30
Thanks
I have the sam Problem, I want to update because of the Bluetooth Cover Albums being stuck with my iPhone.
I am also on 2.033.002
My guess is, that the NBT I version is to old and that it would need to be updated via ESYS
      02-25-2024, 03:41 PM   #4
F30330direland
F30330direland's Avatar
Drives: F30 330D
Hi Guys,
Same issue here for me. Any fixes yet?
I have a 2014 330D, the song name and picture wasn’t updating as I change the song, it’s driving me mad. (iPhone 14 pro max)
I got the latest version of the software from BMW website. Put it on a USB stick and when I put it into the usb port I am getting
“Software on USB device not up-to-date”
I’ve tried two different usb sticks.
      03-16-2024, 02:40 AM   #5
YASBBYM3
YASBBYM3's Avatar
Drives: BMW M4 Cs Lamborghini Huracan
Upgrade your car’s istep which will have the latest update files
      03-16-2024, 03:07 AM   #6
dogballs
dogballs's Avatar
New Zealand
62
Drives: Bmw 435d Xdrive
2018 Honda CRF1000  [0.00]
  [0.00]
There is a work around for this problem:
If you look at the version in HU it will have a particular version number structure.
Ie TV-110.005.011
For some reason, maybe HU replaced at some stage - who knows.. but the bmw server thinks the unit fitted is different for your VIN.
So, you need to use different vins to find the update that has the same version number structure. This can be done by checking the release notes with that particular software download - there is always two files once you’ve entered the vin number.
This is little clumsy, but search with vins of similar age etc to your vehicle, but eventually you’ll find it..
Good luck.
      03-17-2024, 12:20 PM   #7
relicomelico
Drives: BMW 3 Series 328i Luxury
Hey,
I have this same problem. Thought it would be an easy update but i'm also getting the same error message. Where do you suggest i could find the different VIN's so i can try what you have suggested below?
Thanks
Relic
Ie TV-110.005.011
Good luck.
      03-17-2024, 12:21 PM   #8
relicomelico
Did you find a fix mate? Got the same issue.
Originally Posted by F30330direland View Post
Hi Guys,
      03-17-2024, 10:59 PM   #9
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
Post a picture of your current systems status. I’ll find the file for you..
Eg:
      03-18-2024, 06:34 AM   #10
relicomelico
That would be AMAZING! Thank you very much!!
Codes are below;
MN-001.036.002
TN-001.036.002
Eg:
      03-19-2024, 03:19 AM   #11
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
Codes are below;
MN-001.036.002
TN-001.036.002
So you tried UDP05074 but it didn't update?
I can't load .bin files here, so enter vin: WBAKS420200J49157 and try the UPD05081 file.. let me know how you go..
      03-19-2024, 05:34 PM   #12
ronnydied
ronnydied's Avatar
Drives: f30 335i xDrive
Hey man any chance helping me out with a correct VIN?
2014 335i XDrive
My current VIN:WBA3B9G55ENR92687
      03-19-2024, 10:29 PM   #13
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
2014 335i XDrive
Hi. As per previous vehicle your system should take the 05074 file. If it doesn’t work, try the 05081 and see if that loads..
- if it’s not compatible, it won’t load..
Let me know how it goes..
      03-19-2024, 11:23 PM   #14
ronnydied
ronnydied's Avatar
Thanks brother it worked with the previous vin you posted!
unfortunately I don't think it fixed my issue of my album covers and track names not updating but thanks again for the good info.
      03-20-2024, 12:11 AM   #15
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
Before you throw in the towel, try a reset of the HU, delete the pairing from both HU and phone and then re-pair.. See if that helps.
      03-20-2024, 03:02 AM   #16
NealfromNZ
NealfromNZ's Avatar
New Zealand
527
Drives: 2016 F80 M3
And set Bluetooth profile if iPhone to car stereo by taping i next to the bmw entry . Under device change it to car stereo.
      03-20-2024, 12:34 PM   #17
relicomelico
Thanks you very much!! Worked first time even though my current number of software wasn't in the pdf for that bin file either. Still doesn't seem to be syncing my contacts correctly with my new phone but i guess it's better to be more up to date!!! Thanks again!
      03-20-2024, 05:01 PM   #18
F30330direland
Drives: F30 330D
Thanks for all the info dogballs
The update worked this time with that VIN.
But it still doesn’t seem to be the most up to date version.
The songs still don’t switch for me.
I have tried all the other suggested things. It’s quite strange the odd time it does work…..
      03-20-2024, 05:52 PM   #19
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
If you can post a pic of the updated software versions, I will do some research. I have seen a number of this year 2013-2014 nbt vehicles have problems with taking this update.… there may be some FDL changes required to get album art and skip working correctly.
You should have an additional “add on”line as below:
      04-10-2024, 04:17 PM   #20
ljones85
Drives: bmw m520d
Ie TV-110.005.011
Good luck.
I have the same problem but dont understand this solution
      04-11-2024, 05:00 AM   #21
dogballs
dogballs's Avatar
New Zealand
62
  [0.00]
Post an image of your current version.
I’ll see if I can find the update file for you.
      04-18-2024, 12:50 AM   #22
Bkevinn
Drives: 2014 328i
I have the same issue 2014 328i
